Delay-limited channel capacity
Started by Tim Wescott June 11, 2016
On Sat, 11 Jun 2016 15:47:02 -0500, Tim Wescott
<seemywebsite@myfooter.really> wrote:
>On Sat, 11 Jun 2016 19:57:04 +0000, Eric Jacobsen wrote: > >> On Sat, 11 Jun 2016 11:44:51 -0500, Tim Wescott <tim@seemywebsite.com> >> wrote: >> >>>On Sat, 11 Jun 2016 15:25:53 +0000, Eric Jacobsen wrote: >>> >>>> On Sat, 11 Jun 2016 00:29:23 -0500, Tim Wescott >>>> <seemywebsite@myfooter.really> wrote: >>>> >>>>>On Sat, 11 Jun 2016 04:01:46 +0000, Eric Jacobsen wrote: >>>>> >>>>>> On Fri, 10 Jun 2016 22:28:19 -0500, Tim Wescott >>>>>> <tim@seemywebsite.com> >>>>>> wrote: >>>>>> >>>>>>>(This came to mind during a reply to Eric Jacobsen's comment in my >>>>>>>thread about block codes). >>>>>>> >>>>>>>Anyone know of a treatment of Shannon's channel capacity theorem >>>>>>>that adds a finite limit to the delay? >>>>>>> >>>>>>>I.e., instead of saying that I have a linear channel with additive >>>>>>>noise, >>>>>>>defined power and bandwidth, say that I have all that PLUS a >>>>>>>constraint on the total delay in the coding and decoding processes. >>>>>>>Can I then define the best-case properties of any coding scheme? >>>>>>> >>>>>>>That seems clear to me, but let me restate: >>>>>>> >>>>>>>Say that I generate a bit at time t_0. That bit gets gathered up >>>>>>>with other bits, coded, then decoded, and then is finally available >>>>>>>to the receiver at time t_1. If I define a maximum delay T_d, and >>>>>>>insist that t_1 - t_0 < T_d, what does the channel capacity theorem >>>>>>>look like now? >>>>>> >>>>>> I think you're just describing latency, i.e., you need minimum >>>>>> latency. >>>>>> >>>>>> There are several abstractions that have to be kept in mind. >>>>>> >>>>>> You've almost eliminated block codes for consideration, since for >>>>>> block codes the bit generated at t_0 may not even be able to be >>>>>> encoded until its N-1 brethren (for the rest of the block) are >>>>>> available to the encoder. >>>>>> >>>>>> Likewise in the decoder, even if the bit is received at t_1, the >>>>>> decoder may not be able to start working on that block (depending on >>>>>> the code structure), until the other N-1 bits in the block have been >>>>>> received. >>>>>> >>>>>> For mimizing latency this suggests the smallest block possible, or, >>>>>> even better, don't even use a block code, use something like an >>>>>> ordinary convolutional code, which provides a much more minimized >>>>>> latency at the potential expense of some coding gain. >>>>>> >>>>>> I think the main thing relevent in the computation of capacity is >>>>>> the length of the block, and capacity increases with block length >>>>>> (due to the increase in bit diversity or mutual information). But >>>>>> as the block length increases, so does the latency, so there is a >>>>>> somewhat natural tradeoff there for capacity approaching codes. >>>>>> >>>>>> You'll also need to quantify how important the delay is compared to >>>>>> coding gain, which is system dependent. >>>>> >>>>>Block codes may still be in the running, if the blocks are short >>>>>enough, >>>>>because to some extent things could be arranged so that the Really >>>>>Important Bits could fall on the last bit of a block. It'd make >>>>>certain people at my customer site cranky, but it could be done. >>>>> >>>>>I want lots of coding gain AND low delay, of course. >>>> >>>> Can we ask what coding is used in the system now, if any? >>> >>>Not an intentional one. It's mud-pulse communication for oil wells, and >>>it's primarily designed to minimize battery consumption on an obsolete >>>design of mud pulser which only consumed battery power during a '1'. >>>Secondarily, it's an extension of an even older protocol that was close >>>to being human readable. >>> >>>It's basically an M-ary pulse-position coding, with guard intervals >>>between words and a single parity bit. M can equal either 4 or 8 (to >>>minimize delay, word lengths are variable). The even older protocol >>>used M = 10, and you could count out numbers while watching the pressure >>>gauge. >>> >>>There is redundancy there (a pulse can't exist at position 0 and 3, for >>>instance, and a pulse is always a specific width, etc), but it's not >>>deliberate redundancy for coding gain. >>> >>> >> It seems like everybody winds up working on down-hole stuff at one time >> or other. >> >> Since the current system is essentially uncoded, adding a basic >> convolutional code with a Viterbi decoder should have a significant >> improvement on link reliability. Depending on available processing >> power and power consumption limits, there are common, easy-to-implement >> codes with constraint lengths of k = 4, 7, and 9, with each increasing >> decoding complexity and coding gain simultaneously. The beauty of the >> convolutional codes in this case is that the latency can be very, very >> low. Gain compared to the current system would be expected to be >> significant. >> >> While convolutional codes work well with hard-decisions, they work much >> better with soft decisions (as do most codes). I'd think it wouldn't >> be too difficult to come up with a soft-decision mapper for that. > >When you have all the time in the world, soft decisions are easy. > >I've done Viterbi decoders before, I can certainly do one again. It'd be >easier than what's in there now, for sure.
Thinking about it a little more I hope I didn't speak too soon on that. One thing with codes is that some deal with certain types of errors and error distributions better than others. Convolutional codes are good with randomly-distributed errors (like AWGN channel errors), and I don't know if that's what happens in a mud-pulse channel. Sometimes the down-hole stuff suffers from interference and nonlinearities which may affect the error distributions, so it is possible that other codes may work better as the distributions move away from random. Binary block codes sometimes tend to not care about error distributions (within a block) as much as error quantities. Mud-pulse channels have been around for a long time and are well-studied so there are probably references regarding applying FEC or ECC to those channels. The only down-hole work I've done was for a different channel, so I don't have any direct experience with mud-pulse, although it seems like it's been beatern to death for a long time and there should be reference material.
On Friday, June 10, 2016 at 11:28:21 PM UTC-4, Tim Wescott wrote:
> (This came to mind during a reply to Eric Jacobsen's comment in my thread > about block codes). > > Anyone know of a treatment of Shannon's channel capacity theorem that > adds a finite limit to the delay? > > I.e., instead of saying that I have a linear channel with additive noise, > defined power and bandwidth, say that I have all that PLUS a constraint > on the total delay in the coding and decoding processes. Can I then > define the best-case properties of any coding scheme? > > That seems clear to me, but let me restate: > > Say that I generate a bit at time t_0. That bit gets gathered up with > other bits, coded, then decoded, and then is finally available to the > receiver at time t_1. If I define a maximum delay T_d, and insist that > t_1 - t_0 < T_d, what does the channel capacity theorem look like now? > > -- > Tim Wescott > Control systems, embedded software and circuit design > I'm looking for work! See my website if you're interested > http://www.wescottdesign.com
Yes, either you look at error exponents (see: Gallager's PhD thesis), or you look at finite (sphere packing-ish) bounds on codes, which can be interesting for simple channels such as AWGN. IIRC the latest popular work is from Polyanskiy, Poor, and Verdu, essentially Polyanskiy's PhD thesis from 2010 at Princeton. He's now at MIT. It builds on results old and new, and the paper is quite nice to read. http://www.princeton.edu/~verdu/reprints/PolPooVerMay2010.pdf?q=tilde/verdu/reprints/PolPooVerMay2010.pdf
