I discovered this when solving one of those trivia questions. The question was to find out what 36 divided by 2.(3)+ 4 can't get the division symbol on this PC. Correct answer should be to write this as 36/2 X 3 + 4 =58 a computer would interpret it thus. Type that into a calculator and you will get 58 if you type 36 divided by 2X(3) + 4 where it doesn't matter whether there is a bracket round the 3 or not. Now in your calculator put 36 divided by 2.(3)+4 where you use the dot operator (assuming your calculator supports this) instead of multiply. You get 10. It appears that the dot multiply takes the brackets around the 2 and 3 (2X3) and then does the division into 36. You must have the brackets round the 3 or it takes the number as 2.3 of course.
OT: Calculators
Started by ●August 18, 2016
Reply by ●August 18, 20162016-08-18
On Thursday, August 18, 2016 at 2:19:18 PM UTC-7, gyans...@gmail.com wrote:> I discovered this when solving one of those trivia questions.> The question was to find out what> 36 divided by 2.(3)+ 4> can't get the division symbol on this PC.> Correct answer should be to write this as> 36/2 X 3 + 4 =58(snip)> 36 divided by 2.(3)+4> where you use the dot operator (assuming your calculator supports > this) instead of multiply. You get 10.In the early days of calculators, there was no precedence. All operations were done left to right, as that saved registers.> It appears that the dot multiply takes the brackets around the 2 and 3 > (2X3) and then does the division into 36. You must have the brackets > round the 3 or it takes the number as 2.3 of course.Which calculators have a dot operator? -- glen
On Friday, August 19, 2016 at 12:55:11 PM UTC+12, herrman...@gmail.com wrote:> On Thursday, August 18, 2016 at 2:19:18 PM UTC-7, gyans...@gmail.com wrote: > > I discovered this when solving one of those trivia questions. > > > The question was to find out what > > > 36 divided by 2.(3)+ 4 > > > can't get the division symbol on this PC. > > > Correct answer should be to write this as > > > 36/2 X 3 + 4 =58 > > (snip) > > > 36 divided by 2.(3)+4 > > > where you use the dot operator (assuming your calculator supports > > this) instead of multiply. You get 10. > > In the early days of calculators, there was no precedence. All operations > were done left to right, as that saved registers. > > > It appears that the dot multiply takes the brackets around the 2 and 3 > > (2X3) and then does the division into 36. You must have the brackets > > round the 3 or it takes the number as 2.3 of course. > > Which calculators have a dot operator? > > -- glenCasio does and so does sharp.
herrmannsfeldt@gmail.com writes:> On Thursday, August 18, 2016 at 2:19:18 PM UTC-7, gyans...@gmail.com wrote: >> I discovered this when solving one of those trivia questions. > >> The question was to find out what > >> 36 divided by 2.(3)+ 4 > >> can't get the division symbol on this PC. > >> Correct answer should be to write this as > >> 36/2 X 3 + 4 =58 > > (snip) > >> 36 divided by 2.(3)+4 > >> where you use the dot operator (assuming your calculator supports >> this) instead of multiply. You get 10. > > In the early days of calculators, there was no precedence. All operations > were done left to right, as that saved registers. > >> It appears that the dot multiply takes the brackets around the 2 and 3 >> (2X3) and then does the division into 36. You must have the brackets >> round the 3 or it takes the number as 2.3 of course. > > Which calculators have a dot operator?<snicker> -- Randy Yates, DSP/Embedded Firmware Developer Digital Signal Labs http://www.digitalsignallabs.com
