I am looking for an IP camera that: 1. will allow me to programmatically connect to it (over UDP or TCP) 2. will send me the camera's microphone audio as RTP over UDP 3. supports the following audio sample rates: 8000Hz and any sample rate greater than or equal to 44.1kHz Any recommendations?
Off-Topic : Looking for IP camera which can send audio via RTP to remote client
Started by ●October 1, 2016
Reply by ●October 2, 20162016-10-02
>I am looking for an IP camera that: > >1. will allow me to programmatically connect to it (over UDP or TCP) >2. will send me the camera's microphone audio as RTP over UDP >3. supports the following audio sample rates: 8000Hz and any sample rate >greater than or equal to 44.1kHz > >Any recommendations?Is this a one-time project, or perhaps a prototype for a new product? You might consider finding a used netbook computer, slapping a Linux distro on it, and find some open source software to accomplish what you want. You could use the built in mic, or purchase a higher quality USB mic. You don't mention you want to do anything with the video, but having a computer would mean you could easily save a large number of images locally. You could use the built in cam, or get an external one, or both. If the battery is still good, you have built in power backup. Connectivity and security on the internet are already well known quantities. Just some thoughts since you haven't seemed to gotten any other answers. Ced --------------------------------------- Posted through http://www.DSPRelated.com
>I am looking for an IP camera that: > >1. will allow me to programmatically connect to it (over UDP or TCP) >2. will send me the camera's microphone audio as RTP over UDP >3. supports the following audio sample rates: 8000Hz and any sample rate >greater than or equal to 44.1kHzMeeting requirement (3), if it's intended literally, is going to be a tough well to frack. Steve
Reply by ●October 11, 20162016-10-11
> Is this a one-time project, or perhaps a prototype for a new product?It's a prototype project which must use a commercially available cam.> You don't mention you want to do anything with the videoI'm only interested in the audio stream.
> >3. supports the following audio sample rates: 8000Hz and any sample rate > >greater than or equal to 44.1kHz > > Meeting requirement (3), if it's intended literally, is going to > be a tough well to frack. >why? there are plenty of cams sampling at a frequency equal to (or above) 44.1kHz.
Reply by ●October 12, 20162016-10-12
Am 11.10.16 um 17:21 schrieb Mauritz Jameson:>> Is this a one-time project, or perhaps a prototype for a new product? > > It's a prototype project which must use a commercially available cam. > >> You don't mention you want to do anything with the video > > I'm only interested in the audio stream. >If it's just a prototpe, you could use a mobile phone. Network and sound etc. is for free, either you'll find an app for android or it is trivial to write it. Stackoverflow points me there: https://github.com/fyhertz/libstreaming Christian
Reply by ●October 13, 20162016-10-13
>> Is this a one-time project, or perhaps a prototype for a new product? > >It's a prototype project which must use a commercially available cam. > >> You don't mention you want to do anything with the video > >I'm only interested in the audio stream.So the functionality you need is really audio capture and computing power and you think the best platform might be a turnkey video camera? First, do a search on "Internet of Things botnet attack" to understand the importance of good security. Often just changing passwords from the default is adequate, so this doesn't necessarily rule out your proposed solution. Second, I would recommend you look into the Rasperry Pi computer. It is touted as a minimalist Linux system retailing at $35. Attach an external USB microphone, which depending on the quality you need, you may be able to get for $10 anywhere up to hundreds of dollars. Now, if you want to get a real discussion started, pick an encoding scheme for RTP and proclaim that it is the best. Regards, Ced --------------------------------------- Posted through http://www.DSPRelated.com
