Hello! I am learning about iir filters. For this I was going through the bass boost effect of audacity. Can anybody please tell me how exactly the filter coefficients are being calculated? I wonder how do we come to a point of understanding that "this" algorithm for calculating the coefficients is the one for bass boost or any other effect. I tried applying the same effect with FIR filter. I passed the original signal through a low-pass filter, amplified it and added it again to the original one. Bass was boosted no probs in that but there are clicks. I think its again the same problem of taking the input signal as chunks instead of a continuous stream. Am I right or is there something else that I cannot see? BTW, the following is the code that audacity uses for bass boosting. My question is: what criteria brings us to this calculation of coefficients? /* Compute coefficents of the biquand IIR filter */ omega = 2 * 3.141592653589 * frequency / mCurRate; sn = sin(omega); cs = cos(omega); a = exp(log(10.0) * dB_boost / 40); shape = float(1.0); /*Low Shelf filter's shape, if this is too large or too small it will result an unstable filter */ beta = sqrt((a * a + 1) / shape - (pow((a - 1), 2))); /* Coefficients */ b0 = a * ((a + 1) - (a - 1) * cs + beta * sn); b1 = 2 * a * ((a - 1) - (a + 1) * cs); b2 = a * ((a + 1) - (a - 1) * cs - beta * sn); a0 = ((a + 1) + (a - 1) * cs + beta * sn); a1 = -2 * ((a - 1) + (a + 1) * cs); a2 = (a + 1) + (a - 1) * cs - beta * sn; Then these coefficients are used in recursion equation:- (b0 * in + b1 * xn1 + b2 * xn2 - a1 * yn1 - a2 * yn2) / a0; (xn and yn are previous inputs and outputs respectively) Thanks and regards --Himanshu
Understanding IIR filters -- Audacity's Bass Boost
Started by ●May 27, 2005
Reply by ●May 27, 20052005-05-27
It looks like they are using the low shelving biquad filter (IIR) from RB-J's Audio EQ Cookbook: http://www.musicdsp.org/files/Audio-EQ-Cookbook.txt RB-J can jump in if I get it wrong, but those equations were created by starting with the basic analog filter equations, transforming using the bi-linear Z transform, and then doing a whole bunch of algebraic manipulation/trig substitutions to get the relatively simple forms shown. The link above has some additional explanations of this, so try reading through that and see if that answers your questions. The section at the end talks about derivation. -- Jon Harris SPAM blocked e-mail address in use. Replace the ANIMAL with 7 to reply. "Himanshu Chauhan" <hs.chauhan@gmail.com> wrote in message news:1117207908.649533.253610@f14g2000cwb.googlegroups.com...> Hello! > > I am learning about iir filters. For this I was going through the bass > boost effect of audacity. Can anybody please tell me how exactly the > filter coefficients are being calculated? I wonder how do we come to a > point of understanding that "this" algorithm for calculating the > coefficients is the one for bass boost or any other effect. I tried > applying the same effect with FIR filter. I passed the original signal > through a low-pass filter, amplified it and added it again to the > original one. Bass was boosted no probs in that but there are clicks. I > think its again the same problem of taking the input signal as chunks > instead of a continuous stream. Am I right or is there something else > that I cannot see? > BTW, the following is the code that audacity uses for bass boosting. > > My question is: what criteria brings us to this calculation of > coefficients? > > /* Compute coefficents of the biquand IIR filter */ > omega = 2 * 3.141592653589 * frequency / mCurRate; > sn = sin(omega); > cs = cos(omega); > a = exp(log(10.0) * dB_boost / 40); > shape = float(1.0); /*Low Shelf filter's shape, if this is > too large > or too small it will result an unstable > filter */ > beta = sqrt((a * a + 1) / shape - (pow((a - 1), 2))); > /* Coefficients */ > b0 = a * ((a + 1) - (a - 1) * cs + beta * sn); > b1 = 2 * a * ((a - 1) - (a + 1) * cs); > b2 = a * ((a + 1) - (a - 1) * cs - beta * sn); > a0 = ((a + 1) + (a - 1) * cs + beta * sn); > a1 = -2 * ((a - 1) + (a + 1) * cs); > a2 = (a + 1) + (a - 1) * cs - beta * sn; > > Then these coefficients are used in recursion equation:- > (b0 * in + b1 * xn1 + b2 * xn2 - a1 * yn1 - a2 * yn2) / a0; > > (xn and yn are previous inputs and outputs respectively) > > Thanks and regards > --Himanshu >
in article 119el3mh79qcaef@corp.supernews.com, Jon Harris at jon_harrisTIGER@hotmail.com wrote on 05/27/2005 13:11:> It looks like they are using the low shelving biquad filter (IIR) from RB-J's > Audio EQ Cookbook: > http://www.musicdsp.org/files/Audio-EQ-Cookbook.txti dunno whether or not Audacity uses the cookbook or not, but the equations below look a lot like the cookbook.>> BTW, the following is the code that audacity uses for bass boosting.where do they say that? just a curiousity.>> My question is: what criteria brings us to this calculation of >> coefficients? >> >> /* Compute coefficents of the biquand IIR filter */ >> omega = 2 * 3.141592653589 * frequency / mCurRate; >> sn = sin(omega); >> cs = cos(omega); >> a = exp(log(10.0) * dB_boost / 40); >> shape = float(1.0); /*Low Shelf filter's shape, if this is >> too large >> or too small it will result an unstable >> filter */ >> beta = sqrt((a * a + 1) / shape - (pow((a - 1), 2))); >> /* Coefficients */ >> b0 = a * ((a + 1) - (a - 1) * cs + beta * sn); >> b1 = 2 * a * ((a - 1) - (a + 1) * cs); >> b2 = a * ((a + 1) - (a - 1) * cs - beta * sn); >> a0 = ((a + 1) + (a - 1) * cs + beta * sn); >> a1 = -2 * ((a - 1) + (a + 1) * cs); >> a2 = (a + 1) + (a - 1) * cs - beta * sn; >> >> Then these coefficients are used in recursion equation:- >> (b0 * in + b1 * xn1 + b2 * xn2 - a1 * yn1 - a2 * yn2) / a0; >>-- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
