Hi, everybody. I am a newcomer here and not familar with DSP. I got a problem during my work. I need to do a project about anti-vibration control for a machine. For this realtime system, I want to do active vibration control for this system. I don't know which kind of DSP board i need to buy for hardware concern. I know I need floating point. Thus, TI TMS320 3x or TI TMS67x will be a good selection. I searched the TI third party items, but I have no idea what items is what i want to look for.I am confused to select. I know I need a board combined DSP,memory, A/D,D/A and I/o together. So if anybody can give me some suggestion, I really appreciate.
question for purchasing DSP
Started by ●June 2, 2005
Reply by ●June 2, 20052005-06-02
iris wrote:> Hi, everybody. I am a newcomer here and not familar with DSP. I got a > problem during my work. I need to do a project about anti-vibration > control for a machine. For this realtime system, I want to do active > vibration control for this system. I don't know which kind of DSP board > i need to buy for hardware concern. I know I need floating point. Thus, > TI TMS320 3x or TI TMS67x will be a good selection. I searched the TI > third party items, but I have no idea what items is what i want to look > for.I am confused to select. I know I need a board combined DSP,memory, > A/D,D/A and I/o together. So if anybody can give me some suggestion, I > really appreciate. >Google is your friend. The owner of http://www.danvillesignal.com/ will respond pretty soon, directing you to his site. You should be able to pick up some search terms there. I suspect that you'll be lucky to find a single board that has everything you need -- certainly you'll be very lucky to find the signal conditioning that you need, and if you need to make a custom signal conditioning board you may as well put the A/D and D/A converters there as well. To pick the right board you need to have a structured understanding of what you're trying to accomplish -- what are your performance goals, what requirements does this place on your control system in terms of accuracy of measurement and drive, what algorithm do you need to use and what sampling rate do you need to sustain? Once you have answered these questions then you should be able to determine what sort of data conversion you need, and with a bit of code prototyping you should be able to determine what kind of processor speed you need. ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"iris" <haiyan77@gmail.com> wrote in news:1117747878.090276.272550 @z14g2000cwz.googlegroups.com:> Hi, everybody. I am a newcomer here and not familar with DSP. I got a > problem during my work. I need to do a project about anti-vibration > control for a machine. For this realtime system, I want to do active > vibration control for this system. I don't know which kind of DSP board > i need to buy for hardware concern. I know I need floating point. Thus, > TI TMS320 3x or TI TMS67x will be a good selection. I searched the TI > third party items, but I have no idea what items is what i want to look > for.I am confused to select. I know I need a board combined DSP,memory, > A/D,D/A and I/o together. So if anybody can give me some suggestion, I > really appreciate. > >I think we probably have a number of good solutions based around the Analog Devices SHARC DSPs. Analog Devices and TI have about equal market share when it comes to general purpose DSP applications (after you factor out large vertical markets). Did you know that 70% of all DSPs are in cell phones? We would be glad to discuss your application in detail. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Tim Wescott <tim@seemywebsite.com> wrote in news:119v11kl30ukjee@corp.supernews.com:> iris wrote: >> Hi, everybody. I am a newcomer here and not familar with DSP. I got a >> problem during my work. I need to do a project about anti-vibration >> control for a machine. For this realtime system, I want to do active >> vibration control for this system. I don't know which kind of DSPboard>> i need to buy for hardware concern. I know I need floating point.Thus,>> TI TMS320 3x or TI TMS67x will be a good selection. I searched the TI >> third party items, but I have no idea what items is what i want tolook>> for.I am confused to select. I know I need a board combinedDSP,memory,>> A/D,D/A and I/o together. So if anybody can give me some suggestion, I >> really appreciate. >> > > Google is your friend. The owner of http://www.danvillesignal.com/will> respond pretty soon, directing you to his site. You should be able to > pick up some search terms there.Tim, I actually responded to Iris before I even opened your response. I guess I am a little predictable but I would be remiss if I didn't follow up on an application that our boards are well suited for.....> > I suspect that you'll be lucky to find a single board that has > everything you need -- certainly you'll be very lucky to find thesignal> conditioning that you need, and if you need to make a custom signal > conditioning board you may as well put the A/D and D/A converters there > as well.Absolutely true!. This is precisely why our DSP boards use separate I/O modules. In many cases we design a custom I/O module for the customer's application which is much easier than creating a DSP board.> > To pick the right board you need to have a structured understanding of > what you're trying to accomplish -- what are your performance goals, > what requirements does this place on your control system in terms of > accuracy of measurement and drive, what algorithm do you need to useand> what sampling rate do you need to sustain? Once you have answeredthese> questions then you should be able to determine what sort of data > conversion you need, and with a bit of code prototyping you should be > able to determine what kind of processor speed you need.Yep.> > ------------------------------------------- > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com >-- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Reply by ●June 3, 20052005-06-03
>Hi, everybody. I am a newcomer here and not familar with DSP. I got a >problem during my work. I need to do a project about anti-vibration >control for a machine. For this realtime system, I want to do active >vibration control for this system. I don't know which kind of DSP board >i need to buy for hardware concern. I know I need floating point. Thus, >TI TMS320 3x or TI TMS67x will be a good selection. I searched the TI >third party items, but I have no idea what items is what i want to look >for.I am confused to select. I know I need a board combined DSP,memory, >A/D,D/A and I/o together. So if anybody can give me some suggestion, I >really appreciate. >AFAIK, the TMS320C6713 DSK(DSP Starter Kit) boards would be a good choice for evaluating one's solution.Am not sure if you need to break your head with third party(hence more specialized and verticalized) solution at all! [http://focus.ti.com/docs/toolsw/folders/print/tmdsdsk6713.html] The board come with a bundled IDE speacially tweaked for the DSK. Some say this is the words best optimizing compiler(including me). The an on-board codec AIC23--sigma delta ADC-- a programmable codec capable of doing upto 78khz, so that should be enough for your requirements? If not, you can use some speacialized daughter cards that can sample at higher rates. [http://dspvillage.ti.com/docs/catalog/devtools/dsptoolslist.jhtml?familyId=132&toolTypeId=48&toolTypeFlagId=2&templateId=5154&path=templatedata/cm/toolswchrt/data/c6000_daughtercds] And please be assured that the DSK board comes with all that you want I/O,memory,DSP,A/D,D/A etc. all of em! It has on chip memory of about 100kb and onboard memory of 16MB.There are expansion slots available for you to interface more memory if need be. There are multiple high speed and slow speed I/O solutions. The on-chip high speed serial port in C6000 is called McBSP(multi channel buffered serial port), this runs at 100mbps and there are two of em, so thats a through put of about 200 mbps! It has a DMA throughput of >26000 mbps as well. I would rate CPU performance based on three characteristics: 1] Maximum CPU performance: 2] Maximum I/O performance 3] Available High Speed Memory Once you evaluate these three issues, you can then go ahead scale the numbers to compare with your applications needs and the determine: * CPU Load (% of maximum) * Availability of head room to do *extra*( This is very important) --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
>Analog Devices and TI have about equal market share >when it comes to general purpose DSP applications >(after you factor out >large vertical markets) >Did you know that 70% of all DSPs are in cell >phones?TI dominates the digital media application domain as well but thats not cell phones? In fact none of the C6000 devices (DM64x,C67xx,C62xx,C64xx) are used in cell phones(in fact they cannot be because of their non low-power characteristics) but are dominant market players when it comes to high performance ILP demanding applications.Google "Digital media processors" , you will likely come up with lots of DM64xx based product press releases! --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
"bhooshaniyer" <bhooshaniyer@gmail.com> wrote in news:Z5ydnY6uJvZcZgLfRVn- uA@giganews.com:>>Analog Devices and TI have about equal market share >>when it comes to general purpose DSP applications >>(after you factor out >>large vertical markets) >>Did you know that 70% of all DSPs are in cell >>phones? > > TI dominates the digital media application domain as well but thats not > cell phones? In fact none of the C6000 devices (DM64x,C67xx,C62xx,C64xx) > are used in cell phones(in fact they cannot be because of their non > low-power characteristics) but are dominant market players when it comes > to high performance ILP demanding applications.Google "Digital media > processors" , you will likely come up with lots of DM64xx based product > press releases! > > --Bhooshan >TI certainly has a significant portion of the DSP market. I think there is a tendency to consider that they are the only game in town since their cell phone chip sales are so large. If you subtract the large vertical markets (cell phones, hard drives, etc) and look just at the general purpose market, TI has about a 30% share. Analog Devices also has a 30% share with the remaining 40% going to a very fragmented remainder. With the exception of Randy Yates, I don't know any of us who work outside of the general purpose market. The third generation SHARC (ADSP-2126x & ADSP-2136x) compare very favorably with the C67xx. The SHARC is a 32/40 bit floating point and fixed point DSP that in my view is much easier to program than any TI DSP. Evaluation boards like the TI DSK and Analog Devices EZ-Kits are great ways of learning about a specific DSP processor. The catch is that when you are done with the eval board, you still have just an eval board. Danville dspstak boards are designed for small and medium sized production runs. Our customers might use 10 - 500 systems a year. The high volume customers will usually create their own proprietary solutions where they can benefit from economies of scale. We are not at a disadvantage however when it comes to evaluation boards. Recently, we received a license to incorporate the Analog Devices EZ-Kit Debugger on our SHARC based dspstak boards. You can use a full featured Visual DSP license or you can use an EZ-Kit (free) license. From Visual DSP's point of view, these boards look like an EZ-Kit. This means that you can develop your application on a dspstak board and then integrate it directly into production. We also separate I/O from the DSP (two boards) since as everyone has pointed out, the I/O tends be different from application to application. It is also a lot easier to create a special I/O module than create a DSP board (with or without I/O). I certainly agree with Tim Wescott that it starts with the requirements of the application. We can help with this part of the process, we also provide complete turnkey solutions or refer people to skilled consultants like Tim and others who participate in this forum. Bhooshan is a hopeless TI partisan, OTOH, I am a long time ADI JEDI. For all you young Skywalkers out there, resist the dark side. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
bhooshaniyer wrote: ...> AFAIK, the TMS320C6713 DSK(DSP Starter Kit) boards would be a good choice > for evaluating one's solution.Am not sure if you need to break your head > with third party(hence more specialized and verticalized) solution at > all!... It's has been my experience that the right third-party board for any class of processor is usually easier to use. Chip makers design their boards to fit into as wide a range of applications as they can. Third-party suppliers usually select likely niches and design boards specialized for them. The problem with third-party boards is knowing enough about the application to choose the right one. Specialization carries extra costs. The chip maker gets his chips at cost, whatever the internal accounting may be. Although his development board probably doesn't sell as widely as the third-party boards do in the aggregate, it usually has a much higher volume than any one of them. With the right third-party board, the cost is usually more than repaid with time saved and the hand-holding that most third-party vendors are willing to provide. Chip maker's boards are like undifferentiated stem cells: they can become anything. You can usually find a third-party board that, while not completely specialized for your application, is a much better fit to it. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> >TI certainly has a significant portion of the DSP market. I think thereis>a tendency to consider that they are the only game in town since theircell>phone chip sales are so large.I again reiterate that the C6000 devices have NOTHING to do with the cell phone market but it IS the dominant processor is the digital media,high speed switching, multi-channel devices,ADSl's,pooled modems etc. I have great fascination and admiration for the C6000 architectire, it is so elegant,simple and powerful. Joseph fisher-- the father of VLIW philosophy -- would approve of the C6000 architecture and he does in his new book "Embedded Computing-A VLIW Approach. Fisher has been a long time advocate of engineering the compiler and the chip together, right from the start of the chip design. The idea is that the compiler should dictate some of the architectural features for its own convenience and the result would be a powerful compiler. This, as opposed to treating compiler as a piece of **** in the DSP market which is the norm (even today) among many other vendors makes me a c6000 die hard. Ray Simar and Nat Seshan had the vision to investigate such a radical approact to the ISA design as envisioned by Fisher,as far back as 1992. The chip was sampled in the fall of 1996 (I started programming them in 1998) and the rest is history. (I have heard of a story where the motorolla and AD guys being caught totally unawares, when TI released a press note in early 1996,suggesting that their new DSP's would run at 1200 MIPS in the days when 200 MIPS was considered SUPER!) Till today the C6000 architecture, if not the only one, the MOST successful VLIW architecture, barring none(trimedia,StarCore,SHARC). I hear that future ARM processors are going to follow this VLIW, deep pipeline route as well, ofcourse the key to success depends on the answer to the question "How powerful would their compilers be?" As long as companies keep *fixing* their compilers rather than engineer them ground up, the answer woould be "Not Very!".>If you subtract the large vertical markets (cell phones, hard drives,etc)>and look just at the general purpose market, TI has about a 30% share. >Analog Devices also has a 30% share with the remaining 40% going to avery>fragmented remainder.I dont know about the figures, because am not a marketing guy! I can look it up at forward concepts, but am too lazy to do that,so I will take your word for it! But as I mentioned, C6000 is dominating player in the high end multi-channel, digital media space, without a doubt.>With the exception of Randy Yates, I don't know any >of us who work outside of the general purpose market.:-) Time to make few friends, AL?>The third generation SHARC (ADSP-2126x & ADSP-2136x) compare veryfavorably>with the C67xx.Mmmm...am not sure, but I have not studied them carefully either! Of the hand though my understanding is that the compiler is not powerful enough for it to be a force. In the academia, again for various reasons, C6000 is the most popular architecture for running Real Time DSP Courses. (Rice,Texas A&M,Utexas,IITD,IITB, Rose-Hulman, George Washington,Stanford...) Notwithstanding the TI marketing machine, there must be a good reason for this predisposition(ease of use, elegance, powerful compiler, IDE, royalty free RTOS...) I know of only popular course using Analog Devices DSP, which is run by Dr.Smith at the University of Calgary in canada-(http://www.enel.ucalgary.ca/People/Smith/2004webs/encm515_04/)>The SHARC is a 32/40 bit floating point and fixed point DSP >that in my view is much easier to program than any TI DSP.Oh, thats just a matter of which one you start first I suppose! I have tried my hand at different processors after gaining my initial understanding and expertise in TI DSP's and I have found the rest of them lot less intuitive to use and am sure thats just a feeling, thats all! Thats is as far as the IDE and the tools are concerned, but were you refering to the difficulty involved in hand-coding scheduled assembly to the deeply pipelined C6000 architecture?>Evaluation boards like the TI DSK and Analog Devices EZ-Kits are greatways>of learning about a specific DSP processor. The catch is that when youare>done with the eval board, you still have just an eval board.I have seen few customers develop audio solutions, right upto production using the C6711 DSK.Yes, it is not the norm but can be done.>Danville dspstak boards are designed for small and medium sizedproduction>runs. Our customers might use 10 - 500 systems a year. The high volume >customers will usually create their own proprietary solutions where they>can benefit from economies of scale.I think it is a wonderful product from what I hear.I personally cannot wait to get my hands on it. It will be a chance also for me to evaluate a non-TI DSP solution, seriously.>We are not at a disadvantage however when it comes to evaluation boards.>Recently, we received a license to incorporate the Analog Devices EZ-Kit>Debugger on our SHARC based dspstak boards. You can use a full featured >Visual DSP license or you can use an EZ-Kit (free) license. From Visual >DSP's point of view, these boards look like an EZ-Kit.Well, you see, with TI based boards, this is an absolute given-that the boards will have to have the Code Composer Studio IDE hook! There is not much else to it, any third party board will support CCS and all TI evaluation kits, development kits come with CCS. Period.>This means that you can develop your application on a dspstak board and >then integrate it directly into production.This is what I alluded to earlier, most of indulge in such methods in TI solutions.>We also separate I/O from the >DSP (two boards) since as everyone has pointed out, the I/O tends be >different from application to application. It is also a lot easier to >create a special I/O module than create a DSP board (with or withoutI/O). I have no expertise to comment on this, so am assuming you are right!>Bhooshan is a hopeless TI partisan,May be am, may be not.I just LOVE the TI DSP architecture more than I like TI, in itself but yes TI is much better at enabling channel partners like us.>OTOH, I am a long time ADI JEDI. For >all you young Skywalkers out there, resist the dark side.Black is beautiful. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Al-->Bhooshan is a hopeless TI partisan, OTOH, I am a long time ADI JEDI. For>all you young Skywalkers out there, resist the dark side.May be if you keep sending me those 10$ every week for my pizza, I will stop being a TI partisan, what say? :-) --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
