Hi Group This is a new estimator based on real and imaginary values of two DFT bins. The estimator is exact for a pure sinusoid without noise. It performs well in the presence of noise. Let k be the index of the DFT bin with the largest magnitude. Let j be the index of the DFT bin with the largest magnitude neigboring bin k. That is j=k-1 or j=k+1. Now let Sk = Sin(2*PI*k/N) Ck = Cos(2*PI*k/N) Sj = Sin(2*PI*j/N) Cj = Cos(2*PI*j/N) Then the Cosine of the normalised angular frequency can be estimated as the root of the quadratic with the following coefficients: A = Sj*Im[k] - Sk*Im[j] B = Sj*Sk*Re[k] - 2*Sj*Ck*Im[k] - Sk*Sj*Re[j] + 2*Sk*Cj*Im[j] C = - Sj*Sk*Ck*Re[k] + Sj*Ck^2*Im[k] + Sk*Sj*Cj*Re[j] - Sk*Cj^2*Im[j] where Re[] is the real part of X[] and Im[] is the imaginary part of X[]. The roots are Cw1 = (-B + Sqr(B^2-4*A*C))/(2*A) and Cw2 = (-B - Sqr(B^2-4*A*C))/(2*A) The root in the interval [Min(Ck,Cj), Max(Ck,Cj)] is the correct answer, Cw. The normalised frequency is then Freq=(N/(2*PI))*Arccos(Cw) Regards, Michael Plet
Plet's Second Estimator
Started by ●February 21, 2017
Reply by ●February 21, 20172017-02-21
On Tue, 21 Feb 2017 14:07:17 +0100, Michael Plet <me@home.com> wrote:>Hi Group > >This is a new estimator based on real and imaginary values of two DFT >bins. >The estimator is exact for a pure sinusoid without noise. >It performs well in the presence of noise. >Here is the result of a test run: The sample count is 100 and the run size is 1000 The phase value is 0.785398 Errors are shown at 100x actual value Target Noise Level = 0.000 Freq Plet's Second Estimator ---- ------------- 3.0 -0.000 0.000 3.1 0.000 0.000 3.2 -0.000 0.000 3.3 0.000 0.000 3.4 0.000 0.000 3.5 0.000 0.000 3.6 0.000 0.000 3.7 0.000 0.000 3.8 -0.000 0.000 3.9 0.000 0.000 Target Noise Level = 0.001 Freq Plet's Second Estimator ---- ------------- 3.0 0.000 0.023 3.1 -0.001 0.030 3.2 0.000 0.072 3.3 -0.001 0.062 3.4 -0.000 0.019 3.5 -0.000 0.011 3.6 0.000 0.009 3.7 -0.000 0.008 3.8 -0.000 0.009 3.9 -0.000 0.012 Target Noise Level = 0.010 Freq Plet's Second Estimator ---- ------------- 3.0 0.001 0.229 3.1 -0.005 0.297 3.2 -0.014 0.715 3.3 -0.020 0.610 3.4 0.001 0.183 3.5 0.003 0.113 3.6 0.003 0.088 3.7 0.004 0.082 3.8 -0.001 0.096 3.9 0.004 0.117 Target Noise Level = 0.100 Freq Plet's Second Estimator ---- ------------- 3.0 -0.035 2.217 3.1 -0.183 3.099 3.2 -0.074 7.428 3.3 -0.408 6.296 3.4 -0.129 1.903 3.5 0.003 1.116 3.6 -0.006 0.865 3.7 -0.033 0.816 3.8 -0.046 0.918 3.9 -0.001 1.138 Michael
On Tue, 21 Feb 2017 15:30:50 +0100, Michael Plet <me@home.com> wrote:>On Tue, 21 Feb 2017 14:07:17 +0100, Michael Plet <me@home.com> wrote: > >>Hi Group >> >>This is a new estimator based on real and imaginary values of two DFT >>bins. >>The estimator is exact for a pure sinusoid without noise. >>It performs well in the presence of noise. >> > > >Here is the result of a test run: >Thank you to Cedron for letting me use his test program! Michael
