Hi Group This is a new estimator based on the magnitudes of three DFT bins. The estimator is exact for a pure sinusoid without noise. It performs well in the presence of noise. Let j be the index of the DFT bin with the largest magnitude. Let k=j-1 and i=j+1. Now let Ck = Cos(2*PI*k/N) Cj = Cos(2*PI*j/N) Ci = Cos(2*PI*i/N) Then the Cosine of the normalised angular frequency can be estimated as the root of the quadratic with the following coefficients: A = (Ck-Ci)*Mag[j]^2 - (Cj-Ci)*Mag[k]^2 - (Ck-Cj)*Mag[i]^2 B = - 2*( Cj*(Ck-Ci)*Mag[j]^2 - Ck*(Cj-Ci)*Mag[k]^2 - Ci*(Ck-Cj)*Mag[i]^2 ) C = Cj^2*(Ck-Ci)*Mag[j]^2 - Ck^2*(Cj-Ci)*Mag[k]^2 - Ci^2*(Ck-Cj)*Mag[i]^2 where Mag[] is the magnitude of X[]. The roots are Cw1 = (-B + Sqr(B^2-4*A*C))/(2*A) and Cw2 = (-B - Sqr(B^2-4*A*C))/(2*A) The correct answer, Cw, is the root that places the frequency between the two bins with the largest magnitudes. The normalised frequency is then Freq=(N/(2*PI))*Arccos(Cw) Below is the result of a test run. Regards, Michael Plet The sample count is 100 and the run size is 1000 The phase value is 0.785398 Errors are shown at 100x actual value Target Noise Level = 0.000 Freq Plet's Fifth Estimator ---- ------------- 3.0 -0.000 0.000 3.1 -0.000 0.000 3.2 -0.000 0.000 3.3 -0.000 0.000 3.4 -0.000 0.000 3.5 -0.000 0.000 3.6 0.000 0.000 3.7 0.000 0.000 3.8 -0.000 0.000 3.9 0.000 0.000 Target Noise Level = 0.001 Freq Plet's Fifth Estimator ---- ------------- 3.0 -0.019 0.007 3.1 -0.000 0.010 3.2 -0.000 0.010 3.3 -0.001 0.010 3.4 -0.000 0.011 3.5 0.001 0.013 3.6 0.000 0.015 3.7 -0.000 0.012 3.8 0.000 0.011 3.9 -0.000 0.010 Target Noise Level = 0.010 Freq Plet's Fifth Estimator ---- ------------- 3.0 -0.186 0.068 3.1 -0.002 0.094 3.2 0.001 0.095 3.3 -0.002 0.096 3.4 -0.003 0.108 3.5 0.004 0.132 3.6 -0.006 0.144 3.7 -0.006 0.122 3.8 -0.001 0.108 3.9 -0.007 0.102 Target Noise Level = 0.100 Freq Plet's Fifth Estimator ---- ------------- 3.0 -0.023 1.954 3.1 -0.890 4.490 3.2 0.057 0.931 3.3 0.076 0.981 3.4 0.063 1.048 3.5 0.060 1.341 3.6 -0.072 1.496 3.7 -0.072 1.212 3.8 -0.029 1.112 3.9 0.357 3.452 Thank you to Cedron for letting me use his test program.
Started by ●March 1, 2017
