I am beginner in DSP. Overall I am hoping to first learn time domain filter before heading to frequency domain. Are all types of IIR filter considered time domain ? How do i implement a band pass filter. Is there a good explanation on what is meant by priming ? -TryMe This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Novice to IIR filter
Started by ●June 6, 2005
Reply by ●June 7, 20052005-06-07
>I am beginner in DSP. Overall I am hoping to first learn time domain filter >before heading to frequency domain.There is currently a disagreement comp.dsp about whether filters are defined in time or in frequency domain. To get sensible answers, you should re-phrase your question: did you mean fast convolution vs. time domain convolution FIR filtering? Remember, this is only one side of the digital filtering coin (the other side is concerned with IIR filters). Read all about it in: http://www.dspguide.com>How do i implement a band pass filter.I think this is discussed in rbj's filter cookbook: http://musicdsp.org/files/Audio-EQ-Cookbook.txt> Is there a good explanation on what is meant by priming ?Perhaps http://www.psy.ohio-state.edu/psy312/priming.html ? Regards, Andor
Andor wrote:>>I am beginner in DSP. Overall I am hoping to first learn time domain filter >>before heading to frequency domain. > > > There is currently a disagreement comp.dsp about whether filters are > defined in time or in frequency domain. To get sensible answers, you > should re-phrase your question: did you mean fast convolution vs. time > domain convolution FIR filtering? Remember, this is only one side of > the digital filtering coin (the other side is concerned with IIR > filters). Read all about it in: > > http://www.dspguide.com > > >>How do i implement a band pass filter. > > > I think this is discussed in rbj's filter cookbook: > > http://musicdsp.org/files/Audio-EQ-Cookbook.txt > > >>Is there a good explanation on what is meant by priming ? > > > Perhaps http://www.psy.ohio-state.edu/psy312/priming.html ?Probably not. It probably is related to getting past the filter's initial transient. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
