optimal filters
Started by Tobin Fricke ●June 6, 2005
What is an optimal filter?
--tobin
A filter that is the best possible for its intended purpose, sometimes factoring in cost. What is an optimal motor vehicle? If you specify the purpose, you can have a more satisfying answer. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Well, it's this filter, see, and it's, like, optimal. :-) There are many different things that can be thought of as an optimal filter. In some areas, designing an FIR filter using a minimax criterion (e.g. using the Parks-McClellan / Remez exchange algorithm) is called an optimal filter. In other areas, a Kalman filter is described as an optimal filter because it minimizes the least squared error on the estimate of the state of the system under investigation. Do you have any specific thing in mind? More background information would probably generate a better answer. Ciao, Peter K.
Tobin Fricke wrote:
> What is an optimal filter? > > --tobin
What Jerry and Peter said, but also: Usually when you encounter the word "optimal" or "optimum" in the theoretical engineering literature it means there is a system (like a filter) that best meets some defined performance criteria. Usually the performance criteria are chosen to make the design of the optimal system possible, if not easy. So you'll see Kalman fiters which are optimal for (more or less) linear systems with additive Gaussian noise and some error-squared cost function, or the Parks-McClellan algorithm mentioned. What you _won't_ see, in general, are system models, noise models, or cost functions drawn from reality, because designing for an optimal system in such a case is darn near impossible. You will also find that in practice such "optimal" systems are not often implemented unless they address a problem that is either broad (such as PSK demodulators) or highly mission critical (such as Kalman filters in inertial nav systems), and even there you will find that the problem definition has been massaged so that it is approximated by one of the known optimal-system solutions. Why is this? Because managers often want to optimize for time to market, or the man-hours to design the system, and they're willing to live with lower performance and/or higher materials cost if they can keep down the number of hours spent by the costliest of engineers to make the "optimal" solution work. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
If your taking a class or reading a paper in statistical estimation or detection it is "optimal" with respect to some statistical criteria, like least squares, maximum likelihood, or trying to maximize the signal to noise ratio. The second chapter of volume 1 of Van Trees's, Detection, Estimation, and Modulation Theory, develops a number of optimal processors. The terms, processor and filter are somewhat interchangeable. One thing to note about optimal filters is that they are not necessarily something that can be actually constructed. Some people use the terms optimal and adaptive, interchangeably but this is not usually true. Adaptive filters often approximate optimal filters.
Tim wrote:
>Why is this? Because managers often want to optimize for time to >market, or the man-hours to design the system, and they're willing to >live with lower performance and/or higher materials cost if they can >keep down the number of hours spent by the costliest of engineers to >make the "optimal" solution work.
Very true words. In contradiction to Jerry, my definition of engineering (I guess managing as well - actually, the two are very related) is to solve a given problem optimally. The criterion for optimality (in my work) is usually a weighted and project dependent mix of - project specificiation tolerance, - development time, - software availability, extendability and re-usability, - code quality and efficiency, - hardware availability, - usable man power and skill. I guess the larger the projects and teams become, the more such terms have to be accounted for (I'm thinking about administrative issues etc.). If you come to think about how difficult such high dimensional optimization problems become (where some of the parameters might not be readily quantifiable), the amount and range of mismanagement comes as no surprise. Regards, Andor
Andor wrote:
> I guess the larger the projects and teams become, the more such terms > have to be accounted for (I'm thinking about administrative issues > etc.). If you come to think about how difficult such high dimensional > optimization problems become (where some of the parameters might not be > readily quantifiable), the amount and range of mismanagement comes as > no surprise.
Hence Carnegie-Mellon's introduction of CMM and CMMI. http://www.sei.cmu.edu/cmmi/adoption/cmmi-start.html It's not perfect, but it gives a much better set of management handles on an otherwise unmanageable process. Ciao, Peter K.
Andor wrote:
>Tim wrote: > > > >>Why is this? Because managers often want to optimize for time to >>market, or the man-hours to design the system, and they're willing to >>live with lower performance and/or higher materials cost if they can >>keep down the number of hours spent by the costliest of engineers to >>make the "optimal" solution work. >> >> > >Very true words. In contradiction to Jerry, my definition of >engineering (I guess managing as well - actually, the two are very >related) is to solve a given problem optimally. The criterion for >optimality (in my work) is usually a weighted and project dependent mix >of >- project specificiation tolerance, >- development time, >- software availability, extendability and re-usability, >- code quality and efficiency, >- hardware availability, >- usable man power and skill. > >I guess the larger the projects and teams become, the more such terms >have to be accounted for (I'm thinking about administrative issues >etc.). If you come to think about how difficult such high dimensional >optimization problems become (where some of the parameters might not be >readily quantifiable), the amount and range of mismanagement comes as >no surprise. > >Regards, >Andor > >
Companies aren't in business to make products. They are in business to make money. The optimal solution is the one which maximises profit. Never loose sight of that, or nothing in engineering makes any sense. A dirty troublesome half baked solution which hits a market window where people will pay a good price for a dirty troublesome half baked solution might be optimal..... provided the troublesome part doesn't bite too badly with costly recalls. Regards, Steve
Am Mon, 6 Jun 2005 13:00:05 -0700 schrieb Tobin Fricke:
Perhaps you mean "matched filter". In German literature, "Optimalfilter" is the same as "matched filter". Siegbert
Steve Underwood wrote:
> Andor wrote:
> >I guess the larger the projects and teams become, the more such terms > >have to be accounted for (I'm thinking about administrative issues > >etc.). If you come to think about how difficult such high dimensional > >optimization problems become (where some of the parameters might not be > >readily quantifiable), the amount and range of mismanagement comes as > >no surprise.
> Companies aren't in business to make products. They are in business to > make money. The optimal solution is the one which maximises profit. > Never loose sight of that, or nothing in engineering makes any sense.
Just the type of thinking that migh boost a short term profit with absolutely no thought to long term considerations (you just missed a whole set of parameters in the optimization problem :-). A company that sells a product where every shortcut was made to save money in the production and every marketing register pulled to increase the margin in sale might make more short term money in sales of that product. What about the customers? After a second look, they'll know what they bought and are likely to buy from another company the next time. No, I think a company has to make products which adhere to its standard / philosophy of production. This is the task of the "engineers" (in a wide sense of the word, anybody responsible in the core of the company). It is the task of the markting that potential customers are aware of the product and its values. Together they will make money, if both make a good job. Company's that work the other way around aren't places where I want to work (or make products which I want to buy, for that matter). You'll always loose in the long run.
> A dirty troublesome half baked solution which hits a market window where > people will pay a good price for a dirty troublesome half baked solution > might be optimal..... provided the troublesome part doesn't bite too > badly with costly recalls.
This of course works well if you have no competition. In an economically healthy environment, this philosophy won't make for a lasting company.
> > Regards, > Steve
Steve, I wonder: I know from some past posts of yours that are at least a seasoned engineer. What kind of business are you in? Don't answer if you don't want to. Regards, Andor
