I have a question about PLESIOCHROUNOUS re-sampling of audio. It was mentioned in another thread that simply deleting or repeating a sample now and then is a poor solution because it adds clicks. It was mentioned that linear interpolation is not ideal. Why? Because it adds noise? or distortion? I presume the "ideal" digital solution is to use a higher order interpolation algorithm. Is this correct? And here is my real question. I understand that re-sampling by converting the signal back to analog, reconstruction filtering, then re-sampling in a A/D is considered a kludgey. But assuming we didn't care that it was kludgey and the A/D and D/A are good, in terms of audio quality, how does the D/A > A/D method compare to the other methods mentioned above in terms of audio quality? Is the D/A >A/D method theoretically equivalent to a very high order digital interpolation? It seems we need to compare the operation of the digital interpolation filter vs the operation of the analog reconstruction filter. In practice, how complex of a digital interpolation filter would be needed to get audio performance that was as good or better than can be obtained using typical D/A > A/D. thanks Mark
PLESIOCHROUNOUS re-sampling of audio using D/A > A/D
Started by ●June 7, 2005
Reply by ●June 7, 20052005-06-07
Mark wrote:> I have a question about PLESIOCHROUNOUS re-sampling of audio. > > > It was mentioned in another thread that simply deleting or repeating a > sample now and then is a poor solution because it adds clicks. >Correct.> > It was mentioned that linear interpolation is not ideal. Why? Because > it adds noise? or distortion? >I assume because it wouldn't entirely get rid of the clicks (I haven't tried it, myself).> > I presume the "ideal" digital solution is to use a higher order > interpolation algorithm. Is this correct? >Yes.> > And here is my real question. I understand that re-sampling by > converting the signal back to analog, reconstruction filtering, then > re-sampling in a A/D is considered a kludgey. But assuming we didn't > care that it was kludgey and the A/D and D/A are good, in terms of > audio quality, how does the D/A > A/D method compare to the other > methods mentioned above in terms of audio quality? >In theory it could work very well, with the anti-aliasing filter being the limiting factor.> > Is the D/A >A/D method theoretically equivalent to a very high order > digital interpolation? It seems we need to compare the operation of > the digital interpolation filter vs the operation of the analog > reconstruction filter. >Yes.> > In practice, how complex of a digital interpolation filter would be > needed to get audio performance that was as good or better than can be > obtained using typical D/A > A/D. >That depends entirely on your antialiasing filter. With no filter you'd just be deleting or repeating samples _and_ adding noise and distortion.> > thanks > Mark >Look for "polyphase filtering". Your challenge in doing this comes in two parts: one, to filter the audio; and two to know how much phase to slip each sampling interval. You want to filter the audio to get a nice smooth transition without using lots of processor bandwidth -- this is where the polyphase filtering comes in. It'll let you introduce an arbitrary phase shift into the audio, ready for resampling. You also need to know how much phase to add or subtract at each sample interval to keep the two audio streams lined up. This is more difficult. If you knew the _exact_ ratio between the sample rates of the input and output stream it would be easy. Without this knowledge you'd probably want to have a nice deep FIFO, and you'd want to keep the FIFO depth servoed to 1/2 by adjusting your sampling rates. ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"Mark" <makolber@yahoo.com> wrote in message news:1118175450.502685.196710@o13g2000cwo.googlegroups.com...> I have a question about PLESIOCHROUNOUS re-sampling of audio. > > > It was mentioned in another thread that simply deleting or repeating a > sample now and then is a poor solution because it adds clicks.True, but if your sample rates are really close together in frequency, the click may only happen very rarely, so it _might_ be tolerable, depending on your audio signal and application. For example, if the click happened only once a day, maybe that would be OK. But in general, free-running sample rates aren't that close so the clicks are objectionable.> It was mentioned that linear interpolation is not ideal. Why? Because > it adds noise? or distortion?I guess you would technically call what it adds non-harmonic distortion. It also creates high frequency roll-off.> I presume the "ideal" digital solution is to use a higher order > interpolation algorithm. Is this correct?Yes.> And here is my real question. I understand that re-sampling by > converting the signal back to analog, reconstruction filtering, then > re-sampling in a A/D is considered a kludgey. But assuming we didn't > care that it was kludgey and the A/D and D/A are good, in terms of > audio quality, how does the D/A > A/D method compare to the other > methods mentioned above in terms of audio quality?High end audio A/D and D/A converters are capable of about 120dB dynamic range. Back to back in a system, you probably get 116dB dyanmic range or so. For many applications, that would be more that sufficient. (You haven't told us what your application is, so I can't comment on that.) The best all-digital solutions can obtain 140dB dynamic range.> Is the D/A >A/D method theoretically equivalent to a very high order > digital interpolation? It seems we need to compare the operation of > the digital interpolation filter vs the operation of the analog > reconstruction filter.Yes, they are equivalent. Both methods add some amount of noise, the D/A > A/D due to electrical noise, and the digital method due to finite numerical precision. Both have finite attenuation of alias frequencies.> In practice, how complex of a digital interpolation filter would be > needed to get audio performance that was as good or better than can be > obtained using typical D/A > A/D.It kind of depends on your sample rate and what portion of the available frequency spectrum your input signal operates (i.e. how much frequency headroom you have for a filter transition band). But in general, I think the dedicated audio sample rate converters use about an FIR filter in the range of 64 taps. Running at 48kHz, for example, that is trivial for today's DSPs. My question to you is if you have full access to designing hardware, then why don't you design in one of the many audio sample rate converter chips? Their interfaces look just like that of an A/D or D/A, but they are cheap, keep everything digital, and are generally easier to work with. Some manufacturers to look at are Analog Devices, Crystal/Cirrus, TI, and AKM. -- Jon Harris SPAM blocked e-mail address in use. Replace the ANIMAL with 7 to reply.
"Tim Wescott" <tim@seemywebsite.com> wrote in message news:11ac21srirdp41@corp.supernews.com...> Mark wrote: > > I have a question about PLESIOCHROUNOUS re-sampling of audio. > > > > > > It was mentioned in another thread that simply deleting or repeating a > > sample now and then is a poor solution because it adds clicks. > > > Correct. > > > > It was mentioned that linear interpolation is not ideal. Why? Because > > it adds noise? or distortion? > > > I assume because it wouldn't entirely get rid of the clicks (I haven't > tried it, myself).It does get rid of the clicks, but doesn't filter out the images very well. A linear interpolator is an FIR low-pass filter, just not a very good one! It "features" both poor pass-band flatness (rolls off too early) and lousy stop-band rejection (with big ugly sidelobes).> > And here is my real question. I understand that re-sampling by > > converting the signal back to analog, reconstruction filtering, then > > re-sampling in a A/D is considered a kludgey. But assuming we didn't > > care that it was kludgey and the A/D and D/A are good, in terms of > > audio quality, how does the D/A > A/D method compare to the other > > methods mentioned above in terms of audio quality? > > > In theory it could work very well, with the anti-aliasing filter being > the limiting factor. > > > > Is the D/A >A/D method theoretically equivalent to a very high order > > digital interpolation? It seems we need to compare the operation of > > the digital interpolation filter vs the operation of the analog > > reconstruction filter. > > > Yes. > > > > In practice, how complex of a digital interpolation filter would be > > needed to get audio performance that was as good or better than can be > > obtained using typical D/A > A/D. > > > That depends entirely on your antialiasing filter. With no filter you'd > just be deleting or repeating samples _and_ adding noise and distortion.(I am assuming an audio application.) Most of the audio converters are of the upsampling (or oversampling) variety, so a good deal of the anti-aliasing filter is digital and built into the chips. Generally, all you need to add on the outside is a simple 2 or 3 pole analog filter.
In <1118175450.502685.196710@o13g2000cwo.googlegroups.com> Mark wrote:> Is the D/A >A/D method theoretically equivalent to a very high order > digital interpolation? It seems we need to compare the operation of > the digital interpolation filter vs the operation of the analog > reconstruction filter.Yes, the usual sample rate conversion in the digital domain follows the same principles as doing into by converting to analog, resampling in the analog domain, and converting back to digital. For instance: To resample, you could play the digital output through a D/ A convertor and resample it with the A/D of another system running at the new rate: 48kHz system: 96kHz system: [ samples -> D/A -> 48KHz lowpass ] -> [ 96kHz lowpass -> A/D -> samples ] In the case of upsampling, as depicted, the second lowpass is superfluous (no need to lowpass at 96k when you've already bandlimited it to 48k with the first). So, we have [ D/A -> lowpass -> A/Dx2 ] that performs the conversion (the "x2" is there to remind us that the A/D runs 2x the D/A rate). This would be hard to do in memory, but we can observe that if we pull the lowpass out of the middle and move it to the end, we have the same thing. (Why? Because nothing is stopping us from using a D/A without a lowpass, except that we realize that we are getting aliased images of the bandlimited signal by doing so. Following it with the 48kHz lowpass gets rid of these images.) We now have D/A -> A/Dx2 -> 48kHz lowpass. "D/A -> A/Dx2" simplifies to "x2". So we really just need the doubling of sample rate, followed by a lowpass filter set to block everything over 48kHz. We can do both of those things in memory (yay!). OK, to double the samples, the most straight-forward way would be to keep the samples we have and put new ones in between. If we say that the samples represent the impulse train from which the original signal was ( or at least could have been) "discretized", then the in-between values are a constant--zero is the best choice for several obvious reasons-- things like avoiding overflow, DC offset in the signal, and also because it may let us dispense with multiplies for efficiency. (Don't make the mistake of thinking that the sampled data represents a staircase wave, and repeat the samples to fill in the blanks--samples represent impulses ( or can--please, no "they represent the amplitude of a sinc blah blah"); repeating samples gives a sinc-shaped frequency roll-off. Inserting zeros, on the other hand, maintains the spectrum exactly, with the addition of mirror-image aliasing. The low pass that follows removes the aliasing--that why they are sometimes referred to as anti-aliasing or anti-imaging filters.) For completeness, here's the view of downsampling: 96kHz system: 48kHz system: [ samples -> D/A -> 96KHz lowpass ] -> [ 48kHz lowpass -> A/D -> samples ] Here the 96kHz lowpass is superfluous, so it reduces to [ D/A -> 48kHz lowpass -> A/Dx0.5 ]. Since the 0.5 times factor for the sample rate throws away information, we need to reverse the order used for upsampling and reduce this to [ 48kHz lowpass -> D/A -> A/Dx0.5 ], or simply [ lowpass -> 0.5x rate ]. The "0.5 rate" conversion is performed by discarding every other sample. Linear interpolation for the upsampling, as others have mentioned, is simply a poor lowpass filter, one that rolls off the highs a bit, and aliases quite a bit due to the fat sidelobes. Linear interpolation can work fine when the signal is already oversampled, but in your case you most likely want to preserved the maximum bandwidth, so that won't be true. FIRs using windowed sinc (that is, the impulse response of a linear phase low pass filter) are a popular choice. In the end, the quality of the conversion depends on your algorithm and how much computational time you want to devote to each sample. It's easy to get far more accurate conversion computationally than to go the D/A->A/D route.
