question on DSP book by Rulph Chassaing
Started by Mon June 7, 2005
Hi All,
Recently I have purchased a book by Rulph Chassaing, "Digital Signal
Processing and Applications with the C6713 and C6416 DSK". The book comes
with a CD with all the codes which the book refers to.
My question is the entire book refer to C6713 and special file
"dskC6713_init.c", however there is no C6713 support on CD but there is
C6711 code on CD. Am I missing something?
Thanks,
Mona
Mona--
>Recently I have purchased a book by Rulph Chassaing, "Digital Signal >Processing and Applications with the C6713 and C6416 DSK". The book
comes
>with a CD with all the codes which the book refers to. >My question is the entire book refer to C6713 and special file >"dskC6713_init.c", however there is no C6713 support on CD but there is >C6711 code on CD. Am I missing something? >Thanks, >Mona
I have the same book and I believe this file(dsk6713_init.c) is very much present in the accompanying CD. So am not sure where the problem is, a misprinted CD may be? Dr.Chassaing did write an earlier book on C6711 so may be the CD's got mixed up. Never the less, post the C6711_init.c code , I will comment if the initializations are fine.If they are not I shall send you this file from my CD. ps:Dr.Chassaing, has btw, passed away recently. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
