tiger sharc memory
Started by retina June 8, 2005
does anybody know if there is any option i have to set when loading
data on a tiger sharc TS101? i am trying to load an image into memory
but it loads uncorrect values, while if i simulate the loaded values
are correct...
thanx
Hi,
How are you loading the data? What hardware do you have?
Jaime Andr�s Aranguren Cardona
jaac@sanjaac.com
SanJaaC Electronics
Soluciones en DSP
www.sanjaac.com
"retina" <danielelinaro@tiscali-dot-it.no-spam.invalid> escribi&#2013265923; en el
mensaje news:EPydnVVRLYGBhzrfRVn_vg@giganews.com...
> does anybody know if there is any option i have to set when loading > data on a tiger sharc TS101? i am trying to load an image into memory > but it loads uncorrect values, while if i simulate the loaded values > are correct... > > thanx >
hi, i am trying to fill the memory with the menu Memory -> Fill,
reading from an hexadecimal file. the DSP i am using is the
TigerSharc TS101 and the ide is VisualDSP++ 3.5...
thank you for your help...
