I watched this video about the sensitivity function, highly instructive, but at around 9 minutes, the author says that the maximum of the sensitivity function should be between 1.3 and 2. https://www.youtube.com/watch?v=BAWdZvF1O40 What's wrong with having a sensitivity less than 1.3 ? Regards
Sensitivity function - control theory
Started by ●July 25, 2017
Reply by ●July 28, 20172017-07-28
On Wednesday, July 26, 2017 at 3:12:32 AM UTC+12, benjamin....@gmail.com wrote:> I watched this video about the sensitivity function, highly instructive, but at around 9 minutes, the author says that the maximum of the sensitivity function should be between 1.3 and 2. > > https://www.youtube.com/watch?v=BAWdZvF1O40 > > What's wrong with having a sensitivity less than 1.3 ? > > RegardsI know part of that video is wrong. He says that the reason for a slower response is that the gain is lower at low frequencies. In fact speed of response is determined by unity gain crossover freq or bandwidth. Be careful of academics, they don't always understand real problems and are Matlab engineers
On Friday, July 28, 2017 at 6:19:19 PM UTC-7, gyans...@gmail.com wrote: (snip)> I know part of that video is wrong. He says that the > reason for a slower response is that the gain is lower > at low frequencies. In fact speed of response is > determined by unity gain crossover freq or bandwidth. > Be careful of academics, they don't always understand > real problems and are Matlab engineersOkay, but for simpler filters, the response will be monotonically increasing with frequency, so lower gain at low frequencies implies lower crossover. With a higher order filter, I suppose they are not so coupled.
Reply by ●July 29, 20172017-07-29
On Saturday, July 29, 2017 at 2:24:11 PM UTC+12, herrman...@gmail.com wrote:> On Friday, July 28, 2017 at 6:19:19 PM UTC-7, gyans...@gmail.com wrote: > > (snip) > > > I know part of that video is wrong. He says that the > > reason for a slower response is that the gain is lower > > at low frequencies. In fact speed of response is > > determined by unity gain crossover freq or bandwidth. > > Be careful of academics, they don't always understand > > real problems and are Matlab engineers > > Okay, but for simpler filters, the response will be monotonically > increasing with frequency, so lower gain at low frequencies implies > lower crossover. > > With a higher order filter, I suppose they are not so > coupled.Correct but don't make excuses for him. The gain at low frequencies is for disturbance rejection and good tracking. Distinct from the unity gain frequency which determines speed of response. I see all the time in textbooks going back to the 70s of authors saying a phase lag compensator slows a system down because it reduces teh gain at low frequencies. In fact you keep the bandwidth as high as is practical based on the physical limitations of the loop which again is never discussed (structural resonance or high frequency roll-off poles)
Reply by ●August 6, 20172017-08-06
On Tue, 25 Jul 2017 08:12:26 -0700, benjamin.couillard wrote:> I watched this video about the sensitivity function, highly instructive, > but at around 9 minutes, the author says that the maximum of the > sensitivity function should be between 1.3 and 2. > > https://www.youtube.com/watch?v=BAWdZvF1O40 > > What's wrong with having a sensitivity less than 1.3 ?Nothing per se., but in general* you're giving up bandwidth to go lower. Two is actually pretty high, unless you're sure of your system, and you don't have too much disturbances at that frequency. * any sweeping statement in control theory should be prefaced with "in general" -- probably even this one. -- www.wescottdesign.com
