On Wednesday, September 27, 2017 at 2:25:05 AM UTC-4, rickman wrote:> robert bristow-johnson wrote on 9/26/2017 10:35 PM:...> > > > x (c_0 + c_1 x^2 + c_2 x^4) (5 Mults) > > Maybe I'm missing something. Maybe it's the odd symmetry.yup. the approximated function is sin(pi/2 x), for -1 <= x <= +1, which has odd symmetry.> Are you saying > you don't need to calculate terms for x^2 and x^4 times appropriate > coefficients?yup.> What is the final expression you needed to calculate? The > last line shown would produce > > c_0 x + c_1 x^3 + c_2 x^5 >yup. and we want c_0 + c_1 + c_2 = 1 and we want c_0 + 3 c_1 + 5 c_2 = 0 with the last degree of freedom, you want to tweek, say, c_2, so that the 3rd harmonic and 5th harmonic have the same amplitude so as to minimize the maximum amplitude of a harmonic. turns out to be about -70 dB from the first harmonic. r b-j> Isn't that right? Or did you leave out the combining step that might produce > > c_0 + c_0 x + c_1 x^2 + c_1 x^3 + c_2 x^4 + c_2 x^5 > > > >> Viewed the eclipse at Wintercrest Farms, > >> on the centerline of totality since 1998 > > > > i was on the Cerulean-Hopkinsville Road in Kentucky. about 50 feet from the point of greatest eclipse. > > The buildup was pretty cool and totality was awesome although short but the > denouement was rather vapid. Maybe we didn't have enough eclipse dancers. > > -- > > Rick C > > Viewed the eclipse at Wintercrest Farms, > on the centerline of totality since 1998
Low-overhead high quality sine wave generation
Started by ●September 23, 2017
Reply by ●September 27, 20172017-09-27
Reply by ●October 1, 20172017-10-01
robert bristow-johnson wrote: > if you need a quadrature pair of oscillators, you can do > it pretty simply but there *is* that concern of the sinusoids > growing slowly (unstable) to dying off slowly. The point of this thread is that for a given period there are certain amplitudes which make the resonator perfectly stable. It is quite possible that one could forge a theory explaining a priori which amplitudes are correct, but in practice brute force scan finds them in a matter of minutes, so that's a fine kludge. Once you have the amplitude, creating a quadrature pair or arbitrarily more phases is just a matter of selecting a correct phase offset. > there is a pretty simple fix to that to make the amplitude constant. At least a few, e.g. resetting the oscillator after a full cycle. With my trick the oscillator effectively resets itself, so there is no need to do it manually. Best regards, Piotr
Reply by ●October 2, 20172017-10-02
On Sunday, October 1, 2017 at 6:35:23 AM UTC-4, Piotr Wyderski wrote:> > The point of this thread is that for a given period > there are certain amplitudes which make the resonator > perfectly stable. It is quite possible that one could > forge a theory explaining a priori which amplitudes > are correct, but in practice brute force scan finds > them in a matter of minutes, so that's a fine kludge. > > Once you have the amplitude, creating a quadrature pair > or arbitrarily more phases is just a matter of selecting > a correct phase offset.the way to do it for the simple resonator: y[n] = 2 cos(omega) y[n-1] - y[n-2] is to set the initial conditions, y[-1] and y[-2], correctly. if you want a given amplitude and phase (as well as a given frequency, omega) y[n] = A cos(omega n + phi) then y[-1] = A cos(-omega + phi) and y[-2] = A cos(-2 omega + phi) you must set these for your states y[n-1] and y[n-2] to get the specified amplitude and phase. r b-j> > there is a pretty simple fix to that to make the amplitude constant. > > At least a few, e.g. resetting the oscillator after a full cycle. > With my trick the oscillator effectively resets itself, so there > is no need to do it manually.no, with the quadrature oscillator, it is a way to adjust the coefficients up or down so that the square of the in-phase plus the square of the quadrature components add to a constant 1.
Reply by ●October 4, 20172017-10-04
On Sunday, September 24, 2017 at 11:03:41 AM UTC+13, radam...@gmail.com wrote:> I have used the following resonant filter oscillator structure for a long time. > > Integrator1 -> mult by sqrt(2-2cos(theta)) -> integrator2 -> mult by sqrt(2-2cos(theta)) -> back to integrator1 > > Where integrator1 is delayed by 1 sample and integrator2 has no delay. You start it with an impulse and the amplitude is stable forever, even when you use finite wordlengths. > However, if you change the frequency on-the-fly, the amplitude will shift. > I forget the name of this structure but I think it was published in the 60's > > BobJust two integrators with feedback gives zero phase margin, perfect oscillator. Doesn't work that well in analogue unless you are lucky. Often just saturates the output.
Reply by ●October 12, 20172017-10-12
On Saturday, September 23, 2017 at 4:08:09 AM UTC-5, Piotr Wyderski wrote:> Resonant filters are often used for this purpose, > but with a remark that they need some way of amplitude > control, because the numeric errors can make it > rise without control (gain > 1) or decay to 0 (gain < 1). > I don't know about you, but for me it was a great > surprise to discover that for certain "magic" values > of amplitude the error integrated over the entire > period is *exactly* 0, which means that the filter > begins the next period in exactly the same state it > started, so no AGC is needed. For example, for > omega=2*PI/1024 and 24-bit arithmetic the stable > amplitude value is 2163013 (with two_cos = 0x7fff62). > > I thought it might be an interesting result to share. > > Best regards, PiotrPiotr et al, You may find these to be of interest: http://www.claysturner.com/dsp/2nd_OSC_paper.pdf http://www.claysturner.com/dsp/digital_resonators.pdf At the end of the slides, I show how any simple discrete time oscillator can be used in a Goertzel application. This can much improve the precision of the results. Clay
On Wednesday, October 11, 2017 at 10:33:24 PM UTC-5, cl...@claysturner.com wrote:> You may find these to be of interest: > > http://www.claysturner.com/dsp/2nd_OSC_paper.pdf > > http://www.claysturner.com/dsp/digital_resonators.pdfClay, I haven't read the papers in detail, but from a quick look I get the impression that the oscillator frequencies are limited to a discrete set for which the step angle theta = 2PIf/fs can be exactly represented in the numerical format in use, or perhaps even more restrictively, for which cos(theta) or sin(theta) or sin(theta/2), and in some cases their squares, can be exactly represented. Is that correct? Greg
On Saturday, September 23, 2017 at 5:08:09 AM UTC-4, Piotr Wyderski wrote:> Resonant filters are often used for this purpose, > but with a remark that they need some way of amplitude > control, because the numeric errors can make it > rise without control (gain > 1) or decay to 0 (gain < 1). > I don't know about you, but for me it was a great > surprise to discover that for certain "magic" values > of amplitude the error integrated over the entire > period is *exactly* 0, which means that the filter > begins the next period in exactly the same state it > started, so no AGC is needed. For example, for > omega=2*PI/1024 and 24-bit arithmetic the stable > amplitude value is 2163013 (with two_cos = 0x7fff62). > > I thought it might be an interesting result to share. > > Best regards, PiotrThe Matlab code below implements the classic 2-integrator oscillator. No need for stabilization loops, no need to set frequencies to any magic numbers. The only drawback is that on-the-fly frequency changes will cause minor changes in amplitude. I inserted 10-bit quantization in the loop to show that resolution won't cause the amplitude to drift. Bob fs = 48e3; fosc = 1.037e3; % some random frequency not related to fs a = sqrt(2.0 - 2.0*cos(2*pi*fosc/fs)); numsamples = 1000000; integr1 = zeros(numsamples,1); integr2 = zeros(numsamples,1); integr1(1) = 1; % to start it off for k = 2:numsamples integr1(k) = integr1(k-1) + a*integr2(k-1); integr1(k) = (1/1024)*floor(1024*integr1(k)); % quantize to 10 bits to prove precision doesnt matter integr2(k) = integr2(k-1) - a*integr1(k); integr2(k) = (1/1024)*floor(1024*integr2(k)); % quantize to 10 bits to prove precision doesnt matter end figure; plot(integr1);
Reply by ●October 14, 20172017-10-14
Greg, True, you get limited by the precision of the coefs, but I never found that to be a big issue. Back when we were stuck with 8 bits, the coarseness was a concern, but by the 90s, I was using 56000 series DSPs with 24 bit coefs. With the driven oscillators in Goertzel analyzers, the topology was much more a concern. Clay
There are islands of stability where there can be a little hunting around the lsb or two. Definitely fun to explore. I see these days where one needs a large number of modulated subcarriers and an FFT is used. E.g. OFDM in LTE. I recall iDEN using 4 subcarriers, which weren't orthogonal, so my oscillators worked pretty well. Clay
