dear all, I am a computer enggr. doing masters. The final Project involves lot of DSP. The project is on audio classification. The initial step is to obtain mp3 audio stream. Is there any freely available library to obtain the audio data as floating point values. This would help to reduce work load. I have tried using the LibMpeg3 but to i am stuck trying to convert to library. It would be kind if someone replies to my query! Regards Yoshi This message was sent using the Comp.DSP web interface on www.DSPRelated.com
MP3 audio stream
Started by ●June 11, 2005
Reply by ●June 13, 20052005-06-13
>dear all, > >I am a computer enggr. doing masters. The final Project involves lot of >DSP. The project is on audio classification. The initial step is toobtain>mp3 audio stream. Is there any freely available library to obtain theaudio>data as floating point values. This would help to reduce work load. Ihave>tried using the LibMpeg3 but to i am stuck trying to convert to library. >It would be kind if someone replies to my query! > >Regards >Yoshi >I'm not sure I quite understand what you mean by get audio samples in floating point values!? If you have a library that can decode MP3, it will give you the PCM coded output. Assuming 16-bit mp3, you get WORD long data. You can cast them to get the floating point version, but then they'll all have 0 after the decimal point. Why do you need to convert to floating point? This message was sent using the Comp.DSP web interface on www.DSPRelated.com
