Power of State Space Analysis
Started by Kunal ●June 12, 2005
Hi!
Recently I was reading the book Digital Signal Processing by Proakis
and Manolakis, and came across their state space analysis of single
input, single output LTI systems.
The authors do mention that the real power of state space analysis can
be seen in the analysis of MIMO systems, but there's no example. Can
someone please give me a pointer (via an example) to such an analysis?
thanks,
Kunal
Kunal wrote:
> Hi! > > Recently I was reading the book Digital Signal Processing by Proakis > and Manolakis, and came across their state space analysis of single > input, single output LTI systems. > The authors do mention that the real power of state space analysis can > be seen in the analysis of MIMO systems, but there's no example. Can > someone please give me a pointer (via an example) to such an analysis?
Not that I have ever used state space analysis, let alone seen an example of MIMO systems (which basically translates to that I don't know what I'm talking about), but I wouldn't be surprised if the power lies in the compact notation of the system. A state-space model uses matrix-vector notation, where the matrix is very sparse in the case of a single-channel LTI system. If you take advantage of all that "free" storage space, you can incorporate the contributions from several inputs to one output. But I agree with you, it would be very interesting to actually see a state-space system in practice. Rune
Rune Allnor wrote:
> > Kunal wrote: > >>Hi! >> >>Recently I was reading the book Digital Signal Processing by Proakis >>and Manolakis, and came across their state space analysis of single >>input, single output LTI systems. >>The authors do mention that the real power of state space analysis can >>be seen in the analysis of MIMO systems, but there's no example. Can >>someone please give me a pointer (via an example) to such an analysis? > > > Not that I have ever used state space analysis, let alone seen an > example of MIMO systems (which basically translates to that I don't > know what I'm talking about), but I wouldn't be surprised if the > power lies in the compact notation of the system. > > A state-space model uses matrix-vector notation, where the > matrix is very sparse in the case of a single-channel LTI system. > If you take advantage of all that "free" storage space, you can > incorporate the contributions from several inputs to one output. > > But I agree with you, it would be very interesting to actually > see a state-space system in practice. > > Rune >
It's not just that it's compact (although that's not a bad thing), it also shows explicitly how things are tied together. If, for instance, I told you I had a single-input, two-output system with transfer functions: Y_2 (1-a)z Y_1 (1-a)(1-b)z --- = -------, --- = ------------. U z - a U (z-a)(z-b) You have no way of knowing if this is a two-state system where the first output is coupled to the second, or if this is a three-state system with two independent filters. Telling you that the system's state equations are [ a 1-a ] [ 0 ] x_n = [ ] x_{n-1} + [ ] u_n, [ 0 b ] [ 1-b ] y_n = x_n on the other hand, immediately tells you that it's a coupled system, and that you have the system states fully available for you to play with. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Kunal wrote:
> Hi! > > Recently I was reading the book Digital Signal Processing by Proakis > and Manolakis, and came across their state space analysis of single > input, single output LTI systems. > The authors do mention that the real power of state space analysis can > be seen in the analysis of MIMO systems, but there's no example. Can > someone please give me a pointer (via an example) to such an analysis? > > thanks, > Kunal >
I also find state-space representations to be very useful in nonlinear systems. They're handy when designing IIR filters, to make sure the states won't overflow for normal inputs, and to accurately predict how processor saturation will affect the states if they do. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott wrote:
> I also find state-space representations > to be very useful in nonlinear systems.
Can you give an example of what that would look like? -- Quidquid latine dictum sit, altum viditur.
Martin Eisenberg wrote:
> Tim Wescott wrote: > > >>I also find state-space representations >>to be very useful in nonlinear systems. > > > Can you give an example of what that would look like? >
The extended Kalman Filter
Stan's example of the extended Kalman filter is one. I tend to use it most in control systems that have one (or at most two) nonlinearities that dominate the large-signal response -- and then it's almost always actuator saturation. At any rate, the cannonical representation you'll find in textbooks for a nonlinear time-invariant system is: x_n = f(x_{n-1}) + g(u_n), y_n = h(x_{n-1}, u_n) where in general f, g and h are all nonlinear vector functions. This is all too wierd to actually handle in practice, so what I usually end up with is something like x_n = a * x_{n-1} + g(u_n), y_n = c * x_{n-1}, where everything is linear except for g, the reaction to the control signal, and even that is constrained to: { -F u_n <= -F g(u_n) = b * { u_n -F < u_n < F { F u_n >= F You can also represent the action of saturation of state variables by doing something similar with f(x) -- usually when I actually write that out I do it by representing f(x) as a * x with some additional text pointing out that x is limited. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"Kunal" <kunal.yadwadkar@gmail.com> wrote in message
news:1118583596.182276.87560@z14g2000cwz.googlegroups.com...
Well ..... I think it's fair to say that "state space analysis" in practice really means more than the notation conventions. Actually there are many forms it can take. Personally I like the form that explicitly shows each state as the state of an energy storage device such as the current in an inductor, the voltage on a capacitor, the velocity of a mass, the tension of a spring, etc. However, this form may not be the best for numerical reasons or computational efficiency - that's not my area of expertise. The implication of the notation is that the control system will be implemented via a digital computer. It very quickly gets to a stage where mere humans can't control complex systems (e.g. MIMO) but well-designed automatic control system can. One can envision the difference between driving a car from A to B and skippering a sailboat with the same objective. A sailboat is a good example of a MIMO system. The inputs are wind, current, rudder position, jib and main sail trim and position. The state is velocity. When the difference becomes even greater then an automated system makes a lot of sense. Ever try to sail a very small, light boat? How do you bring it about into the wind? How many rudder positions are necessary and why? (Hint: 4 if you start counting before the turn) Fred Fred
Fred Marshall wrote:
> Ever try to sail a very small, light boat? How do you bring it about into > the wind? How many rudder positions are necessary and why? (Hint: 4 if you > start counting before the turn)
That depends on the boat. My 10-foot catboat comes into the wind if you release the rudder and haul the sail amidships. With my 12-foot sloop, I can simply put the helm down and return it slowly. Of course if I hold it down until I'm smart into the wind, then some reverse rudder is needed to stop the rotation. (I can use the jib instead of the rudder, but that's a cheat. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message
news:r_WdnRJMc-k1LDDfRVn-sw@centurytel.net...
you
> start counting before the turn) > > Fred > > Fred > >
In control engineering circles it was all the fashion in the 1960s and 1970s to use state-space methods,Optinal control etc and many missile problems are well suited to this form of analysis ie MIMO systems. However, in the 1980s there was a return to polynomial and transfer function matrix methods at least outside of the US. Rimmer
