QUESTION Do you know where I might find tabulated coding gains for different coding schemes? For example BICM, LDPC, MLC, Turbo Codes etc. CONTEXT I have been working for a while on different coding schemes, so far I have studied block codes, convolutional codes and trellis coded modulation. I am interested in coding for the bandwidth limited channel, so coded modulation is of more use than standard binary codes, which typically have spectral efficiency less than 1 bit/s/Hz. The industry standard TCM seems to be "Pragmatic-TCM" introduced by Viterbi et al in 1989, however the coding gains for this scheme (which uses a convolutional code of constraint length K=7, together with set-partioning constellation mapping) are typically less than 3dB at BER = 10^-5. I understand 3dB is a significant gain in communications, but I was hoping to do better with some of the more modern coding schemes, mentioned above. Another question, do all of these modern schemes use iterative decoding? Does the delay incurred make these codes impractical for delay sensitive applications like voice communication?
Coding Gain?
Started by ●June 13, 2005
Reply by ●June 13, 20052005-06-13
On 13 Jun 2005 06:40:34 -0700, porterboy76@yahoo.com wrote:> >QUESTION >Do you know where I might find tabulated coding gains for different >coding schemes? For example BICM, LDPC, MLC, Turbo Codes etc.It's difficult to find a single source for such things since the gains depend on the specific code designs, which vary widely, as well as the channel models used to evaluate them.>CONTEXT >I have been working for a while on different coding schemes, so far I >have studied block codes, convolutional codes and trellis coded >modulation. I am interested in coding for the bandwidth limited >channel, so coded modulation is of more use than standard binary codes, >which typically have spectral efficiency less than 1 bit/s/Hz. The >industry standard TCM seems to be "Pragmatic-TCM" introduced by Viterbi >et al in 1989, however the coding gains for this scheme (which uses a >convolutional code of constraint length K=7, together with >set-partioning constellation mapping) are typically less than 3dB at >BER = 10^-5. I understand 3dB is a significant gain in communications, >but I was hoping to do better with some of the more modern coding >schemes, mentioned above. Another question, do all of these modern >schemes use iterative decoding?Capacity-approaching codes are all iteratively decoded. If you can get by with gain less than that, then there are lots of other alternatives, like concatenated CC-RS, etc.> Does the delay incurred make these >codes impractical for delay sensitive applications like voice >communication?It can, but it depends on the application. If the bit rate is high enough then the delay relative to the voice channel is often small enough. Alternatively, you may be able to use small block sizes, but that often degrades the gain of the code. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Reply by ●June 14, 20052005-06-14
Thanks Eric...> If the bit rate is high > enough then the delay relative to the voice channel is often small > enough.Oh, I hadn't thought of that. So, let me get this right... The decoding delay might be of the order of a few thousand bits, but if we have a high information rate, say 3Mb/s, then a few thousand bits is not such a long time, and can be less than the tolerable delay for voice comms... is that it? I was going to avoid iterative decoding altogether, but maybe I should consider it if that is the case... PB
On 14 Jun 2005 00:39:42 -0700, porterboy76@yahoo.com wrote:>Thanks Eric... > >> If the bit rate is high >> enough then the delay relative to the voice channel is often small >> enough. > >Oh, I hadn't thought of that. So, let me get this right... >The decoding delay might be of the order of a few thousand bits, but if >we have a high information rate, say 3Mb/s, then a few thousand bits is >not such a long time, and can be less than the tolerable delay for >voice comms... is that it? I was going to avoid iterative decoding >altogether, but maybe I should consider it if that is the case...That's pretty much it assuming the decoder has to decode the entire stream, i.e., run at the aggregate rate rather than the voice rate. Even with a low-rate system it is still possible to design the decoder such that it runs much faster than the data rate in order to reduce the latency. Since iteratively decoded codes are always block codes the latency is associated with the decode time after reception of the last bit in the block. If you just clock the bejeezus out of the thing the latency will be low, but the complexity and power consumption may be higher than you'd like to live with. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
