Hi all, I have received a transmission which consists of a series of PN sequences. I recorded at 8*10^6 SPS (8 MSPS) and wish to perform a matched filter on it. The transmission binary sequence is 1*10^6 bits long and I have just been informed that it was transmitted at a rate of 1,016,118.24682 bits/sec which seems like a very strange chip rate to pick but unfortunately this is beyond my control. So my question is: how can I accurately match the sample rates to be able to perform a matched filter? If I use MATLABs rat function then I can get upsample/downsample ratios which are very large requiring a lot of processing power and anyway this only approximates a solution as over time the error becomes large and the matched filter looses sync. Here I'm trying to upsample the 'template' to match the recorded signal: [n, k] = rat(8e6 / 1016118.24682, 1.e-9); % gives k=23743, n=186931 resamped_template = resample(template, n, k ); Any help appreciated! Enda
Matched filter chiprate issue
Started by ●February 14, 2018
Reply by ●February 14, 20182018-02-14
Enda McKenna <endatheworld@gmail.com> wrote:>So my question is: how can I accurately match the sample rates to be >able to perform a matched filter?I'd try a four point Lagrangian interpolator, which in Matlab may be called a "cubic" interpolator. Steve
Reply by ●February 15, 20182018-02-15
On 14.02.2018 20:11, Steve Pope wrote:> Enda McKenna <endatheworld@gmail.com> wrote: > >> So my question is: how can I accurately match the sample rates to be >> able to perform a matched filter? > > I'd try a four point Lagrangian interpolator, which in Matlab > may be called a "cubic" interpolator. > > Steve >There are two possible solutions, either of which would work. One, as Steve has suggested, involves the use of a Lagrangian interpolator. If you need more context, a more detailed discussion can be found e.g. in F.M. Gardner's 1993 article "Interpolation in digital modems" (which consists of Part I and Part II). The second option is to use an arbitrary rate polyphase filter. IMO, it's best described in a book "Multirate Signal Processing" by Harris. Alternatively, you can go for the 2001 article "Multirate digital filters for symbol timing synchronization in software defined radios" by Harris and Rice. The difference between the two options is that the Lagrangian interpolator would be typically followed by a matched filter. While you can incorporate the matcher filter inside a polyphase filter, so the latter has the potential to be a two-in-one option. Gene
Reply by ●February 19, 20182018-02-19
On Thursday, 15 February 2018 10:26:27 UTC, Evgeny Filatov wrote:> On 14.02.2018 20:11, Steve Pope wrote: > > Enda McKenna wrote: > > > >> So my question is: how can I accurately match the sample rates to be > >> able to perform a matched filter? > > > > I'd try a four point Lagrangian interpolator, which in Matlab > > may be called a "cubic" interpolator. > > > > Steve > > > > There are two possible solutions, either of which would work. One, as > Steve has suggested, involves the use of a Lagrangian interpolator. If > you need more context, a more detailed discussion can be found e.g. in > F.M. Gardner's 1993 article "Interpolation in digital modems" (which > consists of Part I and Part II). > > The second option is to use an arbitrary rate polyphase filter. IMO, > it's best described in a book "Multirate Signal Processing" by Harris. > Alternatively, you can go for the 2001 article "Multirate digital > filters for symbol timing synchronization in software defined radios" by > Harris and Rice. > > The difference between the two options is that the Lagrangian > interpolator would be typically followed by a matched filter. While you > can incorporate the matcher filter inside a polyphase filter, so the > latter has the potential to be a two-in-one option. > > GeneThank you for the advice. I'm trying to implement a cubic spline interpolator in Matlab but with limited results so far. I'm finding that the fractional chipping rate will put the sequence out of sync within a few sequence lengths since obviously it's impossible to have a fraction of a sample leaving me with the possibility of having to insert a 'leap' sample periodically... Really struggling with this! Enda
On 19.02.2018 17:12, Enda McKenna wrote:> > Thank you for the advice. I'm trying to implement a cubic spline > interpolator in Matlab but with limited results so far. I'm finding > that the fractional chipping rate will put the sequence out of sync > within a few sequence lengths since obviously it's impossible to have > a fraction of a sample leaving me with the possibility of having to > insert a 'leap' sample periodically... Really struggling with this! > > Enda >You are welcome! Of course, the output sequence will have fewer or more samples than the input sequence. If you do your own implementation, you will have to account for that. One way to think of it is to get a counter which increments with F_in/F_out for each output sample, where F_in is the input sampling frequency and F_out is the output sampling frequency. Then the integer part of the counter will point to the first sample of the set of four input samples, and the fractional part of the counter will have the meaning the point in the [0; 1) interval (positioned between some two fixed samples within the set of four input samples) for which you calculate the interpolated value. Three considerations: (1) Before you do your own implementation, learn to use the interp1 function of Matlab: https://www.mathworks.com/help/matlab/ref/interp1.html Even if it doesn't account for all your needs, at the very least it helps to be able to test your own implementation against the existing one. (2) You might want to implement a linear interpolator before you do a more complicated design. And actually it will provide quite good results for your particular problem (i.e., oversampling factor of about 8). (3) Arbitrary rate interpolators are a bit hard to grasp, and studying the literature really helps. Reading the references I provided takes a fair amount of time and effort, but it's worth it. HTH, Gene
Enda McKenna <endatheworld@gmail.com> wrote:>Thank you for the advice. I'm trying to implement a cubic spline >interpolator in Matlab but with limited results so far. I'm finding that >the fractional chipping rate will put the sequence out of sync within a >few sequence lengths since obviously it's impossible to have a fraction >of a sample leaving me with the possibility of having to insert a 'leap' >sample periodically... Really struggling with this!It can be made to work. One visualization is that you feed the interpolator's input stream into a circular buffer. Each time you feed a new input value into the buffer, check whether the buffer now contains the set of four consecutive values needed to form one or more new outputs. Emit those new outputs to an output stream. Then discard the oldest value in the buffer. This is analogous to how you'd have to do it in hardware. Steve
Reply by ●February 21, 20182018-02-21
spope384@gmail.com (Steve Pope) writes:> Enda McKenna <endatheworld@gmail.com> wrote: > >>Thank you for the advice. I'm trying to implement a cubic spline >>interpolator in Matlab but with limited results so far. I'm finding that >>the fractional chipping rate will put the sequence out of sync within a >>few sequence lengths since obviously it's impossible to have a fraction >>of a sample leaving me with the possibility of having to insert a 'leap' >>sample periodically... Really struggling with this! > > It can be made to work. > > One visualization is that you feed the interpolator's input stream > into a circular buffer. Each time you feed a new input value into the > buffer, check whether the buffer now contains the set of four > consecutive values needed to form one or more new outputs. Emit those > new outputs to an output stream. Then discard the oldest value > in the buffer. > > This is analogous to how you'd have to do it in hardware.Perhaps this was already mentioned in the thread, but couldn't you simply resample the sync sequence at the operational sample rate? You could do the converse: resample the operational sample rate to match the sync sequence, but that would be computationally stupid since the sinc resampling only has to be done one at system design time. -- Randy Yates, Embedded Linux Developer Garner Underground, Inc. http://www.garnerundergroundinc.com
Randy Yates <randyy@garnerundergroundinc.com> wrote:>spope384@gmail.com (Steve Pope) writes: > >> Enda McKenna <endatheworld@gmail.com> wrote: >> >>>Thank you for the advice. I'm trying to implement a cubic spline >>>interpolator in Matlab but with limited results so far. I'm finding that >>>the fractional chipping rate will put the sequence out of sync within a >>>few sequence lengths since obviously it's impossible to have a fraction >>>of a sample leaving me with the possibility of having to insert a 'leap' >>>sample periodically... Really struggling with this! >> >> It can be made to work. >> >> One visualization is that you feed the interpolator's input stream >> into a circular buffer. Each time you feed a new input value into the >> buffer, check whether the buffer now contains the set of four >> consecutive values needed to form one or more new outputs. Emit those >> new outputs to an output stream. Then discard the oldest value >> in the buffer.>> This is analogous to how you'd have to do it in hardware.>Perhaps this was already mentioned in the thread, but couldn't you >simply resample the sync sequence at the operational sample rate?Are you saying you could save computation by resampling the sync pattern and not the data stream? The answer is yes, sometimes, but this is not how the OP posed their question. Whether this would work well depends on scenario. Steve
Reply by ●February 23, 20182018-02-23
spope384@gmail.com (Steve Pope) writes:> Randy Yates <randyy@garnerundergroundinc.com> wrote: > >>spope384@gmail.com (Steve Pope) writes: >> >>> Enda McKenna <endatheworld@gmail.com> wrote: >>> >>>>Thank you for the advice. I'm trying to implement a cubic spline >>>>interpolator in Matlab but with limited results so far. I'm finding that >>>>the fractional chipping rate will put the sequence out of sync within a >>>>few sequence lengths since obviously it's impossible to have a fraction >>>>of a sample leaving me with the possibility of having to insert a 'leap' >>>>sample periodically... Really struggling with this! >>> >>> It can be made to work. >>> >>> One visualization is that you feed the interpolator's input stream >>> into a circular buffer. Each time you feed a new input value into the >>> buffer, check whether the buffer now contains the set of four >>> consecutive values needed to form one or more new outputs. Emit those >>> new outputs to an output stream. Then discard the oldest value >>> in the buffer. > >>> This is analogous to how you'd have to do it in hardware. > >>Perhaps this was already mentioned in the thread, but couldn't you >>simply resample the sync sequence at the operational sample rate? > > Are you saying you could save computation by resampling the sync > pattern and not the data stream?Yes, exactly.> The answer is yes, sometimes, but this is not how the OP posed > their question.Understood.> Whether this would work well depends on scenario.All I can think of is that the "operational" sample rate must be higher than the original sample rate. Are there other issues? -- Randy Yates, Embedded Linux Developer Garner Underground, Inc. http://www.garnerundergroundinc.com
