Hi, I am looking at a Goldcode transmitted from a LEO satellite and want to perform a matched filter on it. The problem is there is a significant amount of doppler (20kHz) which degrades the performance of the matched filter significantly. If I have a chunk of this signal (quadrature sampled) what would be a good approach to negate the affects of the doppler? Any input will be much appreciated. Thanks. ZZ
Doppler correction, SatCom channel.
Started by ●February 20, 2018
Reply by ●February 20, 20182018-02-20
On Tuesday, February 20, 2018 at 10:22:31 AM UTC-5, Zoul Zubazz wrote:> Hi, > > I am looking at a Goldcode transmitted from a LEO satellite and want to perform a matched filter on it. The problem is there is a significant amount of doppler (20kHz) which degrades the performance of the matched filter significantly. > > If I have a chunk of this signal (quadrature sampled) what would be a good approach to negate the affects of the doppler? > > Any input will be much appreciated. Thanks. > > ZZThis might be a dumb question, but don't you have a way of getting the LEO's orbit parameters?
Reply by ●February 21, 20182018-02-21
On Tuesday, February 20, 2018 at 10:22:31 AM UTC-5, Zoul Zubazz wrote:> I am looking at a Goldcode transmitted from a LEO satellite and want > to perform a matched filter on it. The problem is there is a significant > amount of doppler (20kHz) which degrades the performance of the matched > filter significantly.> If I have a chunk of this signal (quadrature sampled) what would be a > good approach to negate the affects of the doppler?You can try a suitably large set of possible doppler values and see which one best allows extraction of the signal. (Yes, it is sometimes done this way.) Steve
On 21.02.2018 7:27, Steve Pope wrote:> On Tuesday, February 20, 2018 at 10:22:31 AM UTC-5, Zoul Zubazz wrote: > >> I am looking at a Goldcode transmitted from a LEO satellite and want >> to perform a matched filter on it. The problem is there is a significant >> amount of doppler (20kHz) which degrades the performance of the matched >> filter significantly. > >> If I have a chunk of this signal (quadrature sampled) what would be a >> good approach to negate the affects of the doppler? > > You can try a suitably large set of possible doppler values and see which > one best allows extraction of the signal. > > (Yes, it is sometimes done this way.) > > Steve >You might want to read Chapter 5 of Kaplan's "Understanding GPS" -- "Satellite signal acquisition, tracking and data demodulation". It might be useful or not, depending on the specifics. Gene.
