Multiple ADCs and aliasing
Started by Piotr Wyderski February 23, 2018
Hi Randy.
Have you seen the "interleaved ADC" webinar at:
http://hosted.verticalresponse.com/1940905/876581eed7/544320746/1e257ed5fb/
[-Rick Lyons-]
Hi Randy,
W dniu 27.02.2018 o 03:47, Randy Yates pisze:
> rr <rr@somwhere.com> writes:
>> No, Piotr question is about TWO 1 Msps ADCs converting 1 MHz bandwith >> signal in two phase, interleave mode: >> "... >> I have two 1MHz ADCs and would like to interleave them >> by a half of the sampling cycle in order to get a single >> ADC with effective sampling frequency of 2MHz ... " > > I am clear on Piotr's question. The point is, if you consider one of the > two ADCs (either one) independent of the other, it will (in general) > experience aliasing. This was actually part of Piotr's original > question, and Piotr is correct on this point.
yes, of course, if we sample 1 MHz bandwidth analog signal at 1 Msps rate, the sample stream will contain aliasing, but dependency has no meaning, because of too low sampling FREQUENCY, and single ADC is independent (making them dependent has no sense). Regular time intervals between samples counts only. Each of two sample streams from dependent ADCs experience aliasing, but not together. Actually, the aliasing problem in Piotr case is solved by two synchronized S/H blocks, sampling at Fs/2 frequency BUT having analog input BW Fs/2 minimum, AND sampling clock jitter tuned to maximum frequency of input signal. Two S/H circuits must be used to give each of ADCs enough time (1us) for measurement (conversion). In case of two millions such a S/H circuits there is the possibility to convert this signal by two million people equipped with voltmeters. ;-) With regards, Roman Rumian
r.lyons@ieee.org writes:
> Hi Randy. > Have you seen the "interleaved ADC" webinar at > http://hosted.verticalresponse.com/1940905/876581eed7/544320746/1e257ed5fb/ > > [-Rick-]
Hey Rick! Not until now. I'll watch when I get a chance. Those guys look like they would know what they're doing.. -- Randy Yates, Embedded Linux Developer Garner Underground, Inc. http://www.garnerundergroundinc.com
> Hi Randy, > > W dniu 27.02.2018 o&nbsp;03:47, Randy Yates pisze: >> rr <rr@somwhere.com> writes: > (...) >>> No, Piotr question is about TWO 1 Msps ADCs converting 1 MHz bandwith >>> signal in two phase, interleave mode: >>> "... >>> I have two 1MHz ADCs and would like to interleave them >>> by a half of the sampling cycle in order to get a single >>> ADC with effective sampling frequency of 2MHz ... " >> >> I am clear on Piotr's question. The point is, if you consider one of the >> two ADCs (either one) independent of the other, it will (in general) >> experience aliasing. This was actually part of Piotr's original >> question, and Piotr is correct on this point. > > yes, of course, if we sample 1 MHz bandwidth analog signal at 1 Msps > rate, the sample stream will contain aliasing, but dependency has no > meaning, because of too low sampling FREQUENCY, and single ADC is > independent (making them dependent has no sense). Regular time > intervals between samples counts only. Each of two sample streams from > dependent ADCs experience aliasing, but not together.
Roman, In my opinion you are overlooking the most relevent portion of Piotr's question, which was also the question I had in my mind. All my life I've had it drilled it into my head, unconditionally, that once aliasing occurs, it is irreversible. Until now I don't ever remember anyone teaching me, "Aliasing can be reversed in certain cases." Contributing (in my opinion) to the confusion in this thread is that some of the answers (including yours, and including the Analog Devices article that was cited) mix theoretical with practical considerations. Again, I think Piotr's first and foremost question was, "How can aliasing in an ADC ever be undone?" The answer to that question is purely theoretical and has absolutely nothing to do with practical considerations. Further contributing (in my opinion) to the confusion in this thread is that nowhere (until my answer describing the modulation model of sampling) was a clear theoretical explanation provided. I'm not saying practical considerations aren't important. I'm just saying I don't think they answer Piotr's most fundamental question, and I know they didn't answer mine. In any case, I appreciate the discussion. I learned something here and that is very valuable. -- Randy Yates, Embedded Linux Developer Garner Underground, Inc. http://www.garnerundergroundinc.com
On 27.2.18 17:48, Randy Yates wrote:
> rr <rr@somwhere.com> writes: > >> Hi Randy, >> >> W dniu 27.02.2018 o&nbsp;03:47, Randy Yates pisze: >>> rr <rr@somwhere.com> writes: >> (...) >>>> No, Piotr question is about TWO 1 Msps ADCs converting 1 MHz bandwith >>>> signal in two phase, interleave mode: >>>> "... >>>> I have two 1MHz ADCs and would like to interleave them >>>> by a half of the sampling cycle in order to get a single >>>> ADC with effective sampling frequency of 2MHz ... " >>> >>> I am clear on Piotr's question. The point is, if you consider one of the >>> two ADCs (either one) independent of the other, it will (in general) >>> experience aliasing. This was actually part of Piotr's original >>> question, and Piotr is correct on this point. >> >> yes, of course, if we sample 1 MHz bandwidth analog signal at 1 Msps >> rate, the sample stream will contain aliasing, but dependency has no >> meaning, because of too low sampling FREQUENCY, and single ADC is >> independent (making them dependent has no sense). Regular time >> intervals between samples counts only. Each of two sample streams from >> dependent ADCs experience aliasing, but not together. > > Roman, > > In my opinion you are overlooking the most relevent portion of > Piotr's question, which was also the question I had in my mind. > > All my life I've had it drilled it into my head, unconditionally, that > once aliasing occurs, it is irreversible. Until now I don't ever > remember anyone teaching me, "Aliasing can be reversed in certain > cases." > > Contributing (in my opinion) to the confusion in this thread is that > some of the answers (including yours, and including the Analog Devices > article that was cited) mix theoretical with practical considerations. > Again, I think Piotr's first and foremost question was, "How can > aliasing in an ADC ever be undone?" The answer to that question is > purely theoretical and has absolutely nothing to do with practical > considerations. > > Further contributing (in my opinion) to the confusion in this thread is > that nowhere (until my answer describing the modulation model of > sampling) was a clear theoretical explanation provided. > > I'm not saying practical considerations aren't important. I'm just > saying I don't think they answer Piotr's most fundamental question, and > I know they didn't answer mine. > > In any case, I appreciate the discussion. I learned something here and > that is very valuable.
If the ADC samplings are properly staggered and the resulting number stream interleaved, how does the result differ from one sampled at twice the original rate? -- -TV
Hi Randy,
W dniu 27.02.2018 o&nbsp;16:48, Randy Yates pisze:
So, let's look at this question again: "...But the aliasing properties of the data stream will be as if the signal was sampled at 1MHz because the ADCs are independent blocks and don't influence each other, right? " My answer to his question is: no, because Piotr overlooked what he assumed: "I have two 1MHz ADCs and would like to interleave them by a half of the sampling cycle in order to get a single ADC with effective sampling frequency of 2MHz ..." This means, that he thinks about using exactly the same sampling frequency (1MHz; not one 1MHz and second 1.0000000001 Mhz or anything else different from 1 MHz; hm, well, this may also mean that 1MHz is just one of ADC chip parameters ...), and they will be interleaved by half of the sampling cycle (it is possible with the same sampling clock ONLY), so, the obvious conclusion is that ADCs work SYNCHRONOUSLY, in STRONGLY DEPENDENT manner.
Yes, that is true, but we have no aliasing in combined, interleaved sample stream. :-) You have probably overlooked, that we can reverse this point of view to situation, where correctly sampled signal can be seen as two DEPENDENT streams od even and odd samples. What could we say about them and aliasing ?
My answer is: aliasing can be undone by replenishment of missing samples provided by the second ADC (working in synchronous, interleaved way). Hm, this is very practical consideration for me and probably for Piotr, and also for companies manufacturing chips like mentioned ADC12DJ3200, but can understand that for you this is absolutely theoretical, interesting question. Thank you, Roman
Tauno Voipio <tauno.voipio@notused.fi.invalid> writes:
> On 27.2.18 17:48, Randy Yates wrote: >> rr <rr@somwhere.com> writes: >> >>> Hi Randy, >>> >>> W dniu 27.02.2018 o&nbsp;03:47, Randy Yates pisze: >>>> rr <rr@somwhere.com> writes: >>> (...) >>>>> No, Piotr question is about TWO 1 Msps ADCs converting 1 MHz bandwith >>>>> signal in two phase, interleave mode: >>>>> "... >>>>> I have two 1MHz ADCs and would like to interleave them >>>>> by a half of the sampling cycle in order to get a single >>>>> ADC with effective sampling frequency of 2MHz ... " >>>> >>>> I am clear on Piotr's question. The point is, if you consider one of the >>>> two ADCs (either one) independent of the other, it will (in general) >>>> experience aliasing. This was actually part of Piotr's original >>>> question, and Piotr is correct on this point. >>> >>> yes, of course, if we sample 1 MHz bandwidth analog signal at 1 Msps >>> rate, the sample stream will contain aliasing, but dependency has no >>> meaning, because of too low sampling FREQUENCY, and single ADC is >>> independent (making them dependent has no sense). Regular time >>> intervals between samples counts only. Each of two sample streams from >>> dependent ADCs experience aliasing, but not together. >> >> Roman, >> >> In my opinion you are overlooking the most relevent portion of >> Piotr's question, which was also the question I had in my mind. >> >> All my life I've had it drilled it into my head, unconditionally, that >> once aliasing occurs, it is irreversible. Until now I don't ever >> remember anyone teaching me, "Aliasing can be reversed in certain >> cases." >> >> Contributing (in my opinion) to the confusion in this thread is that >> some of the answers (including yours, and including the Analog Devices >> article that was cited) mix theoretical with practical considerations. >> Again, I think Piotr's first and foremost question was, "How can >> aliasing in an ADC ever be undone?" The answer to that question is >> purely theoretical and has absolutely nothing to do with practical >> considerations. >> >> Further contributing (in my opinion) to the confusion in this thread is >> that nowhere (until my answer describing the modulation model of >> sampling) was a clear theoretical explanation provided. >> >> I'm not saying practical considerations aren't important. I'm just >> saying I don't think they answer Piotr's most fundamental question, and >> I know they didn't answer mine. >> >> In any case, I appreciate the discussion. I learned something here and >> that is very valuable. > > > If the ADC samplings are properly staggered and the resulting > number stream interleaved, how does the result differ from one > sampled at twice the original rate?
It does not differ. The question in my mind was, why didn't the aliasing in the individual converters screw things up? Until you can prove analytically how this aliasing is "undone", you're waving your hands, no matter how intuitive it may seem from other points-of-view. Intuition is not proof! If it is true, it should be provable. Analogy: Did Shannon/Nyquist merely assert that the input bandwidth to a single, real (time) quantizer running at a rate of Fs quantizations per second must be less than Fs / 2? Or did they prove why it must be so?!? All the responses I've seen so far have been faith-based. -- Randy Yates, Embedded Linux Developer Garner Underground, Inc. http://www.garnerundergroundinc.com
> [...] > Yes, that is true, but we have no aliasing in combined, interleaved > sample stream. :-)
That is an assertion, not a proof. For all the time you've spent discussing this, you could have easily come up with the proof. It took me about a half an hour. -- Randy Yates, Embedded Linux Developer Garner Underground, Inc. http://www.garnerundergroundinc.com
> >All my life I've had it drilled it into my head, unconditionally, that >once aliasing occurs, it is irreversible. Until now I don't ever >remember anyone teaching me, "Aliasing can be reversed in certain >cases." [..] >Further contributing (in my opinion) to the confusion in this thread is >that nowhere (until my answer describing the modulation model of >sampling) was a clear theoretical explanation provided.
Aliasing occurs when sampling. This signal is being sampled at 2 Ms/sec. You can take a sampled signal (2 Ms/sec in this case) and sub-sample it (into two 1 Ms/sec signals), and those individual sub-sampled signals certainly exhibit additional aliasing. But the total signal, sampled at 2 Ms/sec, does not exhibit this additional aliasing. How this sampled signal is formatted and presented to the next layer of the system has no theoretical aspects, so there is no such thing as a further theoretical explanation for the lack of additional aliasing... you get the aliasing that is associated with the sampling you have performed. If you throw out one of the two streams in this case, you get additional aliasing; if you keep them both, you do not. Steve
spope384@gmail.com (Steve Pope) writes:
> Randy Yates <randyy@garnerundergroundinc.com> wrote: > >>In my opinion you are overlooking the most relevent portion of > >> >>All my life I've had it drilled it into my head, unconditionally, that >>once aliasing occurs, it is irreversible. Until now I don't ever >>remember anyone teaching me, "Aliasing can be reversed in certain >>cases." [..] >>Further contributing (in my opinion) to the confusion in this thread is >>that nowhere (until my answer describing the modulation model of >>sampling) was a clear theoretical explanation provided. > > Aliasing occurs when sampling. This signal is being sampled at 2 > Ms/sec.
Steve, That is an unproven assertion. The standard treatment of sampling theory involves the use of a SINGLE quantizer sampling at Fs samples per second with Fs/2 bandwidth. It almost always involves the use of a (single) infinite impulse train, modulating the input signal with that, etc. Creating an alternate sampling architecture which uses two quantizers and claiming it is equivalent to sampling at twice the sample rate requires a theoretical basis to establish its validity. Otherwise it's just an assertion. -- Randy Yates, Embedded Linux Developer Garner Underground, Inc. http://www.garnerundergroundinc.com
