i have been reading a lot of messages on spectral subtraction and how it is useful in reducing background noise. i have tried this in matlab and i was highly successful in attenuating the noise from a sound file. but when i tried this with another sound file instead of noise the signal was not attenuated at all. in fact both of the signals could be heard perfectly well; and i can say pretty positively without any degradation in the secondary signal at all. i would like to know whether this method of spectral subtraction is applicable for other signals too other than noise. if yes than how; what extra processing of the signal is required. if no then why so. if someone can shed light on this problem i would be really thankful to you. thank you
spectral subtraction of signals other than noise
Started by ●June 16, 2005
Reply by ●June 16, 20052005-06-16
"adj" <arshdeepjindal@gmail.com> writes:> i have been reading a lot of messages on spectral subtraction and how > it is useful in reducing background noise. i have tried this in matlab > and i was highly successful in attenuating the noise from a sound > file. but when i tried this with another sound file instead of noise > the signal was not attenuated at all. in fact both of the signals > could be heard perfectly well; and i can say pretty positively without > any degradation in the secondary signal at all. i would like to know > whether this method of spectral subtraction is applicable for other > signals too other than noise. if yes than how; what extra processing of > the signal is required. if no then why so. if someone can shed light on > this problem i would be really thankful to you. thank youSo if you've implemented it in matlab then you must have had an estimate of the noise signal for the case when it worked? Or was this provided to you? What did you use for the second case? Do you think your noise estimate in the second case was a good estimate of the true noise? What were the relative powers at different frequencies of the two sigals in both cases? Tony
Reply by ●June 17, 20052005-06-17
<tony.nospam@nospam.tonyRobinson.com> wrote in message news:877jgu3vha.fsf@tonyRobinson.com...> "adj" <arshdeepjindal@gmail.com> writes: > > > i have been reading a lot of messages on spectral subtraction and how > > it is useful in reducing background noise. i have tried this in matlab > > and i was highly successful in attenuating the noise from a sound > > file. but when i tried this with another sound file instead of noise > > the signal was not attenuated at all. in fact both of the signals > > could be heard perfectly well; and i can say pretty positively without > > any degradation in the secondary signal at all. i would like to know > > whether this method of spectral subtraction is applicable for other > > signals too other than noise. if yes than how; what extra processing of > > the signal is required. if no then why so. if someone can shed light on > > this problem i would be really thankful to you. thank you > > So if you've implemented it in matlab then you must have had an estimate > of the noise signal for the case when it worked? Or was this provided > to you? What did you use for the second case? Do you think your noise > estimate in the second case was a good estimate of the true noise? What > were the relative powers at different frequencies of the two sigals in > both cases? > > > Tony >It wont work if the noise is rapidly non-stationary like two speakers - also you need a good voice activity detector and thats hard to find for some applications. Rimmer
Reply by ●June 18, 20052005-06-18
for the first case i assumed the noise to be additive and uncorrelated. also i assumed that it affected the speech signal over the entire spectrum uniformely. this assumption is pretty much valid for most experimental testing. if an estimate if the noise signal had been provided to me i would have used multi band spectral subtraction. but i believe that would have only been a very slight improvement over the present results.
Reply by ●June 19, 20052005-06-19
adj wrote:> i have been reading a lot of messages on spectral subtraction and how > it is useful in reducing background noise. i have tried this in matlab > and i was highly successful in attenuating the noise from a sound > file.Exactly how did you do this? Was there already noise in the data that you subtracted? Did you generate noise, add it to the sound file, and then subtract it again?> but when i tried this with another sound file instead of noise > the signal was not attenuated at all. in fact both of the signals > could be heard perfectly well; and i can say pretty positively without > any degradation in the secondary signal at all. i would like to know > whether this method of spectral subtraction is applicable for other > signals too other than noise.You have got a couple of steps ahead of me: I would like to start with establishing that the technique can be used at all. The problem is that noise is only known in terms of its power spectrum. The phase information is not available, so the exact shape of the noise is not known in time domain. So if you have a noise signal that has amplitude n(t) at time = t, you could as well subtract an amplitude of -n(t), giving a total of 2(t) contribution from the noise.> if yes than how; what extra processing of > the signal is required. if no then why so.Waveforms tend to vary too much. Even if the free-space envelope of a radar signal is known and recieved undegraded, the exact waveform of the radar signal can not be known, since it depends on the total travelled distance of the pulse. Again, phase information is the culprit.> if someone can shed light on > this problem i would be really thankful to you. thank youIt's all about finding robust ways of dealing with data outside computer simulations. Rune
Reply by ●June 21, 20052005-06-21
hi rune. since you've mentioned phase information i have a question regarding that. i took the fft of a sound file. to its phase part i added a random phase. and for the magnitude part i subtracted the magnitude of the spectrum of noise which in magnitude was very less compared to the original sound. i then reconstructed the sound file thus edited by taking ifft. all this processing was done in matlab. now after taking ifft i was expecting a real signal which i should ideally get. but i am getting a complex signal. please explain this irregularity to me. thanks
adj wrote:> hi rune. since you've mentioned phase information i have a question > regarding that. i took the fft of a sound file. to its phase part i > added a random phase. and for the magnitude part i subtracted the > magnitude of the spectrum of noise which in magnitude was very less > compared to the original sound. i then reconstructed the sound file > thus edited by taking ifft. all this processing was done in matlab.It beats me how you were "highly successful" at noise reduction using this method.> now > after taking ifft i was expecting a real signal which i should ideally > get. but i am getting a complex signal. please explain this > irregularity to me. thanksYou destroyed the conjugate complex symmetry of the real input signal in frequency domain when you added the random phase noise, resulting in a complex output sequence. You should try to find some literature on how noise reduction via spectral subtraction works (what you describe is more or less the opposite of noise reduction), and why it usually doesn't work well. Regads, Andor
i'm sorry for the confusion. my last post about phase addition was not about noise reduction. it was something which i had tried differently. i have read in literature that eeven if we add a random phase to the fft of a signal, if the original was real so will the ifft of the new(phase added) signal be. i am not observing this. this was my question. please don not confuse it with the spectral subtraction and noise reduction part. i know the choice of post could have been in a new topic.
Reply by ●June 22, 20052005-06-22
adj wrote:> hi rune. since you've mentioned phase information i have a question > regarding that. i took the fft of a sound file. to its phase part i > added a random phase.Which is equivalent to adding noise.> and for the magnitude part i subtracted the > magnitude of the spectrum of noise which in magnitude was very less > compared to the original sound.How do you know you subtracted only noise? Do you have refernce data to verify the noise spectrum?> i then reconstructed the sound file > thus edited by taking ifft. all this processing was done in matlab. now > after taking ifft i was expecting a real signal which i should ideally > get. but i am getting a complex signal. please explain this > irregularity to me. thanksAndor has already provided one answer. The other answer is that any output of the IFFT is complex-valued, even if it represents a real-valued signal. Try xx=ifft(fft(x)); for some real-valued vector x. Check out the magnitude of the imaginary component. If you did the transform correctly, the magnitudes ought to be on the order << 1e-12. Now try xxx=real(ifft(fft(x))); and see the difference. Rune
