Idea exploration 1.1 - Inertia based angular sensor.
Started by Kris Neot June 16, 2005
This idea is used to serve my old idea of "Image stabilization by means of
software.".
I was aware that it was difficult to find angular sensor that can run at
1MS/s. I will
have a cubic enclosure, two perpendicular walls are made of small/fast image
sensors.
I use a hanging ball and a laser to shine upon it. The image sensors will
detect the
exact location of the ball (hopefully 1000 times a second). When the
enclosure(thus
camera body) shakes, the ball will remain inert for that short period, Thus
the image
sensors can give a reading of the balls location and calculate the
displacement.
Does this idea work? :)
Kris Neot wrote:
> This idea is used to serve my old idea of "Image stabilization by means of > software.". > I was aware that it was difficult to find angular sensor that can run at
Just a quick point - is this discussion really relevant to: a) comp.arch.fpga b) comp.arch.embedded c) comp.dsp d) sci.image.processing ? Maybe if you were making the application work on an fpga with an embedded processor, using a DSP algorithm based on images of a small ball, but... Jeremy
> Just a quick point - is this discussion really relevant to: > a) comp.arch.fpga > b) comp.arch.embedded > c) comp.dsp > d) sci.image.processing > ? >
More groups, more replies. :)
"Jeremy Stringer" <jeremy@_NO_MORE_SPAM_endace.com> wrote in message
news:42b23c62$1@clear.net.nz...
> Kris Neot wrote: > > This idea is used to serve my old idea of "Image stabilization by means
of
> > software.". > > I was aware that it was difficult to find angular sensor that can run at > > Just a quick point - is this discussion really relevant to: > a) comp.arch.fpga > b) comp.arch.embedded > c) comp.dsp > d) sci.image.processing > ? > > Maybe if you were making the application work on an fpga with an > embedded processor, using a DSP algorithm based on images of a small > ball, but... > > Jeremy
Yes and piss off and winge elsewhere... Rimmer
In a crosspost apparently to cover all the bases, specifically to
alt.sci.physics,comp.arch.embedded,comp.arch.fpga,comp.dsp,sci.image.processing,
On Fri, 17 Jun 2005 10:07:50 +0800, "Kris Neot"
<Kris.Neot@hotmail.com> wrote:
>This idea is used to serve my old idea of "Image stabilization by means of >software.".
What does that mean? You want to generate a signal that represents a change in the position (orthogonal or angular? both?), and use this to translate a digital real-time video image from a digital camera sensor to make it appear stable?
>I was aware that it was difficult to find angular sensor that can run at >1MS/s. I will >have a cubic enclosure, two perpendicular walls are made of small/fast image >sensors. >I use a hanging ball and a laser to shine upon it. The image sensors will >detect the >exact location of the ball (hopefully 1000 times a second). When the >enclosure(thus >camera body) shakes, the ball will remain inert for that short period, Thus >the image >sensors can give a reading of the balls location and calculate the >displacement.
This will give positional displacement, not angular displacement. Is that what you want? Also, I can think of several other ways of doing this. I'd probably use these things: http://www.analog.com/en/cat/0,2878,764,00.html
Yes, probably, sort of. ----- http://www.mindspring.com/~benbradley
Ben Bradley wrote:
> Kris Neot wrote:
>>Does this idea work? :) > > > Yes, probably, sort of.
Wanna bet? There are six motion axes. How many will the ball track? Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
