Hi Jim, My problem is the SHARC, not the TigerSHARC. The TS permits debug using it's external bus. Anyway it looks like you have nice tools. Thanks, Luiz Carlos
SHARC debug
Started by ●June 20, 2005
Reply by ●June 23, 20052005-06-23
Hi Ron, We sell boards based on ADSP-218x. But it is running out of gas! We are looking for a floating point DSP replacement. Well, even BlackFin doesn't have a host port! I'll try again to get more information from ADI. Thanks, Luiz Carlos.
To Luiz: I think that if you were heading for the TS, but are also considering the ADSP-2136x, it's because you need some big computational power for your application. Couldn't a ADSP-21161 work for you? It has a host port, allowing you to debug it without the need of diving deep into the JTAG internals. I think that Ron's suggestion of the emulator + remote access software (NetMeeting, VNC) could be a good option for you. Ask Dr. Mike Rosing, maybe he could give you good advice, since his company (BeastRider, http://www.beastrider.com/) makes low cost JTAG debuggers for SHARC, 2106x and 2116x, though. Anyway, they are experienced with what you need. To Ron Huizen, Jim Thomas: Thanks for coming in, and commenting from your experience. Regards, -- ------------------------------ Jaime Andr�s Aranguren Cardona jaac@sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com "Ron Huizen" <rhuizen@bittware.com> escribi� en el mensaje news:11bleaunlns9odb@corp.supernews.com...> We (BittWare) use the ADI emulators for JTAG debug, so have no need to try > to figure out and run the JTAG directly. We also have our own "secret" > method for doing VDSP debug sessions over the PCI bus to our boards. > However, all of our processors (2106x, 2116x, TS101, TS201) have host > ports we can use for this. > > You should contact Analog Devices and see if you can sign whatever > licenses and NDAs they may require to get access to this information. It > may be much easier, however, to look at something like their USB > emulators, and plug this into your board and the PC its in (you did say it > had a PCI interface) assuming you're running Windows) and then just use > some remote Windows access software (like NetMeeting). > > We support remote VDSP debug sessions over TCP/IP, but it requires one of > our PCI based boards to be in a target system (Windows, Linux, VxWorks) > running our remote server to provide access to the DSPs. > > ---- > Ron Huizen > BittWare > > <oen_no_spam@yahoo.com.br> wrote in message > news:1119527763.620352.259310@f14g2000cwb.googlegroups.com... >> Bittware, Danville, anyone? >> Is this "top secret" information? >> >> Luiz Carlos
oen_no_spam@yahoo.com.br wrote in news:1119538390.774704.45300 @z14g2000cwz.googlegroups.com:> Hi Ron, > > We sell boards based on ADSP-218x. But it is running out of gas! We are > looking for a floating point DSP replacement. Well, even BlackFin > doesn't have a host port! > I'll try again to get more information from ADI. > > Thanks, > > Luiz Carlos. >Our boards certainly have support for an external emulator and we also provide EZ-Kit Style debuggers (under license from ADI) on some of our boards. In both cases, we treat the JTAG port as a black box so we don't know any more than you about the specifics. We also provide the capablility to upload code into flash on our boards using USB or RS-232 using a proprietary loader that we wrote. This doesn't provide debug support but it does work well for production programming and upgrades. We have customers using our dspblok 21261sm with its FPGA for a host port interface. Depending on you application, SPI, SPORTs, USB or RS-232 are also possibilities with our dspstak boards. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Reply by ●June 24, 20052005-06-24
Hi Jaime, Yes, a lot of processing power, besides you never have enough! The ADSP-21161N runs at 100MHz, has 1Mbit of on chip SRAM and costs $26. As we need the processing power of one or more Tigers, a cluster of ADSP-21161s would be very expensive. The ADSP-21363 runs at 333MHz, has 3 Mbits of internal RAM and costs $17. But lacks the host port. I hate TI's assembly language! What will I do? :) As I said, we sell boards, so it's not practical to bundle an external debugger. Luiz Carlos
