Hi all. I am in the process of producing a pile of programs and documents in various stages of evolution: - Some documents are finished reports, or almost finished reports that only need proofreading. - Others are in slightly less evolved stages, missing a chapter or two, or missing data demonstrations. - Other still are merely "post-it notes", containing key word reminders of some idea I had once upon a time, or the outline of some report-to-be. - Some programs are self-contained while others are merely tests of program syntax. - Etc. As of yet, I am capable of keeping track of what's going on, but I will not be for much longer. Hence I need some sort of system for document/version control. Do anybody out there have experience with these sorts of systems? Are they suitable for small companies, or only for the multinasional mastodonts? Do anybody have suggestions to what version control systems to check out? Rune
OT?: Document/source code version control
Started by ●June 22, 2005
Reply by ●June 22, 20052005-06-22
Rune Allnor wrote:> > Hi all. > > I am in the process of producing a pile of programs and > documents in various stages of evolution: > > - Some documents are finished reports, or almost finished > reports that only need proofreading. > - Others are in slightly less evolved stages, missing a > chapter or two, or missing data demonstrations. > - Other still are merely "post-it notes", containing key > word reminders of some idea I had once upon a time, > or the outline of some report-to-be. > - Some programs are self-contained while others are > merely tests of program syntax. > - Etc. > > As of yet, I am capable of keeping track of what's going on, > but I will not be for much longer. Hence I need some sort > of system for document/version control. > > Do anybody out there have experience with these sorts of > systems?I have used CVS, SVN, Perforce and GNU Arch.> Are they suitable for small companies, or only > for the multinasional mastodonts?I use Perforce at work and think it is horrid. CVS is probably a little too limited and old fashioned to recommend it nowadays. I use GNU Arch for all my own stuff because I think its better than SVN. However GNU Arch does not currently play nicely with windows so if you want to use it with windows clients, SVN is probably a better bet.> Do anybody have suggestions > to what version control systems to check out?If you only use Unix/Linux then my recomendation is GNU Arch. If you need to use windows then SVN is a better bet. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ Saying Python is easier than C++ is like saying that turning a light switch on or off is easier than operating a nuclear reactor.
Rune Allnor wrote:> Hi all. > > I am in the process of producing a pile of programs and > documents in various stages of evolution: > > - Some documents are finished reports, or almost finished > reports that only need proofreading. > - Others are in slightly less evolved stages, missing a > chapter or two, or missing data demonstrations. > - Other still are merely "post-it notes", containing key > word reminders of some idea I had once upon a time, > or the outline of some report-to-be. > - Some programs are self-contained while others are > merely tests of program syntax. > - Etc. > > As of yet, I am capable of keeping track of what's going on, > but I will not be for much longer. Hence I need some sort > of system for document/version control. > > Do anybody out there have experience with these sorts of > systems? Are they suitable for small companies, or only > for the multinasional mastodonts? Do anybody have suggestions > to what version control systems to check out? > > RuneI cannot urge you strongly enough to use a version control system, not just for code but also for documents. The VCS will see them all as files that have changes to be tracked. If you ever want to get back an old version of a file then a VCS is for you. I use WinCVS at work. We were a small company with around 10 software engineers at the time so needed something cheap - this is free. Since we settled on CVS a number of years ago there are more free VCS systems available. I have heard very good reports of SUBVERSION and its windows incarnation TortoiseSVN (also both free). I am intending to use this at home for my own projects but have not set it up yet. There has been a thread in the last couple of weeks on comp.arch.embedded that asked the same question as you are asking. Ian http://www.satamatics.com
Hi Rune, Rune Allnor wrote:> Do anybody out there have experience with these sorts of > systems? Are they suitable for small companies, or only > for the multinasional mastodonts? Do anybody have suggestions > to what version control systems to check out?Well, a first (free) approximation would be to use CVS for version control. It's free and relatively painless to install (https://www.cvshome.org/). As you also have notes etc. I'd actually recommend that you extend things a little (a lot?) further and go with something like a Wiki (e.g. http://moinmoin.wikiwikiweb.de/). This is more of a pain to set up (Apache as a web-server, Python as the implementation language), but it has the benefit of being MUCH easier to use (IMHO, YMMV, Objects in the mirror are larger than they appear, etc, etc, etc). These are definitely NOT just for multinationals. I used RCS (similar to CVS) to keep my thesis documents revision-controlled after a minor accident with Chapter 3. Ciao, Peter K.
Rune Allnor wrote:> Hi all. > > I am in the process of producing a pile of programs and > documents in various stages of evolution: > > - Some documents are finished reports, or almost finished > reports that only need proofreading. > - Others are in slightly less evolved stages, missing a > chapter or two, or missing data demonstrations. > - Other still are merely "post-it notes", containing key > word reminders of some idea I had once upon a time, > or the outline of some report-to-be. > - Some programs are self-contained while others are > merely tests of program syntax. > - Etc. > > As of yet, I am capable of keeping track of what's going on, > but I will not be for much longer. Hence I need some sort > of system for document/version control. > > Do anybody out there have experience with these sorts of > systems? Are they suitable for small companies, or only > for the multinasional mastodonts? Do anybody have suggestions > to what version control systems to check out? > > Rune >Version control _everything_. If you're a unix user it should come with RCS, Linux should come with RCS and quite possibly CVS. I use RCS under Cygwin because it's just me, but if I ever do anything that involves more than 5 files at a time I'll learn how to use CVS or another free VCS. In production environments you should have a build document that allows you to start with the VCS archives and possibly a well-guarded CD from your tool vendor, go buy a computer at Radio Shack or Sears, install software, and build code that's bit-for-bit exactly like what you built the first time. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●June 23, 20052005-06-23
Rune Allnor wrote:> [..] Hence I need some sort > of system for document/version control.If your documents are all based on ASCII (meaning not binary formats like Word Documents) you can try cvs. I use it for almost everything. If you have also non ASCII documents try subversion. Since this is more or less the successor to cvs I recommend to start with subversion anyway. bye Andreas -- Andreas Hnnebeck | email: ah@despammed.com ----- privat ---- | www : http://www.huennebeck-online.de Fax/Anrufbeantworter: 0721/151-284301 GPG-Key: http://www.huennebeck-online.de/public_keys/andreas.asc PGP-Key: http://www.huennebeck-online.de/public_keys/pgp_andreas.asc
porterboy76@yahoo.com wrote:> RCS is really easy to use, and it comes free with Linux. > $.02Which is it then.... free or $0.02 ?
Andreas Huennebeck wrote:> Rune Allnor wrote: > > > [..] Hence I need some sort > > of system for document/version control. > > If your documents are all based on ASCII (meaning > not binary formats like Word Documents) you > can try cvs. I use it for almost everything. > > If you have also non ASCII documents try subversion. > Since this is more or less the successor to cvs I > recommend to start with subversion anyway. > > bye > Andreas > -- > Andreas Hnnebeck | email: ah@despammed.com > ----- privat ---- | www : http://www.huennebeck-online.de > Fax/Anrufbeantworter: 0721/151-284301 > GPG-Key: http://www.huennebeck-online.de/public_keys/andreas.asc > PGP-Key: http://www.huennebeck-online.de/public_keys/pgp_andreas.ascI use CVS every day (WinCVS) and this is perfectly well able to control/store binary files as well as ascii source/text. Ian
"Ian" <ian_okey@hotmail.com> wrote in message news:1119529228.219259.249890@f14g2000cwb.googlegroups.com...> > Andreas Huennebeck wrote: > > Rune Allnor wrote: > > > > > [..] Hence I need some sort > > > of system for document/version control. > > > > If your documents are all based on ASCII (meaning > > not binary formats like Word Documents) you > > can try cvs. I use it for almost everything. > > > > If you have also non ASCII documents try subversion. > > Since this is more or less the successor to cvs I > > recommend to start with subversion anyway. > > > > bye > > Andreas > > -- > > Andreas Hnnebeck | email: ah@despammed.com > > ----- privat ---- | www : http://www.huennebeck-online.de > > Fax/Anrufbeantworter: 0721/151-284301 > > GPG-Key: http://www.huennebeck-online.de/public_keys/andreas.asc > > PGP-Key: http://www.huennebeck-online.de/public_keys/pgp_andreas.asc > > I use CVS every day (WinCVS) and this is perfectly well able to > control/store binary files as well as ascii source/text.Yes, most version control systems can store binary files just fine, but what you lose is the ability to easily view differences graphically (say in a MS Word document) like you can with text files. That may be a significant limitation for some.
