"Jon Harris" <jon_harrisTIGER@hotmail.com> wrote in message news:11blqsqeiop1b88@corp.supernews.com... <snip>> Yes, most version control systems can store binary files just fine, butwhat you> lose is the ability to easily view differences graphically (say in a MSWord> document) like you can with text files. That may be a significantlimitation> for some.Do you know of any that allows viewing differences graphically esp. of MS Word documents? I've used VSS and I know it doesn't...just treats it as a binary. Cheers Bhaskar
OT?: Document/source code version control
Started by ●June 22, 2005
Reply by ●June 23, 20052005-06-23
Bhaskar-->Do you know of any that allows viewing differences graphically esp. ofMS>Word documents? >I've used VSS and I know it doesn't...just treats it as a binary. > >Cheers >BhaskarI use scootersoftware.com's Beyond Compare software to diff my word files graphically.It is very useful. I get by without vcf,because of this and some highly imaginative folder structures that I create. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
"Bhaskar Thiagarajan" <bhaskart@deja.com> wrote in message news:42baf9d4$0$18643$14726298@news.sunsite.dk...> "Jon Harris" <jon_harrisTIGER@hotmail.com> wrote in message > news:11blqsqeiop1b88@corp.supernews.com... > <snip> > > Yes, most version control systems can store binary files just fine, but > what you > > lose is the ability to easily view differences graphically (say in a MS > Word > > document) like you can with text files. That may be a significant > limitation > > for some. > > Do you know of any that allows viewing differences graphically esp. of MS > Word documents? > I've used VSS and I know it doesn't...just treats it as a binary.Sorry, I don't. I would imagine it would be a tough task for the VS system--a special case for every format it supported, plus multiple versions of the MS formats.
"Jon Harris" <jon_harrisTIGER@hotmail.com> wrote in message news:11bm31cegvjuc0d@corp.supernews.com...> "Bhaskar Thiagarajan" <bhaskart@deja.com> wrote in message > news:42baf9d4$0$18643$14726298@news.sunsite.dk... > > "Jon Harris" <jon_harrisTIGER@hotmail.com> wrote in message > > news:11blqsqeiop1b88@corp.supernews.com... > > <snip> > > > Yes, most version control systems can store binary files just fine,but> > what you > > > lose is the ability to easily view differences graphically (say in aMS> > Word > > > document) like you can with text files. That may be a significant > > limitation > > > for some. > > > > Do you know of any that allows viewing differences graphically esp. ofMS> > Word documents? > > I've used VSS and I know it doesn't...just treats it as a binary. > > Sorry, I don't. I would imagine it would be a tough task for the VSsystem--a> special case for every format it supported, plus multiple versions of theMS> formats.That's what I figured...so I've never bothered searching for something like this actively. My current group might be interested in a new version control tool (we use PVCS now!!), so I thought it might be a good time to scout around. I'm just starting to try out the new TortoiseSVN. I thought that someone might have a plug-in/piggy back module on an existing system that addresses Word docs specifically....but expecting something specific for MS stuff from the open source community is rather optimistic :-) I'll probably look at Booshan's scootersoftware suggestion and see what it had to offer. Cheers Bhaskar
Reply by ●June 24, 20052005-06-24
bhooshaniyer wrote:> Bhaskar-- > > >Do you know of any that allows viewing differences graphically esp. of > MS > >Word documents? > >I've used VSS and I know it doesn't...just treats it as a binary. > > > >Cheers > >Bhaskar > > I use scootersoftware.com's Beyond Compare software to diff my word files > graphically.It is very useful. I get by without vcf,because of this and > some highly imaginative folder structures that I create. > > --BhooshanOuch.... If you are anything like me, that folder structure would look something along the lines of project1/misc /utils /tmp /var Which is probably the reason why I need some sort of document control... Rune
Bhaskar Thiagarajan wrote:> ...but expecting something specific for MS stuff from > the open source community is rather optimistic :-)I don't think it's OVERLY optimistic though. OpenOffice.org and Samba are two counter examples. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 In theory, theory and practice are the same, but in practice, they're not
Tim Wescott <tim@seemywebsite.com> writes:> Rune Allnor wrote: > >> Hi all. >> I am in the process of producing a pile of programs and >> documents in various stages of evolution: >> - Some documents are finished reports, or almost finished >> reports that only need proofreading. >> - Others are in slightly less evolved stages, missing a >> chapter or two, or missing data demonstrations. >> - Other still are merely "post-it notes", containing key >> word reminders of some idea I had once upon a time, >> or the outline of some report-to-be. >> - Some programs are self-contained while others are >> merely tests of program syntax. >> - Etc. >> As of yet, I am capable of keeping track of what's going on, >> but I will not be for much longer. Hence I need some sort >> of system for document/version control. >> Do anybody out there have experience with these sorts of >> systems? Are they suitable for small companies, or only >> for the multinasional mastodonts? Do anybody have suggestions >> to what version control systems to check out? >> RuneRune, subversion (svn) seems to be a new upcoming version control system, aiming to replace the RCS/CVS systems. --Randy -- % Randy Yates % "I met someone who looks alot like you, %% Fuquay-Varina, NC % she does the things you do, %%% 919-577-9882 % but she is an IBM." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
"bhooshaniyer" <bhooshaniyer@gmail.com> writes:> Bhaskar-- > >>Do you know of any that allows viewing differences graphically esp. of > MS >>Word documents? >>I've used VSS and I know it doesn't...just treats it as a binary. >> >>Cheers >>Bhaskar > > I use scootersoftware.com's Beyond Compare software to diff my word files > graphically.It is very useful. I get by without vcf,because of this and > some highly imaginative folder structures that I create.I don't think it will handle MS Word files, but "meld" is absolutely amazing for diff'ing source code - a great tool! -- % Randy Yates % "Though you ride on the wheels of tomorrow, %% Fuquay-Varina, NC % you still wander the fields of your %%% 919-577-9882 % sorrow." %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO http://home.earthlink.net/~yatescr
Reply by ●June 25, 20052005-06-25
Randy Yates wrote:> > I don't think it will handle MS Word files, but "meld" is absolutely > amazing for diff'ing source code - a great tool!I've tried meld, but I don't think its as nice as mgdiff. If you want to try it, do try the version in Debian GNU/Linux as it has some enhanced features I added. These would have been passed upstream but upstream seems to have disappeared off the face of the earth. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "I could never learn to use C++, because of the completely overwhelming desire to redesign the language every time I tried to use it, but this is the normal, healthy reaction to C++." -- Erik Naggum
Randy Yates wrote:> > Rune, > > subversion (svn) seems to be a new upcoming version control system, > aiming to replace the RCS/CVS systems.Subversion is a definite improvement over CVS especially if you want windows users to access it. However, it shares some of the downsides of CVS: - Multiple merges across branches are a PITA. - Centralised repository. If you are luck enough to have only Unix users accessing the archive GNU Arch is much nicer, especially if you want to do a bunch of branching/merging or disconnected/distributed development. Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "XML is not a language in the sense of a programming language any more than sketches on a napkin are a language." -- Charles Simonyi
