Removal of Time-Varying AM Contamination
Started by TheGhost June 23, 2005
Mark wrote:
> > Jerry Avins wrote: > >>Mark wrote: >> >>>Ghost, >>> >>>what is the rate of the AM of the tones you want to notch? Is the 16 >>>kHz amplitude changing over a period of seconds? >>> >>>I would think the AM is very slow and therefore the bandwidth of the >>>sidebands on the 16 kHz tones should be very close to 16 kHz.? >>> >>>What am I missing/ >> >>One thing is that with very slow change in amplitude, the bandwidth will >>approach zero. >> >>Jerry >> > > > I thought that's what I said.
On second reading, I agree that you you meant to. I took "the bandwidth of the sidebands ... should be very close to 16 kHz" literally. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
