Filter values in multi-stage audio sample rate covnersion?
Started by damc4 June 24, 2005
"Bhaskar Thiagarajan" <bhaskart@deja.com> wrote in message
news:42c17fe1$0$18640$14726298@news.sunsite.dk...
> "David Kirkland" <spam@netscape.net> wrote in message > news:XQawe.1493$Ai.282292@news20.bellglobal.com... >> Jim Thomas wrote: >> > Jon Harris wrote: >> > >> >> Just curious, what is the advantage of doing the 48/44.1 conversion in >> >> 3 stages >> >> versus a single stage? >> >> >> > >> > It can be cheaper. To realize some computational savings, you can use >> > sloppy filters in the initial stages, so long as you protect the >> > integrity of the /final/ passband. You can trash major portions of the >> > intermediate passbands (by allowing aliasing), so long as you keep the >> > trash out of the final passband. >> > >> > It always takes me a lot of work with pencil and paper to get my head >> > around this in the interp/decimate situation, but it's fairly >> > straightforward in a decimate-only or interpolate-only scenario. >> > >> > Rick covers this in his book (pg 384 and onward of the 2nd edition). >> > >> >> It often makes the filter design easier as well. For instance to do a >> single stage decimation by 1024, would likely require a huge number of >> taps. This single filter may be impossible to design using the PM >> algorithm - Even in matlab, the filter length can usually only go to >> ~1200 taps before instabilities start to occur (YMMV).
There are some tricks you can use to make the filter design easier for these huge filters. The windowed sinc method with a hand-tweaked kaiser window can usually get pretty close to a PM filter and doesn't suffer from any numerical issues at large sizes. Or you can design the filter at 1/2 (or 1/4, etc.) the size you need (e.g. design to decimate by 512 instead of 1024) and then interpolate up to get the full-length filter. The filter coefficients are usually so heavily oversampled (smooth) that linear interpolation is good enough.
> I agree with you when the resampling involves decimation only (or interp > only). In this case, the resampling is from 48 to 44.1 which shouldn't need > a very large filter. So in this specific case, I wouldn't say the filter > design is consierably easier. Yes - the multi-stage approach could use > sloppier filters but a straight conversion wouldn't result in a > 1000 taps > filter (I've never done this but that's what my gut feel tells me...unless > the required stop band attenuation is way way down there).
Because of the strange sample rate ratio (147/160), you probably will need a > 1000 tap filter for any kind of decent stop-band for audio. The way I think of it in my mind is that the ratio essentially forces you to oversample your filter by 160x (or maybe 147x?), so it doesn't take a very long "normal" filter before the "oversampled" filter is > 1000 taps.
