I wonder if you could help me with this. Because of system restrictions, I have to convert input data (floating point, 32 bit, IEEE format) to a 16 bit format (for example: 1 sign bit, 5 exponent bits, 10 mantissa) and, after processing, back to IEEE 32 bits. What issues can I expect in terms of dynamic range, clipping etc? Also, what would be the most efficient way to convert between the two formats? Many thanks.
Floating point issues
Started by ●June 25, 2005
Reply by ●June 25, 20052005-06-25
"Tom Linden" <tom@kednos.com> wrote in message news:opssxlf0rnzgicya@hyrrokkin...> If you can't work this out by yourself, you should consider a different > career path.Come on Tom, the guy's probably a computing 101 student, asking for advice.>>What issues can I expect in terms of dynamic range, clipping etc? Also, >>what would be the most efficient way to convert between the two formatsAssuming only +ive values ... You've assumed that you have to convert fp32 to fp16. One commonly used approach is to convert the FP data into unsigned 16 bit integer, that is, multiply the fp number by, say, 1000, do the math processing, then convert the integer back to fp by dividing by 1000. Since unsigned 16 bit integer has range 0 - 65535, the conversion gives you an effective fp range of 0 - 65. If you use a factor of 100, you get an effective fp range of 0 - 655. Get the picture? Try thinking outside the box a bit: Are you are limited to ALWAYS having just one 16 bit integer for each fp32 value? There's nothing wrong with an encoding scheme that might use an occasional extra 16 bit value to define something useful. For example, what about scanning each line (or buffer full) to see what the minimum value per line is, then each integer value is the delta ie base_value (int16), delta_values (int16). This will increase your effective dynamic range considerably, and make very little difference to the "system restrictions" you mention. Your algorithm sets the line or buffer size. example: base value is 3000, and all buffer values are the delta * 1000 (as described above). This scheme could be modified to set the base value to the data mean, then have signed integer delta values. You should be able to work out dynamic range and clipping issues from this. -- regards, Stewart DIBBS ======================================== Want to build your own scanner and digicam apps? PiXCL 6.0 is affordable and available now ! www.pixcl.com Gatineau, Quebec, CANADA ========================================
On 25 Jun 2005 08:09:19 -0700, giljk@hotmail.com wrote:>I wonder if you could help me with this. > >Because of system restrictions, I have to convert input data (floating >point, 32 bit, IEEE format) to a 16 bit format (for example: 1 sign >bit, 5 exponent bits, 10 mantissa) and, after processing, back to IEEE >32 bits. > >What issues can I expect in terms of dynamic range, clipping etc?Is this homework?>Also, >what would be the most efficient way to convert between the two >formats?You can discuss this only with some context and, even then, probably only by comparison -- as in, x is more efficient than y in this particular context. Why don't you disclose more of the situation? Jon
> Because of system restrictions, I have to convert input data (floating > point, 32 bit, IEEE format) to a 16 bit format (for example: 1 sign > bit, 5 exponent bits, 10 mantissa) and, after processing, back to IEEE > 32 bits.Google for "half float format". It is used by ATI and nVidia to save memeory and gain speed while rendering floating point. Also, the file format OpenEXR supports half floats and is well documented, including discussions on half float advantages over fixed point and 32 bit float. The OpenEXR libraries are open source and include half float conversion and, IIRC, math.
Reply by ●June 26, 20052005-06-26
On Sat, 25 Jun 2005 11:36:36 -0400, Stewart DIBBS <sjd@pixcl.com> wrote:> Come on Tom, the guy's probably a computing 101 student, asking for > advice.Very likely, but it doesn't require more than high school math.
Thank you Matthias, that is what I was looking for. Matthias Melcher wrote:> > Because of system restrictions, I have to convert input data (floating > > point, 32 bit, IEEE format) to a 16 bit format (for example: 1 sign > > bit, 5 exponent bits, 10 mantissa) and, after processing, back to IEEE > > 32 bits. > > Google for "half float format". It is used by ATI and nVidia to save memeory > and gain speed while rendering floating point. Also, the file format OpenEXR > supports half floats and is well documented, including discussions on half > float advantages over fixed point and 32 bit float. The OpenEXR libraries > are open source and include half float conversion and, IIRC, math.
Reply by ●June 27, 20052005-06-27
>>> On Sat, 25 Jun 2005 22:53:21 +0200, "Matthias Melcher" >>> <no-spame-matt@matthiasm.com> said:>> Because of system restrictions, I have to convert input data >> (floating point, 32 bit, IEEE format) to a 16 bit format (for >> example: 1 sign bit, 5 exponent bits, 10 mantissa) [ ... ]no-spame-matt> Google for "half float format". It is used by ATI no-spame-matt> and nVidia to save memeory and gain speed [ ... ] no-spame-matt> [ ... ] including discussions on half float no-spame-matt> advantages over fixed point and 32 bit float. [ no-spame-matt> ... ] Quite interesting. But for small number of bits I was quite impressed by FOCUS and other logarithm based ''floating point'' formats: http://DBLP.Uni-Trier.DE/rec/bibtex/journals/cacm/EdgarL79 "Communications of the ACM", v22 n3, March 1979: "FOCUS Microcomputer Number System"; Albert Edgar,Samuel Lee. =ABFOCUS is a number system and supporting computational algorithms especially useful for microcomputer control and other signal processing applications. FOCUS has the wide-ranging character of floating-point numbers with a uniformity of state distributions that give FOCUS better than a twofold accuracy advantage over an equal word length floating-point system. FOCUS computations are typically five times faster than single precision fixed-point or integer arithmetic for a mixture of operations, comparable in speed with hardware arithmetic for many applications. Algorithms for 8-bit and 16-bit implementations of FOCUS are included.=BB They require a different programming attitude though, probably the reason why GPUs use them. IIRC Some UK academic had started a few years ago a company for hardware accelerated logarithm based ''floating point'', but it does not seem to have achieved world domination yet, which may be a pity.
Peter Grandi schrieb:> Quite interesting. But for small number of bits I was quite > impressed by FOCUS and other logarithm based ''floating > point'' formats: > > http://DBLP.Uni-Trier.DE/rec/bibtex/journals/cacm/EdgarL79 > > "Communications of the ACM", v22 n3, March 1979: "FOCUS > Microcomputer Number System"; Albert Edgar,Samuel Lee. > ...Sounds really interesting. Is there any more detailed information about the principle available (online and for free)? The only link I found so far is <http://portal.acm.org/citation.cfm?id=359080.359085> which is a commercial portal - absolutely no information unless you pay... :-( -- Dipl.-Ing. Tilmann Reh http://www.autometer.de - Elektronik nach Ma�.
> Is there any more detailed information about the principle > available ... ?The generic term is probably LNS "logarithmic number system" there are many variants. Apart from software implementations in hardware/VLSI are common too. The basic simple variant is: Addition and subtraction are easy with integers. The most straightforward way to get from integer to logarithmic format and back is tables. There one has strength reduction: multiplication, division is addition, subtraction again. Tables can be appropriate with low-resolution applications, i know of a flight-simulator for very early x86 PCs. But for high-resolution the tables get out of hand, so from time to time someone comes up with a new fix for that problem. Often with a two word format similar to float. Log Point Technologies had a version in 1997 that claimed tables from 17k - 55k bytes. For 8 bit microprocessors and DSPs with 32x32 integer multiply. An old Ph.d: Stouraitis "Logarithmic Number System, Theory, Analysis and Design" University of Florida gives in google as "stouraitis logarithmic" about 250 hits one can examine. Another starting point would be groups.google on comp.arch.arithmetic with "logarithmic">> "Communications of the ACM", v22 n3, March 1979: "FOCUS >> Microcomputer Number System"; Albert Edgar,Samuel Lee.Thats the oldest (?) and certainly the most often quoted. I think there is a description of Focus as a chapter in a book too. MfG JRD
