hi i need help to design the loop filter for phase lock loop ic (4046).my input frequency is 40 t0 70 HZ AND my VCOout frequency is 256 to 448 KHZ.my VCC IS 5 Volt thank you R.birasanna
phase lock loop(PLL) help
Started by ●June 27, 2005
Reply by ●June 27, 20052005-06-27
biras wrote:> hi > i need help to design the loop filter for phase lock loop ic > (4046).my input frequency is 40 t0 70 HZ AND my VCOout frequency is > 256 to 448 KHZ.my VCC IS 5 Volt > > thank you > R.birasanna >Given that this is almost purely an analog circuits design question you should probably ask it on sci.electronics.design, or even sci.electronics.basic. There are a lot of variables that you have to juggle depending on what kind of performance you need in the end; expect to get a lot of questions about that. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
