In case of linear time invariant systems we can use convolution to represent the system or to find the system response. However if we have a nonlinear system how can we find the system response or the transfer function of the system? any ideas? This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Nonlinear system
Started by ●June 27, 2005
Reply by ●June 27, 20052005-06-27
aries44 wrote:> In case of linear time invariant systems we can use convolution to > represent the system or to find the system response. However if we have a > nonlinear system how can we find the system response or the transfer > function of the system? any ideas? > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.comBoth the notion of a general system response and of a transfer function are not generally valid for nonlinear systems. For a system with a "mild" nonlinearity you can approximate it's response by linearizing and finding the transfer function, then being careful how you use the result. For a system with a "severe" nonlinearity you have to throw away the linear analysis entirely and start using heavy math. It is not uncommon with nonlinear systems to use a combination of heavily simplified system models for theoretical calculations combined with carefully constructed simulations to speed up system design. The difference between "mild" and "severe" depends on interpretation. Indeed, you will often find it useful to call a system linear for one set of circumstances, and nonlinear for another. When I am analyzing control systems I'll often use linear analysis for finding the best controller for small disturbances and command inputs, but I'll use nonlinear analysis and synthesis techniques to insure that the system is unconditionally stable and will respond appropriately to large disturbances and/or control inputs. -- ------------------------------------------- Tim Wescott Wescott Design Services http://www.wescottdesign.com
aries44 wrote:> In case of linear time invariant systems we can use convolution to > represent the system or to find the system response. However if we have a > nonlinear system how can we find the system response or the transfer > function of the system? any ideas?I suggest you Google on "Volterra series". Difficult problem. Expensive solutions (measurement and computation.) A good intro is here: http://tinyurl.com/dqo54 In long form: http://lanoswww.epfl.ch/studinfo/courses/cours_nonlinear_de/extras/Cherry(1994)_Distortion%20Analysis%20of%20Weakly%20Nonlinear%20Filters%20Using%20Volterra%20Series_Chap3.pdf There isn't generally "a" transfer function because it depends on the levels (also in a frequency dependant way.) Bob -- "Things should be described as simply as possible, but no simpler." A. Einstein
Reply by ●June 28, 20052005-06-28
Here is an approach on how you could model non-linear systems using impulse responses: http://www.sintefex.com/docs/a=ADppnotes/dynaconv.PDF=20 Regards, Andor
