Hi again, I need to design a FIR filter with an even number of coefficients. I was wondering if the following formula is correct for calculating the coefficients for a lowpass filter with hamming window - for(n=0;n<L;n++) b[n] = (1/R)sinc(n/R){0.54+0.46*sin(2*pi*n/L) where R = Nyquist f / cutoff f L = filter length Thanks for your help once more, Ann.
newbie: fir filter design
Started by ●June 28, 2005
Reply by ●June 28, 20052005-06-28
aine_canby@yahoo.com wrote:> Hi again, > > I need to design a FIR filter with an even number of coefficients. I > was wondering if the following formula is correct for calculating the > coefficients for a lowpass filter with hamming window - > > for(n=0;n<L;n++) > b[n] = (1/R)sinc(n/R){0.54+0.46*sin(2*pi*n/L) > > where R = Nyquist f / cutoff f > L = filter length > > Thanks for your help once more, > > Ann.http://www.cg.tuwien.ac.at/studentwork/CESCG/CESCG99/TTheussl/node9.html Please learn to exploit Google. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Thanks, I was trying to be too smart with that sin function. OK, heres what I have now - for(i=0;i<L;i++) h[i] = 1/R*sinc(i-(L-1)/2)*(0.54+0.46*cos(2*PI* (i-(L-1)/2) / L)) Is this correct for an odd number of coefficients? Now, what about an even number? I could do it for 255 and leave one of the taps a zero. Is there a way of using all the taps? Thanks, Ann.
Thanks, I was trying to be too smart with that sin function. OK, heres what I have now - for(int i=0;i<L;i++) b[i] = 1/double(R)*sinc((i-((L-1)/2.0))/double(R))*(0.54+0.46*cos(2*PI* (i-((L-1)/2.0))/L)); Is this correct for an odd number of coefficients? Now, what about an even number? I could do it for 255 and leave one of the taps a zero. Is there a way of using all the taps? Thanks, Ann.
aine_canby@yahoo.com wrote:> Thanks, I was trying to be too smart with that sin function. > > OK, heres what I have now - > > for(int i=0;i<L;i++) > b[i] = > 1/double(R)*sinc((i-((L-1)/2.0))/double(R))*(0.54+0.46*cos(2*PI* > (i-((L-1)/2.0))/L));sinc? Why? from where? The window is simply a cycle of cosine raised on a pedestal so that the lowest point is slightly positive and the highest is unity. The reference I gave you shows a closely related window. Once you understand what they are, you can derive your own equation. Note sin^2(x) = [1-cos(x/2)]/2 and related identities.> Is this correct for an odd number of coefficients? > > Now, what about an even number? I could do it for 255 and leave one of > the taps a zero. Is there a way of using all the taps?That's an exercise for the student. Note that when using a window whose end coefficients are zero, you keep a little more significance by computing the window to cover two extra points, then discarding 0*0. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Well this is how we learned to generate symmetrical filter coefficients in class for a lowpass filter with 33 taps - h[n] = (1/R)sinc(n/R) n =-16 to 16 where R = Nyquist frequency / Cutoff Frequency I'm just trying to create a more practical version of this so I can generate the tap values using C. I also added the window. Does my code make sense? I plotted the frequency response of the tap values my code generated using freqz, and I got what I expected. I set R = 5 and L = 1023 and I got a stopband attenuation of -60dBs or so.
aine_canby@yahoo.com wrote:> Well this is how we learned to generate symmetrical filter coefficients > in class for a lowpass filter with 33 taps - > > h[n] = (1/R)sinc(n/R) n =-16 to 16 > > where R = Nyquist frequency / Cutoff Frequency > > I'm just trying to create a more practical version of this so I can > generate the tap values using C. I also added the window. > > Does my code make sense? > > I plotted the frequency response of the tap values my code generated > using freqz, and I got what I expected. I set R = 5 and L = 1023 and I > got a stopband attenuation of -60dBs or so.I'm confused. Are you generating filter coefficients, or the coefficients of the Hamming window? I may well have given you a bum steer. Yes indeed: sinc for low-pass (and high-pass too by subtracting one from the middle coefficient) and a window to reduce the leakage. Is there a reason for not using one of the many software optimizers to do the whole job? Practice? I too like and use old tools, sometimes because because that's what I have, sometimes because they work better. One of my better tools: http://users.rcn.com/jyavins/Jointer.jpg (I also have an electric one.) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Thanks Jerry. As part of my class project, I have to produce the coefs myself. I'm happy enough now with what I have, just wondering though about the implementation of a 256 tap filter. Should I simply calculate for 255 taps and then leave the last tap empty, or is there a version the following equation for even numbered taps - h[n] = (1/R)sinc(n/R) n =-16 to 16 Ann.
Reply by ●June 29, 20052005-06-29
Hi Ann! Your FIR filter should be designed to be linear-phase. A FIR filter is linear-phase if (and only if) its coefficients are symmetrical around the center coefficient, that is, the first coefficient is the same as the last; the second is the same as the next-to-last, etc. (A linear-phase FIR filter having an odd number of coefficients will have a single coefficient in the center which has no mate.) b[n] = b[ L-n-1]! So it's not a good idea to just throw one coefficient away to get an even numbered filter! If your two functions fullfill the abovementioned criterium, you are on a good way: So you may write for your window function: 0.54 + 0.46 * sin( 2*PI*n/ (L-1) ) ( since n = 0.... L-1 ) or in C++ pseudo code: w[n] = 0.54 + 0.46 * sin (2. * PI * (float) n / float( L - 1) ; And your low pass filter should be: (1/R) * sinc ( (n - ( L-1)/2) /R ) or in pseudo C++ code: float m = ( float ) n - float( L-1) /2.f; h[n] = (1/R) * sin ( m/R ) / (m/R) ; Whether the filter length L is odd or even does not matter for those formulas ( if I didn't make errors - Please remember, that I am no filter expert ). Just set L = 255 or L = 256 ! Yours Karin <aine_canby@yahoo.com> schrieb im Newsbeitrag news:1119965921.445942.226820@g43g2000cwa.googlegroups.com...> Hi again, > > I need to design a FIR filter with an even number of coefficients. I > was wondering if the following formula is correct for calculating the > coefficients for a lowpass filter with hamming window - > > for(n=0;n<L;n++) > b[n] = (1/R)sinc(n/R){0.54+0.46*sin(2*pi*n/L) > > where R = Nyquist f / cutoff f > L = filter length > > Thanks for your help once more, > > Ann. >
Karin wrote:> A FIR filter is linear-phase if (and only if) its coefficients are symmetrical > around the center coefficient, that is, the first coefficient is the same as > the last; the second is the same as the next-to-last, etc.Hello Karin, I'm not sure about that second "if". I think hermitian symmetric FIRs are also linear-phase ... Regards, Andor
