cross correlation
Started by signal ●June 29, 2005
Hi expert,
I used xcorr to calculate cross correlation in matlab, i tried to do the
same thing by using fft, so :
i have 2 signals x, y
L=max(lenght(x), lenght(y))
xx=fft(x,2*L).
yy=fft(y,2*L).
Sxy=xx.*conj(y);
rxy=fftshift(real(ifft(Sxy))) ;
Rxy is my cross correlation,the problem is when i drawed rxy and
xcorr(x,y)
i dont find equality between rxy et xcorr, where is the problem
Thanks a lot to answer at my question.
This message was sent using the Comp.DSP web interface on
www.DSPRelated.com
I don't have xcorr available, so I don't know the detail of
how it works, but here are some suggestions of what to look
for.
> I used xcorr to calculate cross correlation in matlab, i tried to do the > same thing by using fft, so : > i have 2 signals x, y > L=max(lenght(x), lenght(y))
Make sure to use the signal the same length as xcorr does. I wouldn't be surprised if it is something along the lines of L=length(x)+2*(length(y)-1);
> xx=fft(x,2*L). > yy=fft(y,2*L).
Make sure to use the same FFT length as xcorr does. Again, I wouldn't be surprised if it is something along the lines of Nfft = length(x)+2*(length(y)-1); Remember, no symmetry can be expected for cross correlation.
> Sxy=xx.*conj(y);
Could it be that the order of the conjugates are different?
Does xcorr shift the data so that zero lag ends up in the middle? If so, how does it handle the different lengths of x and y?
> Rxy is my cross correlation,the problem is when i drawed rxy and > xcorr(x,y)
Rune
signal wrote:
> Sxy=xx.*conj(y);
Sxy=xx.*conj(yy);
signal wrote:
> Sxy=xx.*conj(y);
Should that be Sxy=xx.*conj(yy); ?? -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Any sufficiently advanced technology is indistinguishable from magic. - Arthur C. Clarke
Hi,
thanks for your response.
This is a typing error, i used sxy=xx.*conj(yy).
>signal wrote: >> Sxy=xx.*conj(y); > >Should that be Sxy=xx.*conj(yy); > >?? > >-- >Jim Thomas Principal Applications Engineer Bittware, Inc >jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 >Any sufficiently advanced technology is indistinguishable from magic. > - Arthur C. Clarke >
This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Hi,
Hello,
when I plotted  two curves, I mean xcorr and rxy , I found same pace, but
one of the curves is shifted and out of phase with an angle of 180
compared to the other
>Hi, >thanks for your response. >This is a typing error, i used sxy=xx.*conj(yy). > > >>signal wrote: >>> Sxy=xx.*conj(y); >> >>Should that be Sxy=xx.*conj(yy); >> >>?? >> >>-- >>Jim Thomas Principal Applications Engineer Bittware, Inc >>jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 >>Any sufficiently advanced technology is indistinguishable from magic. >> - Arthur C. Clarke >> > > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.com >
signal wrote:
> Hello, > > when I plotted two curves, I mean xcorr and rxy , I found same pace, but > one of the curves is shifted and out of phase with an angle of 180 > compared to the other
Perhaps, along the way, you missed an odd number of minus signs. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry,
Please, could you explain more, above i writted my method.
thanks
>signal wrote: >> Hello, >> >> when I plotted two curves, I mean xcorr and rxy , I found same pace,
but
>> one of the curves is shifted and out of phase with an angle of 180 >> compared to the other > >Perhaps, along the way, you missed an odd number of minus signs. > > ... > >Jerry >-- >Engineering is the art of making what you want from things you can get. >����������������������������������������������������������������������� >
signal wrote:
> Jerry, > Please, could you explain more, above i writted my method. > thanks > > > >>signal wrote: >> >>>Hello, >>> >>>when I plotted two curves, I mean xcorr and rxy , I found same pace, > > but > >>>one of the curves is shifted and out of phase with an angle of 180 >>>compared to the other >> >>Perhaps, along the way, you missed an odd number of minus signs.
My remark was intended to me a humorous way to point out that a 180-degree phase shift and a negation are the same. I'm sorry that the joke fell flat. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
