Hi. I'm working in a FFT project, and I need to do a zoom in a FFT. Do you know what is the most effective way to do a zoom FFT. Do you have a code to do it? Thank you? Diego
What is the most effective way to do a zoom FFT
Started by ●July 2, 2005
Reply by ●July 3, 20052005-07-03
On 1 Jul 2005 21:54:13 -0700, "Diego" <diux007@gmail.com> wrote:>Hi. > >I'm working in a FFT project, and I need to do a zoom in a FFT. >Do you know what is the most effective way to do a zoom FFT. Do you >have a code to do it? > >Thank you? > >DiegoHi, are you sure you want to perform a Zoom FFT? Is you goal to minimize the size of your FFT in order to achieve some given FFT spectral bin spacing? I've learned that the Zoom FFT is only computationally efficient if your decimation factor is greater than, say 30, and the number of taps in the filter (FIR) is less than, say, 30. Good luck [-Rick-]
