Hi there, I'm reading a paper at the moment which refers to an "A-DSP", and also refers to "analog-to-digital signal processing circuit". What exactly is this? Is it simply a ADC or is it a ADC and DSP board in one? This device intefaces to a PC via an IO-board and its not clear if signal processing takes place on the A-DSP or the PC. Can anyone enlighten me? Regards, Cathal.
What's an A-DSP?
Started by ●July 2, 2005
Reply by ●July 2, 20052005-07-02
cathal_campbell_shaw@mail.ie wrote:> Hi there, > > I'm reading a paper at the moment which refers to an "A-DSP", and also > refers to "analog-to-digital signal processing circuit". What exactly > is this? Is it simply a ADC or is it a ADC and DSP board in one? This > device intefaces to a PC via an IO-board and its not clear if signal > processing takes place on the A-DSP or the PC. > > Can anyone enlighten me? > > Regards, > > Cathal.Is it a brand name? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> cathal_campbell_shaw@mail.ie wrote: > > Hi there, > > > > I'm reading a paper at the moment which refers to an "A-DSP", and also > > refers to "analog-to-digital signal processing circuit". What exactly > > is this? Is it simply a ADC or is it a ADC and DSP board in one? This > > device intefaces to a PC via an IO-board and its not clear if signal > > processing takes place on the A-DSP or the PC. > > > > Can anyone enlighten me? > > > > Regards, > > > > Cathal. > > Is it a brand name? > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF==AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF Analog Devices DSP chips are named ADSPXXXXX. For example, http://www.digchip.com/datasheets/parts/datasheet/041/ADSP2101.php John
john wrote:> > Jerry Avins wrote: > >>cathal_campbell_shaw@mail.ie wrote: >> >>>Hi there, >>> >>>I'm reading a paper at the moment which refers to an "A-DSP", and also >>>refers to "analog-to-digital signal processing circuit". What exactly >>>is this? Is it simply a ADC or is it a ADC and DSP board in one? This >>>device intefaces to a PC via an IO-board and its not clear if signal >>>processing takes place on the A-DSP or the PC. >>> >>>Can anyone enlighten me? >>> >>>Regards, >>> >>>Cathal. >> >>Is it a brand name? >> >>Jerry >>-- >>Engineering is the art of making what you want from things you can get. >>����������������������������������������������������������������������� > > > Analog Devices DSP chips are named ADSPXXXXX. For example, > > http://www.digchip.com/datasheets/parts/datasheet/041/ADSP2101.phpBut not with a hyphen: A-DSP. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Jerry Avins" <jya@ieee.org> wrote in message news:ofednfeQNenDRlvfRVn-1Q@rcn.net...> cathal_campbell_shaw@mail.ie wrote: >> Hi there, >> >> I'm reading a paper at the moment which refers to an "A-DSP", and also >> refers to "analog-to-digital signal processing circuit". What exactly >> is this? Is it simply a ADC or is it a ADC and DSP board in one? This >> device intefaces to a PC via an IO-board and its not clear if signal >> processing takes place on the A-DSP or the PC. >> >> Can anyone enlighten me? >> >> Regards, >> >> Cathal. > > Is it a brand name?Why don't you give us some more context? Like several sentences around the usage of the unfamiliar terms.
