Hi, I've been working on demodulation of low-deviation GFSK signals similar to Bluetooth, with h=0.3 and BT=0.5. I have two simulations, one using a discriminator plus integrate and dump, and another with a second order PLL. I am computing BER vs Eb/No for each case. In the PLL case, I expect to see a few dB of improvement compared to the discriminator, but I'm not getting that. I'm either misunderstanding something, or I have made a mistake in the implementation. The PLL locks onto the average phase of the carrier, leaving a phase error term that, when differentiated and filtered (with a boxcar), gives the bit waveform. What I don't get is how this is any better than skipping the PLL entirely. Is it possible to use a PLL to obtain better sensitivity for this class of FSK signals? Thanks, John
Coherent vs Noncoherent GFSK Demodulation
Started by ●July 7, 2005
Reply by ●July 8, 20052005-07-08
"john" <johns@xetron.com> writes:> Hi, > > I've been working on demodulation of low-deviation GFSK signals similar > to Bluetooth, with h=0.3 and BT=0.5. I have two simulations, one using > a discriminator plus integrate and dump, and another with a second > order PLL. I am computing BER vs Eb/No for each case. In the PLL case, > I expect to see a few dB of improvement compared to the discriminator, > but I'm not getting that. I'm either misunderstanding something, or I > have made a mistake in the implementation. > > The PLL locks onto the average phase of the carrier, leaving a phase > error term that, when differentiated and filtered (with a boxcar), > gives the bit waveform. What I don't get is how this is any better than > skipping the PLL entirely. > > Is it possible to use a PLL to obtain better sensitivity for this class > of FSK signals?Hi John, How do you get baud lock with your integrate/dump in the discriminator model? That's the real issue. Also, how do you know your phase lock is good in the PLL model? You might want to try using the carrier of the transmitter in the demodulator as a test to see that the PLL is getting locked correctly. If it is their shouldn't be much difference in the BERs, I would think. Caveat: I'm no expert. -- % Randy Yates % "I met someone who looks alot like you, %% Fuquay-Varina, NC % she does the things you do, %%% 919-577-9882 % but she is an IBM." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:> "john" <johns@xetron.com> writes: > > > Hi, > > > > I've been working on demodulation of low-deviation GFSK signals similar > > to Bluetooth, with h=0.3 and BT=0.5. I have two simulations, one using > > a discriminator plus integrate and dump, and another with a second > > order PLL. I am computing BER vs Eb/No for each case. In the PLL case, > > I expect to see a few dB of improvement compared to the discriminator, > > but I'm not getting that. I'm either misunderstanding something, or I > > have made a mistake in the implementation. > > > > The PLL locks onto the average phase of the carrier, leaving a phase > > error term that, when differentiated and filtered (with a boxcar), > > gives the bit waveform. What I don't get is how this is any better than > > skipping the PLL entirely. > > > > Is it possible to use a PLL to obtain better sensitivity for this class > > of FSK signals? > > Hi John, > > How do you get baud lock with your integrate/dump in the discriminator > model? That's the real issue. > > Also, how do you know your phase lock is good in the PLL model? You might want to try > using the carrier of the transmitter in the demodulator as a test to see > that the PLL is getting locked correctly. If it is their shouldn't be much > difference in the BERs, I would think. Caveat: I'm no expert. > -- > % Randy Yates % "I met someone who looks alot like you, > %% Fuquay-Varina, NC % she does the things you do, > %%% 919-577-9882 % but she is an IBM." > %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO > http://home.earthlink.net/~yatescrThanks, Randy. I have a couple methods of obtaining baud lock. Remember, this is just a simulation at this point. The first method is that there is no timing error, i.e. perfect sampling. The second method is to use an S-curve to choose the best phase over a packet. The third method is to use a transition tracking PLL to track the best sampling phase even when clocks drift. In no case do I see the improvement I expect with coherent detection. Regarding the phase, I check the PLL transient step response with an unmodulated input, and plot against the theory for a second order loop. The agreement is excellent. Now I turn on the GFSK modulation, with no change to the PLL parameters. John
