Hi all i am basically from GPS doing usual Acuistion, tracking stuff for CDMA signal... recently moved in to ofdm... still learning..this site doing a great favour.. after going thorugh all basics i have few points to comment and ask.. 1. IFFT will genrate the complex valued signal,as input is output of QAM mapper and placement of carriers is assymetrical, how do we go from here.. how do we transmit a complex signal.? will it relate to I and Q channels in my RF transmission and then adding these signals there... or only real part is transmiietd.... 2. for 11a , 20 MHz signal is genrated in to baseband and taken to higher band where signal has to be transmitted. in GPS case,at reciver end selection of IF frequncy and ADC sampling frequncy used to define where our final digital signal fall: baseband or centred around some carrier... if i apply same analysis to ofdm, what are the usual sampling rate and IF signal for 11a or for any other ofdm system for that matter... 3. if we look at one single symbol,including CP,in frq domain theye are still impulse trains only.. they do spread only if we look over two consecutive or more symobols(given that they hapen to tranmit differnt QAM values) ... giving rise to that famous ofdm frequncy diagram showing overlapping sincs..... is it true???? Regds and thanks in advance sandeep This message was sent using the Comp.DSP web interface on www.DSPRelated.com
ofdm RF portion doubt...
Started by ●July 9, 2005
Reply by ●July 14, 20052005-07-14
Hi First of all you do not transmitt a complex signal. Align the input to your IFFT in a way called Hermitian symmetry (symetrical around DC). This will result in only real valued output from the IFFT. Secondly to get the famous OFDM spectrum, sum the outputs of your IFFT and convolve this OFDM symbol value with a rectangular pulse (not sure about the period for the pulse). This will give you the sinc functions in the frequency domain with the DC value of each sinc equal to the OFDM symbol value. Hope it helps Cheers Jaco>Hi all > i am basically from GPS doing usual Acuistion, tracking stufffor>CDMA signal... recently moved in to ofdm... still learning..this site >doing a great favour.. > > after going thorugh all basics i have few points to commentand>ask.. > >1. IFFT will genrate the complex valued signal,as input is output ofQAM>mapper and placement of carriers is assymetrical, how do we go from >here.. how do we transmit a complex signal.? will it relate to I and Q >channels in my RF transmission and then adding these signals there... or >only real part is transmiietd.... > >2. for 11a , 20 MHz signal is genrated in to baseband and taken tohigher>band where signal has to be transmitted. in GPS case,at reciver end >selection of IF frequncy and ADC sampling frequncy used to define where >our final digital signal fall: baseband or centred around somecarrier...> >if i apply same analysis to ofdm, >what are the usual sampling rate and IF signal for 11a or for any other >ofdm system for that matter... > >3. if we look at one single symbol,including CP,in frq domain theye are >still impulse trains only.. they do spread only if we look over two >consecutive or more symobols(given that they hapen to tranmit differntQAM>values) ... giving rise to that famous ofdm frequncy diagram showing >overlapping sincs..... is it true???? > > >Regds >and thanks in advance >sandeep > > > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.com >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●July 15, 20052005-07-15
Thanks jaco for the help i just want to elaborate few points further>Hi > >First of all you do not transmitt a complex signal. Align the input to >your IFFT in a way called Hermitian symmetry (symetrical around DC).This>will result in only real valued output from the IFFT.if we place the carriers symmetrically,i believe it means same amplitude and oppoiste phase on wither side of DC for the same index number..that means we are forced to do so..... so as to get real output.... dont this thing effectively halves my data transmission rate....?> >Secondly to get the famous OFDM spectrum, sum the outputs of your IFFTand>convolve this OFDM symbol value with a rectangular pulse (not sure about >the period for the pulse). This will give you the sinc functions in the >frequency domain with the DC value of each sinc equal to the OFDM symbol >value.what you said is entirely true...perhaps its another way of looking at the same thing what i said.... say if both symbols to be transmtted are exactly same.. each subcarrier will be continous over twice the length of rectangular pulse.... but beacuse its 100% sure that two consecuitve symbols will transmitt different symbols at least once over a period of time,there will be change of phase and amplitude for each subcarrier (equivalent of multiplication of subcarrier with that of rectangular pulse)...in frequncy domain it becomes convoloution of each impluse (for subcarriers)withe the sinc function(that of rectangular pulse).... i hope what i undersatnd is closer to TRUTH.. thansk a lot> >Hope it helps >Cheers >Jaco > >>Hi all >> i am basically from GPS doing usual Acuistion, tracking stuff >for >>CDMA signal... recently moved in to ofdm... still learning..this site >>doing a great favour.. >> >> after going thorugh all basics i have few points to comment >and >>ask.. >> >>1. IFFT will genrate the complex valued signal,as input is output of >QAM >>mapper and placement of carriers is assymetrical, how do we go from >>here.. how do we transmit a complex signal.? will it relate to I andQ>>channels in my RF transmission and then adding these signals there...or>>only real part is transmiietd.... >> >>2. for 11a , 20 MHz signal is genrated in to baseband and taken to >higher >>band where signal has to be transmitted. in GPS case,at reciver end >>selection of IF frequncy and ADC sampling frequncy used to define where >>our final digital signal fall: baseband or centred around some >carrier... >> >>if i apply same analysis to ofdm, >>what are the usual sampling rate and IF signal for 11a or for any other >>ofdm system for that matter... >> >>3. if we look at one single symbol,including CP,in frq domain theye are >>still impulse trains only.. they do spread only if we look over two >>consecutive or more symobols(given that they hapen to tranmit differnt >QAM >>values) ... giving rise to that famous ofdm frequncy diagram showing >>overlapping sincs..... is it true???? >> >> >>Regds >>and thanks in advance >>sandeep >> >> >> >> >>This message was sent using the Comp.DSP web interface on >>www.DSPRelated.com >> > > > > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.com >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●July 17, 20052005-07-17
hi friends i am amal i am doing a project on the below topic " power allocation for ofdm using adaptive beamforming over wireless netowrk" if u have any paper related to this or any article if u know anything about this please send me urs amal
Reply by ●July 18, 20052005-07-18
1. The complex I & Q baseband signal will be upconverted to higher frequency (being it IF or RF doesn't matter) by using sin and cos signals as I*cos-Q*sin 2. In 11a system, we downconvert to baseband (with several stages, usually 1 to 2), and ADC to do sampling. Usually the sampling rate is 2X (40MHz).
Reply by ●August 1, 20052005-08-01
>1. The complex I & Q baseband signal will be upconverted to higher >frequency (being it IF or RF doesn't matter) by using sin and cos >signals as I*cos-Q*sinI am trying this approach in MATLAB. after generating I and Q signals(as output of IFFT) i am multiplying them with cq(i) = cos(2*pi*i*(30e06/100e06)); ci(i) = sin(2*pi*i*(30e06/100e06)); to simulate upconversion at 30 Mhz carrier with sampling rate of 100 Mhz. and finaly ading as u suggest final = I*cos-Q*sin is it correct approach to simulate things in MATLAB.... if i want to recover signal from final after adding AWGN,how to do it.. is it again by multiplying the final+noise with cos and sin of same frequncies in MATLAB.... where does filter etc come in to picture... Thanks fot the help.. sandy>2. In 11a system, we downconvert to baseband (with several stages, >usually 1 to 2), and ADC to do sampling. Usually the sampling rate is >2X (40MHz). > >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
