Rune Allnor wrote:> > Jerry Avins wrote: > >>Rune Allnor wrote: >> >>>Jerry Avins wrote: >> >> >> ... >> >> >>>>Lenses are a little like logic chips in that they can be used in >>>>combination to do neat stuff. >>> >>> >>>I am sure you are right and it would be great fun to test out some >>>of the basic optical principles. Somehow, it seems to me that some >>>precision tools and mechanical skills, like knowing how to operating >>>a lathe, would be needed. >> >>A lathe is very nice, but you can do a lot with cardboard tubes, tin >>cans, stove pipe, wood, and hand tools. Given a mounted lens -- the >>mount can be cardboard -- wood, a piece of ground glass (or window glass >>and emery powder) and wood, a camera obscura is easy to make. A mirror >>can make it fancier. http://brightbytes.com/cosite/portable.html My >>first camera was a cardboard pinhole kit from Kodak. I won honorable >>mention in Popular Photography with a picture I took with it that took >>advantage of the tremendous depth of field and uniform slight softness. >>My first astro telescope, a 3" f/14 refractor had a surplus erecting >>roof prism with 1.25" clear aperture. The tube was stove pipe, the end >>fitting was a soup can soldered to a mixed-nut can with a press-on lid >>(with the prism inside) and a commercial focuser intended for a >>Newtonian refractor. The tube was lined with black flock paper. I >>cannibalized much of it for more other uses, but I still have the >>objective (with its tuna-can lens cap) Do you want it? > > > Heyheyheyheyhey, you are light-years ahead of me... your CO was a > box with lense in the front end and a matt glass "projector screen" > in the rear end?No. That's what I'm suggesting for you; look at the pictures. Mine was a hole in the roof (that the dryer vent usually passed through) with the 45" f.l. lens in it and a rotatable mirror over it driven by a pulley on the rotating TV antenna. With no light in the attic, I could spy on the whole neighborhood. It stayed in place for a few days until rain was forecast, then I put things back the way they were.> Sure, it could be done but I'm thinking a bit simpler than that. > What I have in mind is a small mirror, like the ~7 cm mirror I bought > today, perhaps a bit bigger to collect more light, somehow mounted > behind an easel inside a dark hut or room. No fancy stuff, just a > mirror. The mount and the easel will be needed to keep the mirror > and the drawing paper in fixed positions for any length of time, but > that's obvious to anybody who sees the rig. Use some sticks or chairs > an a couple of carpets to make a dark "tent", and perhaps rig some > lights outside to light up the subject even more. The key here is > to make people see each and every piece of the rig, undertsand why > they are there and thus see how the whole thing works.The problem with mirrors is that they get in the way of their own images. If you tilt them so the image passes sideways, a lot of astigmatism and coma is introduced. (Tilted mirrors are used in schlieren cameras, but in pairs that tend to correct each other.)> The lense-and-projector-screen-inside-a-box would probably be too > much of a "black box" - literally - to be useful to trig curiousity.Bah! Use a shoe box. Put a screen at the back of it and another in the rear of the top, with a support for a removable diagonal mirror to redirect the image to the cover, where it's more useful for drawing. Remove the top with a flourish to reveal an empty box. Say something exciting, like "Hocus Pocus! Observe that the fingers never leave the hand!", then pass the box around, inviting your audience to look at the white paper that you have cleverly put in front of the rear ground glass. (Wax paper will do instead of ground glass.) The image will be washed out by ambient light; put the cover on and invite the audience members -- how many little relatives do you have? -- to peer through the small view port (a liftable flap) that you cleverly cut into the front of the top. Ask them to determine the handedness of the upside-down image. Next, remove the white paper from the back of the box and have them examine the same image from the outside with the help of a dark sheet. (You can close the front flap now.) Have them confirm that the image is still upside down, but its handedness has changed. Show them the mirror. Have them confirm that it too changes handedness, then put it in place in the box. Now the image appears on the top ground class (or wax paper). Lo and behold! The handedness is the same as the image inside the box, but top is top. (Not really: top is front. Let them figure that out for themselves.) How transparent can the setup be? For drawing, use wooden boxes that slide together and apart to focus, clear glass so the image is formed directly on the back of the tracing paper, and if available, a front-surface mirror (but don't sweat it; just get the thinnest mirror you can), but only after the cardboard one they can not only look at but hold and squeeze. (You WILL have tape for making repairs!> But then, your method might just be what trigs the whole optics > frenzie.Which method? I have lots of them. A puzzle for the kiddies: How can you arrange more than one mirror so the image at the top is not a "mirror image" of reality? Hint: the box needs to be a little bigger. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Power spectrum
Started by ●July 10, 2005
Reply by ●July 16, 20052005-07-16
Jerry Avins wrote: ...> Bah! ...I regret writing that. It sounds dismissive, and I don't mean to be. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●August 3, 20052005-08-03
Jerry Avins wrote:> Rune Allnor wrote: > > > > Jerry Avins wrote: > > > >>Rune Allnor wrote: > >> > >>>Jerry Avins wrote: > >> > >> > >> ... > >> > >> > >>>>Lenses are a little like logic chips in that they can be used in > >>>>combination to do neat stuff. > >>> > >>> > >>>I am sure you are right and it would be great fun to test out some > >>>of the basic optical principles. Somehow, it seems to me that some > >>>precision tools and mechanical skills, like knowing how to operating > >>>a lathe, would be needed. > >> > >>A lathe is very nice, but you can do a lot with cardboard tubes, tin > >>cans, stove pipe, wood, and hand tools. Given a mounted lens -- the > >>mount can be cardboard -- wood, a piece of ground glass (or window glass > >>and emery powder) and wood, a camera obscura is easy to make. A mirror > >>can make it fancier. http://brightbytes.com/cosite/portable.html My > >>first camera was a cardboard pinhole kit from Kodak. I won honorable > >>mention in Popular Photography with a picture I took with it that took > >>advantage of the tremendous depth of field and uniform slight softness. > >>My first astro telescope, a 3" f/14 refractor had a surplus erecting > >>roof prism with 1.25" clear aperture. The tube was stove pipe, the end > >>fitting was a soup can soldered to a mixed-nut can with a press-on lid > >>(with the prism inside) and a commercial focuser intended for a > >>Newtonian refractor. The tube was lined with black flock paper. I > >>cannibalized much of it for more other uses, but I still have the > >>objective (with its tuna-can lens cap) Do you want it? > > > > > > Heyheyheyheyhey, you are light-years ahead of me... your CO was a > > box with lense in the front end and a matt glass "projector screen" > > in the rear end? > > No. That's what I'm suggesting for you; look at the pictures.Sorry, didn't do that. I'm on a low-capacity link for yet a few days, so I tend not to look at links I don't know beforehand.> Mine was a > hole in the roof (that the dryer vent usually passed through) with the > 45" f.l. lens in it and a rotatable mirror over it driven by a pulley on > the rotating TV antenna.Sounds like a periscope to me (still haven't looked at any pictures).> With no light in the attic, I could spy on the > whole neighborhood. It stayed in place for a few days until rain was > forecast, then I put things back the way they were. > > > Sure, it could be done but I'm thinking a bit simpler than that. > > What I have in mind is a small mirror, like the ~7 cm mirror I bought > > today, perhaps a bit bigger to collect more light, somehow mounted > > behind an easel inside a dark hut or room. No fancy stuff, just a > > mirror. The mount and the easel will be needed to keep the mirror > > and the drawing paper in fixed positions for any length of time, but > > that's obvious to anybody who sees the rig. Use some sticks or chairs > > an a couple of carpets to make a dark "tent", and perhaps rig some > > lights outside to light up the subject even more. The key here is > > to make people see each and every piece of the rig, undertsand why > > they are there and thus see how the whole thing works. > > The problem with mirrors is that they get in the way of their own > images. If you tilt them so the image passes sideways, a lot of > astigmatism and coma is introduced.That much I have found out. Should make a better sketch than my free-hand drawing, nonetheless.> (Tilted mirrors are used in > schlieren cameras, but in pairs that tend to correct each other.) > > > The lense-and-projector-screen-inside-a-box would probably be too > > much of a "black box" - literally - to be useful to trig curiousity. > > Bah! Use a shoe box. Put a screen at the back of it and another in the > rear of the top, with a support for a removable diagonal mirror to > redirect the image to the cover, where it's more useful for drawing. > Remove the top with a flourish to reveal an empty box. Say something > exciting, like "Hocus Pocus! Observe that the fingers never leave the > hand!", then pass the box around, inviting your audience to look at the > white paper that you have cleverly put in front of the rear ground > glass. (Wax paper will do instead of ground glass.) The image will be > washed out by ambient light; put the cover on and invite the audience > members -- how many little relatives do you have? -- to peer through the > small view port (a liftable flap) that you cleverly cut into the front > of the top. Ask them to determine the handedness of the upside-down > image. Next, remove the white paper from the back of the box and have > them examine the same image from the outside with the help of a dark > sheet. (You can close the front flap now.) Have them confirm that the > image is still upside down, but its handedness has changed. Show them > the mirror. Have them confirm that it too changes handedness, then put > it in place in the box. Now the image appears on the top ground class > (or wax paper). Lo and behold! The handedness is the same as the image > inside the box, but top is top. (Not really: top is front. Let them > figure that out for themselves.)Need some time to digest that one...> How transparent can the setup be? For drawing, use wooden boxes that > slide together and apart to focus, clear glass so the image is formed > directly on the back of the tracing paper, and if available, a > front-surface mirror (but don't sweat it; just get the thinnest mirror > you can), but only after the cardboard one they can not only look at but > hold and squeeze. (You WILL have tape for making repairs!Now we are talking. This sounds almost useful... ;)> > But then, your method might just be what trigs the whole optics > > frenzie. > > Which method? I have lots of them. A puzzle for the kiddies: How can you > arrange more than one mirror so the image at the top is not a "mirror > image" of reality? Hint: the box needs to be a little bigger.To accomodate that second mirror? I think I'll have to find some glass maker's shop some day soon... Rune
Jerry Avins wrote:> Rune Allnor wrote: > > Heyheyheyheyhey, you are light-years ahead of me... your CO was a > > box with lense in the front end and a matt glass "projector screen" > > in the rear end? > > No. That's what I'm suggesting for you; look at the pictures.Hail, O Jerry! My salutes to the Great Wizard in the art of Engineering! The carboard-box camera works! I found a carboard box roughly the same length as the focal length of my magnifying glass. I taped the lid shut and cut out the end walls. I taped some waxed paper over one end, and stuck the magnifying glass in the other. When pointing the box out in a lit area from a dark room, I get a picture visible on the paper. The picture is upside-down and mirrored, but it is more or less in focus. This design can be elaborated in all sorts of ways (making a rigid frame, making a smooth and plane screen, adding smoke an mirrors..., sorry, lenses and mirrors to turn the image right-way up etc), but here's the basic camera. So what Daguerre did in 1839, was "merely" to develop light-sensitive chemicals to fix the image on glass plates. The camera itself was already available, and had been for centuries. Which, apparently, is a tautology from an ethymological point of view... Hey, this is fun! Rune
Rune Allnor wrote:> > Jerry Avins wrote: > >>Rune Allnor wrote: >> >>>Heyheyheyheyhey, you are light-years ahead of me... your CO was a >>>box with lense in the front end and a matt glass "projector screen" >>>in the rear end? >> >>No. That's what I'm suggesting for you; look at the pictures. > > > Hail, O Jerry! My salutes to the Great Wizard in the art of > Engineering! > The carboard-box camera works! > > I found a carboard box roughly the same length as the focal length > of my magnifying glass. I taped the lid shut and cut out the end > walls. I taped some waxed paper over one end, and stuck the magnifying > glass in the other. When pointing the box out in a lit area from a > dark room, I get a picture visible on the paper. > > The picture is upside-down and mirrored, but it is more or less in > focus. This design can be elaborated in all sorts of ways (making a > rigid frame, making a smooth and plane screen, adding smoke an > mirrors..., sorry, lenses and mirrors to turn the image right-way up > etc), but here's the basic camera. > > So what Daguerre did in 1839, was "merely" to develop light-sensitive > chemicals to fix the image on glass plates. The camera itself was > already available, and had been for centuries. Which, apparently, is > a tautology from an ethymological point of view... > > Hey, this is fun!It seems that after our mid-twenties is gets harder and harder to remember the things we did in physics classes at 11 or 12. :-) I agree it can be fun to relive them, though. I find it great fun trying to explain to my 5 and 7 years olds how things like this work. Its one of the more satisfying aspects of being a daddy. A large camera obscura (a pretty old device, though I'm not clear just how old. Aristotle is supposed to have used one.) in a suitably high location can be a fun way to while away a little time. Regards, Steve
Steve Underwood wrote:> Rune Allnor wrote: > > Hey, this is fun! > > It seems that after our mid-twenties is gets harder and harder to > remember the things we did in physics classes at 11 or 12. :-)As far as I can remember, we never did this in physics class. Growing up in Norway in the 70ies/80ies after we struck gold (well, oil) in the late 60ies, there were little money or resources for fun stuff at the lab. The only practical lab exercise I can remember from compulsary school, was collecting some insects in the woods. In "extension school" (intended for ages 16 -19) we did a little bit of chemistry, but little if any physics that did not involve expensive hard-to-get stuff like lasers, prisms and spectrometers. The charm of the camera obscura experiments is that they require nothing but inexpensive household items.> I agree > it can be fun to relive them, though. I find it great fun trying to > explain to my 5 and 7 years olds how things like this work. Its one of > the more satisfying aspects of being a daddy.I showed the camera obscura to my niese and nephew of ages 3 and 4. They understood the "upside-down" thing immediately (they were able to pcorrectly oint out heads and feet of persons in the image), although they were VERY curious about exactly what was inside the empty box.> A large camera obscura (a pretty old device, though I'm not clear just > how old. Aristotle is supposed to have used one.) in a suitably high > location can be a fun way to while away a little time.After having seen the thing in the works, I am pretty sure the camera obscura would have been around since before optics. It only takes a curved (focusing) mirror situated in a dark spot (a cave?). With that sort of kit, one would be able to see "real-world-related" images of the outer world, depending on how smooth the surface is and how close the curvature of the mirror is to a parabolic surface. I wouldn't be surprised if the camera obscura was known to the earliest cultures that used copper. What can be documented, is a compeletly different question.> Regards, > SteveRune
Rune Allnor wrote: ...> Hey, this is fun!And educational! Imagine a pinhole instead of a lens. Light from the top left of the scene falls at the bottom right of the screen when you face both at the same time. The image on the screen is both inverted (turned top for bottom) and reverted (turned left for right). Its handedness is unchanged. When you look at the screen from the inside of the box, you face away from the scene, interchanging left and right but not top for bottom, thereby reversing the handedness. A diagonal mirror in the box, the usual arrangement of a camera obscura used for sketching, puts the bottom of the image -- the top of the scene -- toward the front of the box, leaving left and right unchanged. Again, the image handedness is wrong. There are two ways to make a correct image. One of them is optical, and the simplest optical way is a second mirror. The other is even simpler. I leave both solutions to you for now. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Rune Allnor wrote: ...> After having seen the thing in the works, I am pretty sure the camera > obscura would have been around since before optics. It only takes a > curved (focusing) mirror situated in a dark spot (a cave?).A small hole in a wall (pinhole camera) is all that's needed.> With that > sort of kit, one would be able to see "real-world-related" images > of the outer world, depending on how smooth the surface is and > how close the curvature of the mirror is to a parabolic surface.A parabola is great on axis, but coma builds up rapidly off axis and astigmatism isn't far behind. A spherical mirror has spherical aberration everywhere, but in some configurations, neither coma nor astigmatism anywhere. For images more than a few degrees off axis (depending on the relative aperture) a spherical mirror is better. The archetypical amateur's home-made telescope mirror is a six-inch blank ground to a 48-inch focal length: f/8. The 200-inch telescope on Palomar Mountain is also f/8. Both have diffraction-limited fields approximately an inch in diameter. Paraboloids are not wide angle.> I wouldn't be surprised if the camera obscura was known to the > earliest cultures that used copper. What can be documented, is a > compeletly different question.Maybe so. It can be seen by those who know what they're looking at in the crescent patches of moonlight on the ground when the tree canopy overhead nearly blocks the moonlight. National Geographic Magazine had a picture, taken during the 1922 eclipse, of crescents on the ground under a tree. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
