(no subject)
Started by Habib ●July 18, 2005
32-bit floats can go down around 1e-38 in magnitude before going
denormal (about -750dB from peak). A least-significant bit of a 24-bit
integer is about 5e-8 (roughly -144dB). I use 1e-15 (roughly -300dB)
because it lies comfortably between the denormal rock and the 24-bit DAC
hard place. 300dB down from peak, I believe, won't ever be audible
(someone compared it to the magnitude of atomic vibration -- I don't
know if that's accurate).
I use a relatively low frequency square wave (flipping the bit once per
process() call) because that has both low freq and high freq content in
the signal. A highpass filter will tend to turn it into a pulse wave, a
lowpass will tend to turn it into a sine wave, and either way it gets
through - so you can inject it once and run it through a bunch of
filters and reverbs with little fear of it getting wiped out - you have
to flatten it 400dB more before it even starts to think about going
denormal, and it's broadband, so just lowpasses or just highpasses
aren't gonna do it.
Habib wrote:
> 32-bit floats can go down around 1e-38 in magnitude before going > denormal (about -750dB from peak). A least-significant bit of a 24-bit > integer is about 5e-8 (roughly -144dB). I use 1e-15 (roughly -300dB) > because it lies comfortably between the denormal rock and the 24-bit DAC > hard place. 300dB down from peak, I believe, won't ever be audible > (someone compared it to the magnitude of atomic vibration -- I don't > know if that's accurate).
That depends how loud you set your amplifier connected to the 32bit floating-point DAC (you need one that goes to eleven). I'm pretty sure that the band "Disaster Area" could make it audible in one of their concerts.
> I use a relatively low frequency square wave (flipping the bit once per > process() call) because that has both low freq and high freq content in > the signal. A highpass filter will tend to turn it into a pulse wave, a > lowpass will tend to turn it into a sine wave, and either way it gets > through - so you can inject it once and run it through a bunch of > filters and reverbs with little fear of it getting wiped out - you have > to flatten it 400dB more before it even starts to think about going > denormal, and it's broadband, so just lowpasses or just highpasses > aren't gonna do it.
Hotblack Desiato ain't gonna like it. :-) Regards, Andor
I'm sorry, this (original) post isn't mine, it's from KVR forum, written
by someone else. I did send it from my work account to my home account,
and suprisingly my email client did post it to comp.dsp (or I clicked
something wrong :-[).
PS. Is "Disaster Area" new band of "Spinal Top" guitarist ?
Andor wrote:
> Habib wrote: > > >>32-bit floats can go down around 1e-38 in magnitude before going >>denormal (about -750dB from peak). A least-significant bit of a 24-bit >>integer is about 5e-8 (roughly -144dB). I use 1e-15 (roughly -300dB) >>because it lies comfortably between the denormal rock and the 24-bit DAC >>hard place. 300dB down from peak, I believe, won't ever be audible >>(someone compared it to the magnitude of atomic vibration -- I don't >>know if that's accurate). > > > That depends how loud you set your amplifier connected to the 32bit > floating-point DAC (you need one that goes to eleven). I'm pretty sure > that the band "Disaster Area" could make it audible in one of their > concerts. > > >>I use a relatively low frequency square wave (flipping the bit once per >>process() call) because that has both low freq and high freq content in >>the signal. A highpass filter will tend to turn it into a pulse wave, a >> lowpass will tend to turn it into a sine wave, and either way it gets >>through - so you can inject it once and run it through a bunch of >>filters and reverbs with little fear of it getting wiped out - you have >>to flatten it 400dB more before it even starts to think about going >>denormal, and it's broadband, so just lowpasses or just highpasses >>aren't gonna do it. > > > Hotblack Desiato ain't gonna like it. > > :-) > > Regards, > Andor >
Habib wrote:
> I'm sorry, this (original) post isn't mine, it's from KVR forum, written > by someone else. I did send it from my work account to my home account, > and suprisingly my email client did post it to comp.dsp (or I clicked > something wrong :-[). > > PS. Is "Disaster Area" new band of "Spinal Top" guitarist ?
...and the question that dwarfs all others is: What is the connection between "a rock and a hard place" and Stonehenge? Soory. My imagination just clammed up. Rune
> Andor wrote: > > Habib wrote: > > > > > >>32-bit floats can go down around 1e-38 in magnitude before going > >>denormal (about -750dB from peak). A least-significant bit of a 24-bit > >>integer is about 5e-8 (roughly -144dB). I use 1e-15 (roughly -300dB) > >>because it lies comfortably between the denormal rock and the 24-bit DAC > >>hard place. 300dB down from peak, I believe, won't ever be audible > >>(someone compared it to the magnitude of atomic vibration -- I don't > >>know if that's accurate). > > > > > > That depends how loud you set your amplifier connected to the 32bit > > floating-point DAC (you need one that goes to eleven). I'm pretty sure > > that the band "Disaster Area" could make it audible in one of their > > concerts. > > > > > >>I use a relatively low frequency square wave (flipping the bit once per > >>process() call) because that has both low freq and high freq content in > >>the signal. A highpass filter will tend to turn it into a pulse wave, a > >> lowpass will tend to turn it into a sine wave, and either way it gets > >>through - so you can inject it once and run it through a bunch of > >>filters and reverbs with little fear of it getting wiped out - you have > >>to flatten it 400dB more before it even starts to think about going > >>denormal, and it's broadband, so just lowpasses or just highpasses > >>aren't gonna do it. > > > > > > Hotblack Desiato ain't gonna like it. > > > > :-) > > > > Regards, > > Andor > >
Rune wrote:
> ...and the question that dwarfs all others is: What is the > connection between "a rock and a hard place" and Stonehenge?
Nice pun with the dwarves :-)!
Oops.
Close :-). Actually, Hotblack Desiato is the guitarist of Disaster Area (but I'm sure he's also got one that goes to eleven). This is the band that is banned from most planets in our galaxy because their PA violates local disarmaments agreements.
Andor wrote:
> Rune wrote: > > > ...and the question that dwarfs all others is: What is the > > connection between "a rock and a hard place" and Stonehenge? > > Nice pun with the dwarves :-)!
Thanks. Do you know if there are more than one Spinal Tap movie? A couple of years ago, there was a video running on the cable networks where the line "I know, for I told me so" appeared. I didn't find it on the "Tis is Spinal Tap" DVD. Rune
There is the sequel "A Spinal Tap Reunion" (1992) which I haven't seen,
 a number of new short movies (20 - 25mins), plus some music videos.
Have a look in the internet movie database (http://www.imdb.com) under
"Spinal Tap".
I went to see the Hitchhiker's Guide movie a couple of days ago (which
inspired my reply to Habib). Too much romance, too little zest.
Regards,
Andor
Is it worth going to the cinema, compared to the old BBC series? Best regards, Andre -- Please change no_spam to a.lodwig when replying via email!
Andre wrote:
> Andor wrote: > > > I went to see the Hitchhiker's Guide movie a couple of days ago (which > >> inspired my reply to Habib). Too much romance, too little zest. > > > Is it worth going to the cinema, compared to the old BBC series? > > Best regards, > > Andre >
If you like the radio plays, or the books, or the BBC TV series, avoid the movie. Its awful. It follows the general story line of the other versions, reasonably changed to make it a 1.5 hour move. However, it omits all the jokes and social commentary that made the original interesting. Its like a hollow shell. Regards, Steve
