Hello, We are seeking a "light" algorithm performing exponential function (y=A*exp(-k*x)) fitting. A typical curve is composed of 200 16-bits integers. As the code should be executed by a MCU, fixed-point is preferable but if floating-point is required for accuracy reasons, it could also be implemented if the amount of calculation is compatible with a reasonable processing time (few hundreds ms). Did someone already implement such an algorithm or could provide us with references? Of course, a piece of C code would be ideal. Thanks and regards, -- Eric Meurville
Fixed-point algorithm for exponential function fitting for an embedded application
Started by ●July 20, 2005
Reply by ●July 20, 20052005-07-20
"Eric Meurville"> Hello, > > We are seeking a "light" algorithm performing exponential > function (y=A*exp(-k*x)) fitting. A typical curve is > composed of 200 16-bits integers. As the code should be > executed by a MCU, fixed-point is preferable but if > floating-point is required for accuracy reasons, it > could also be implemented if the amount of calculation is > compatible with a reasonable processing time (few hundreds > ms). > > Did someone already implement such an algorithm or could > provide us with references? Of course, a piece of C code > would be ideal. >Taking the logarithm of y(x) yields ln(y) = ln(A) - k*x from where you can apply e.g. a least-squares approximation: y = a*x + b # the mean values x_mean = sum(x) / n y_mean = sum(y) / n # the variances sx^2 = (sum(x*x)-(sum(x)^2)/n)/(n-1) sy^2 = (sum(y*y)-(sum(y)^2)/n)/(n-1) sxy = (sum(x*y)-n*x_mean*y_mean)/(n-1) # the coefficients a = sxy/sx^2 b = y_mean - a * x_mean # the correlation coeffiecient # +1 positive correlation (x++ => y++) # -1 negative correlation (x++ => y--) # 0 no correlation rxy^2 = sxy / (sx * sy) I hope I got the formulas right. Don't know whether there is something faster than that. Best regards to my old alma mater. I still have fond memories of my days there ... Martin
