Hi, We are developing a card with an ARM processor (PXA255) and a low cost Sharc chip (DSP and CPU in a single board). We want to use this card for a medical application. Does anyone know of a low cost dual processor card with a floating point dsp and the capability of running Linux on the host CPU? The Tiburon from Bittware is the only one I could find but it is too big, too expensive, and too complex. Regards, Ajith
Info Needed
Started by ●July 20, 2005
Reply by ●July 20, 20052005-07-20
ajith_pc@yahoo.com wrote:> Hi, > > We are developing a card with an ARM processor (PXA255) and a low cost > Sharc chip (DSP and CPU in a single board). We want to use this card > for a medical application. > > Does anyone know of a low cost dual processor card with a floating > point dsp and the capability of running Linux on the host CPU? The > Tiburon from Bittware is the only one I could find but it is too big, > too expensive, and too complex. >Both processors are supported by stand-alone evaluation boards by the respective IC manufacturers (ADI/Intel). I know the SHARC (EZ-KIT) boards bring I/O pins off-chip that allow interconnect to another board. I am guessing the Intel ARM eval board does too. good luck, Dan Ash
Reply by ●July 21, 20052005-07-21
Thanks for your reply. I was looking for a board which contains both floating point DSP device and a CPU (both DSP and CPU in a single board). But we have not found any thing similar. So we started developing one for our purpose. By integrating the DSP and CPU, one can achieve the display and/or I/O capability of CPU and the number crunching ability of DSP, but not found any one off the shelf. Any opinions or suggestions? Regards, Ajith Daniel A. Ash wrote:> ajith_pc@yahoo.com wrote: > > Hi, > > > > We are developing a card with an ARM processor (PXA255) and a low cost > > Sharc chip (DSP and CPU in a single board). We want to use this card > > for a medical application. > > > > Does anyone know of a low cost dual processor card with a floating > > point dsp and the capability of running Linux on the host CPU? The > > Tiburon from Bittware is the only one I could find but it is too big, > > too expensive, and too complex. > > > > Both processors are supported by stand-alone evaluation boards by the > respective IC manufacturers (ADI/Intel). I know the SHARC (EZ-KIT) > boards bring I/O pins off-chip that allow interconnect to another board. > I am guessing the Intel ARM eval board does too. > > good luck, > > Dan Ash
Reply by ●July 26, 20052005-07-26
Ajith, Read the manuals for both evaluation boards and determine if there is an easy way to prototype with existing hardware, or at most, designing only the interface boards to "glue" the two together. Once you have debugged the prototype, then you can proceed with designing custom hardware. regards, Dan ajith_pc@yahoo.com wrote:> Thanks for your reply. I was looking for a board which contains both > floating point DSP device and a CPU (both DSP and CPU in a single > board). But we have not found any thing similar. So we started > developing one for our purpose. > By integrating the DSP and CPU, one can achieve the display and/or I/O > capability of CPU and the number crunching ability of DSP, but not > found any one off the shelf. Any opinions or suggestions? > > Regards, > Ajith > > > > Daniel A. Ash wrote: > >>ajith_pc@yahoo.com wrote: >> >>>Hi, >>> >>>We are developing a card with an ARM processor (PXA255) and a low cost >>>Sharc chip (DSP and CPU in a single board). We want to use this card >>>for a medical application. >>> >>>Does anyone know of a low cost dual processor card with a floating >>>point dsp and the capability of running Linux on the host CPU? The >>>Tiburon from Bittware is the only one I could find but it is too big, >>>too expensive, and too complex. >>> >> >>Both processors are supported by stand-alone evaluation boards by the >>respective IC manufacturers (ADI/Intel). I know the SHARC (EZ-KIT) >>boards bring I/O pins off-chip that allow interconnect to another board. >> I am guessing the Intel ARM eval board does too. >> >>good luck, >> >>Dan Ash > >
Reply by ●July 27, 20052005-07-27
Thank you Daniel. We are working for it, almost integrated the DSP and PXA 255 in a single board. Regards, Ajith Daniel A. Ash wrote:> Ajith, > > Read the manuals for both evaluation boards and determine if there is an > easy way to prototype with existing hardware, or at most, designing only > the interface boards to "glue" the two together. Once you have debugged > the prototype, then you can proceed with designing custom hardware. > > regards, > > Dan > > > ajith_pc@yahoo.com wrote: > > Thanks for your reply. I was looking for a board which contains both > > floating point DSP device and a CPU (both DSP and CPU in a single > > board). But we have not found any thing similar. So we started > > developing one for our purpose. > > By integrating the DSP and CPU, one can achieve the display and/or I/O > > capability of CPU and the number crunching ability of DSP, but not > > found any one off the shelf. Any opinions or suggestions? > > > > Regards, > > Ajith > > > > > > > > Daniel A. Ash wrote: > > > >>ajith_pc@yahoo.com wrote: > >> > >>>Hi, > >>> > >>>We are developing a card with an ARM processor (PXA255) and a low cost > >>>Sharc chip (DSP and CPU in a single board). We want to use this card > >>>for a medical application. > >>> > >>>Does anyone know of a low cost dual processor card with a floating > >>>point dsp and the capability of running Linux on the host CPU? The > >>>Tiburon from Bittware is the only one I could find but it is too big, > >>>too expensive, and too complex. > >>> > >> > >>Both processors are supported by stand-alone evaluation boards by the > >>respective IC manufacturers (ADI/Intel). I know the SHARC (EZ-KIT) > >>boards bring I/O pins off-chip that allow interconnect to another board. > >> I am guessing the Intel ARM eval board does too. > >> > >>good luck, > >> > >>Dan Ash > > > >
