Hi. I'm writting a code to do a FFT using fixed point(16 bits). Well this is the question What is the better, make the sacaling after or before start a pass. I think that is better before start a pass. This is correct? Diego
scaling in a fixed point FFT
Started by ●July 24, 2005
Reply by ●July 24, 20052005-07-24
DX wrote:> Hi. > > I'm writting a code to do a FFT using fixed point(16 bits). Well this > is the question What is the better, make the sacaling after or before > start a pass. I think that is better before start a pass. This is > correct?Processor? -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●July 25, 20052005-07-25
| I'm writting a code to do a FFT using fixed point(16 bits). Well this | is the question What is the better, make the sacaling after or before | start a pass. I think that is better before start a pass. This is | correct? | If results are divided by two to avoid overflow at each stage (like the code I use) You better scale your input buffer before processing the FFT. Of course it depends of the precision you need !
Yes, it depends about the presicion, but it depends about the dsp's features to. The problem is that I have to use fixed point and the registers has 16 bits to represent a fixed point, and if I don't scale the data they overflow the registers. Thank you. Diego
Reply by ●September 28, 20052005-09-28
Hi, It's better to do the scaling inside the FFT when the intermediate results have grown. Or even better do a data dependent scaling inside the FFT when needed. Best regards, Jens J. Nielsen http:/home.get2net.dk/jjn On 25 Jul 2005 13:48:53 -0700, "DX" <diux007@gmail.com> wrote:>Yes, it depends about the presicion, but it depends about the dsp's >features to. >The problem is that I have to use fixed point and the registers has 16 >bits to represent a fixed point, and if I don't scale the data they >overflow the registers. > >Thank you. > >Diego
