Well, for better or for worse, I just sent this off:
27July05
Ted Koppel,
As I write this, I'm listening to Nightline and the discussion of the
grounded shuttle fleet. I think I know how to fix the shuttle problem,
but I no longer know a way to contact someone at NASA.
I constructed the audio module for the Mercury space capsule; there were
several independent radio transmitters and receivers, but all voice
communications went through my box. I was driving on the Belt Parkway
when all communications with the capsule were lost during the first
re-entry. My first thought was "My God! My box!", then the brain kicked
into gear. The last communication had been about a strange glow. I got
off the parkway at Coney Island avenue, found a phone booth, raised the
operator, and told her that I needed to talk to Mission Control about
the emergency. No other information proved necessary. Someone in the
control room answered the phone less than a minute later. I opined that
the glow had been a plasma that, when fully developed, shorted out all
the antennas. He thanked me, agreed that I had probably identified the
cause, and told me that signals from the capsule seemed to be returning.
I thanked him and rang off. The news of the blackout's end had not yet
reached my car radio when I got back to it, but it did shortly after.
It was an incredible experience that could only have happened then. The
whole country seemed to be focused on that one event. Times are
different now. How can I pass my ideas to the right people. They may not
work, but they're worth considering. I have a lifetime's experience
making things work.
Jerry Avins
Engineering is the art of making what you want from things you can get.
Shuttle insulation
Started by ●July 28, 2005
Reply by ●July 28, 20052005-07-28
Great story Jerry. The standard way of approaching NASA will probably fail. So release your ideas publicly and let the media rub NASA's noses in it to the point where they will have to consider your ideas. Find out who the science editors are for various media outlets and approach them. It can't be worse than doing nothing at all. Contact "Air and Space" magazine. They are a Smithsonian derivative. Clay
Hi Jerry> I opined that > the glow had been a plasma that, when fully developed, shorted out all > the antennas. He thanked me, agreed that I had probably identified the > cause, and told me that signals from the capsule seemed to be returning.I often wondered what caused the radio 'blackout'. Knew it was when the plasma glow appeared, but I always assumed that the plasma itself generated RF hash. Now I really know the answer. Coincidentally, I operate one of the six control stations worldwide for the MISSE5 experiment that's on board the Shuttle right now. The astronauts are scheduled to fit it to the outside of the ISS on one of the EVA's next week. As such I do have communications directly with NASA personel, mainly at JSC, but I would have no idea how you would get your ideas to the right person: as you know NASA's a big organisation. Email me off list if you'd like - remove the 'xxx' from the return address. Kind Regards, Howard
Clay wrote:> Great story Jerry. > > The standard way of approaching NASA will probably fail. So release > your ideas publicly and let the media rub NASA's noses in it to the > point where they will have to consider your ideas. Find out who the > science editors are for various media outlets and approach them. It > can't be worse than doing nothing at all. Contact > "Air and Space" magazine. They are a Smithsonian derivative.OK. I'll start here. Part of the difficulty is that NASA is trying to solve the wrong problem. They WANT to make the foam adhere better, but events have shown that to be too ambitious a goal. What they NEED is to keep it from falling off; that's a different problem with a wider range of solutions. Here are some: Broad-headed nails (roofing nails) welded to the tank on the intersections of a two-inch grid. The foam will be held in place by the embedded heads or, is torn off violently enough, broken into small -- hence harmless -- pieces. Light plastic netting embedded in the foam, much like lath holding plaster. Somebody isn't thinking about composite materials. Plastic netting stretched around the outside of foam already in place. I have in my hand netting that was once a bag of onions. It is a tube with the ends clipped shut. What the netting needs to do is hold loose pieces in place against the force of acceleration. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> Well, for better or for worse, I just sent this off: ><snip>> Jerry Avins > -- > Engineering is the art of making what you want from things you can get. >Jerry, Curious timing, Shuttle Challenger having exploded 19 years ago today. Several engineers from the support team at Bendix Field Engineering were gathered in a darkened office to watch the Challenger launch on TV. To our shock and horror the terrible events unfolded, leaving us numbed. As we were dispersing, a fellow engineer (a Shuttle ground communications specialist with access to the shuttle) ran into the building to watch the launch, having been delayed on his drive from Goddard Space Flight Center. Seeing our faces he asked what had happened. When we told him that Challenger had exploded he said, "My God, I hope it wasn't the seals." My point is that, if the seal problem was well enough known by a specialist in an unrelated (electronics vs. mechanical) area, it was pretty obviously broadly known to any number of support engineers in NASA, a fact which didn't come out in the press or any of the hearings that I watched. Good luck in communicating with an ostrich whose head is buried in the sand. You only havc access to one orfice. Regards, Ken Asbury =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF
Ken Asbury wrote:> Curious timing, Shuttle Challenger having exploded 19 years ago today. >Not /that/ curious. The Challenger disaster occurred January 31, 1986. That's more like 19.5 years ago today. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Nothing is ever so bad that it can't get worse. - Calvin
Jerry Avins wrote:> Plastic netting stretched around the outside of foam already in place. I > have in my hand netting that was once a bag of onions. It is a tube with > the ends clipped shut. What the netting needs to do is hold loose > pieces in place against the force of acceleration. >That's the same idea I had, but then what would you do with all those onions? ;-) An even better solution would be to put the payload on the top (a la Saturn V) so that when pieces break off, they can't do any damage. I guess that depends on how you define "better" though. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Nothing is ever so bad that it can't get worse. - Calvin
Jim Thomas wrote:> Jerry Avins wrote: > >> Plastic netting stretched around the outside of foam already in place. >> I have in my hand netting that was once a bag of onions. It is a tube >> with the ends clipped shut. What the netting needs to do is hold >> loose pieces in place against the force of acceleration. >> > > That's the same idea I had, but then what would you do with all those > onions? ;-) > > An even better solution would be to put the payload on the top (a la > Saturn V) so that when pieces break off, they can't do any damage. I > guess that depends on how you define "better" though. >The foam is there to eliminate the build up of ice that condenses from water vapor in the air onto a tank containing cryogenic liquids. Move the launch site to Death Valley or some other desert. Low humidity -> less condensate -> less insulation -> less things to fall off.
Jim Thomas wrote:> ... what would you do with all those onions? ;-)That calls for the Saga of the Greengrocer and the Dowager. During WW II, when shortages were the norm and some shopkeepers held back goods for regular customers or the black market, a lady went to the vegetable store and asked for five pounds of onions. then followed: GG: I'm sorry, we're all out of onions. Lady: OK. Let me have half a pound. GG: I told you, we DON'T HAVE ANY. Lady: Give me one then. GG: What do you get if you take the melon out of watermelon? Lady (puzzled): Err... Water? GG: Right! What do you get if you honey out of honeydew? Lady (surer now): Dew. GG: What do you get if you take the fuck out of onions? Lady (puzzled again) But there's no fuck in onions...* GG: Lady, THAT'S WHAT I'VE BEEN TRYING TO TELL YOU! Jerry __________________________________ * This only works when spoken. -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Thu, 28 Jul 2005 12:57:46 -0400, Stan Pawlukiewicz <spam@spam.mitre.org> wrote:>Jim Thomas wrote: >> Jerry Avins wrote: >> >>> Plastic netting stretched around the outside of foam already in place. >>> I have in my hand netting that was once a bag of onions. It is a tube >>> with the ends clipped shut. What the netting needs to do is hold >>> loose pieces in place against the force of acceleration.It's a good idea, but I'd like to think they (the engineers) thought of it or something like it, actually I'd bet on something like that having been considered. I'd like to think the managers gave such ideas due consideration, but I wouldn't bet on that.>> That's the same idea I had, but then what would you do with all those >> onions? ;-)Don't send them to the ISS, they have enough problems!>> >> An even better solution would be to put the payload on the top (a la >> Saturn V) so that when pieces break off, they can't do any damage. I >> guess that depends on how you define "better" though. >> >The foam is there to eliminate the build up of ice that condenses from >water vapor in the air onto a tank containing cryogenic liquids. MoveWhy are they having this problem still? I recall last winter they were aiming for a June 15th launch, they put some heater at the top of the tank so ice wouldn't form. They rolled the thing back into the VAB to change the tank to one that had a heater already installed, or something like that. I recall this was supposed to eliminate the need for an insulating blanket.>the launch site to Death Valley or some other desert. Low humidity -> >less condensate -> less insulation -> less things to fall off.Weren't shuttles at one time going to be launched from Vandenburg (sp?) Air Force Base in California (is Vandenburg anywhere near a desert?)? I'm sure they'd have a lot of logistics to do that, fly the shuttle out there on a 747, probably need to make a Vehicle Assembly Building out there too. But the closer the launch site is to the Equator, the better it takes advantage of the Earth's rotation, and Florida is better for that. So as always there's a bunch of tradeoffs. ----- http://www.mindspring.com/~benbradley
