Dear All, I have one problem in real time signal processing. My signal frequency is 4000Hz and the sampling frequency is 8000Hz. Actually it should be more than 8KHz. Becasue of that i am loosing the zero resting points of the sampled signal. With out increasing the sampling frequency , is there any remedy for avoiding the information loss ? Thanking you,
Problem in Sampling
Started by ●August 13, 2004
Reply by ●August 13, 20042004-08-13
Sai Kumar wrote:> Dear All, > > > I have one problem in real time signal processing. My signal frequency is > 4000Hz and the sampling frequency is 8000Hz. Actually it should be more than > 8KHz. > > Becasue of that i am loosing the zero resting points of the sampled signal. > > With out increasing the sampling frequency , is there any remedy for > avoiding the information loss ? > > Thanking you, > > > >If your signal is centered around 4000Hz but is sufficiently low bandwidth you can sample at 7000Hz and get very good reconstruction. But if your signal is DC to 4000Hz you're out of luck (but at least you're also saved from esoteric undersampling schemes). -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Hi Tim,
Thank you,
But i am unlucky as u said.
"Sai Kumar" <saikumar.s@in.bosch.com> wrote in message
news:cfheji$cv6$1@ns1.fe.internet.bosch.com...
> Dear All,
than
> 8KHz.
signal.
> Thanking you,
On Fri, 13 Aug 2004 09:33:33 +0530, "Sai Kumar" <saikumar.s@in.bosch.com> wrote:>Dear All, > > >I have one problem in real time signal processing. My signal frequency is >4000Hz and the sampling frequency is 8000Hz. Actually it should be more than >8KHz. > >Becasue of that i am loosing the zero resting points of the sampled signal. > >With out increasing the sampling frequency , is there any remedy for >avoiding the information loss ? > >Thanking you,Hi, your post sounds like you're sampling an analog 4 kHz pure tone (although you didn't actually describe your signal in a meaningful way), at a sample rate of 8000 samples per second. Is that really what you're doing? [-Rick-]
Rick Lyons wrote:> > On Fri, 13 Aug 2004 09:33:33 +0530, "Sai Kumar" > <saikumar.s@in.bosch.com> wrote: > > >Dear All, > > > > > >I have one problem in real time signal processing. My signal frequency is > >4000Hz and the sampling frequency is 8000Hz. Actually it should be more than > >8KHz. > > > >Becasue of that i am loosing the zero resting points of the sampled signal. > > > >With out increasing the sampling frequency , is there any remedy for > >avoiding the information loss ? > > > >Thanking you, > > Hi, > your post sounds like you're sampling > an analog 4 kHz pure tone (although you didn't actually > describe your signal in a meaningful way), at a > sample rate of 8000 samples per second. > > Is that really what you're doing?Well, no he can't be doing that. He can't produce a perfectly pure tone at exactly a steady 4KHz and he can't sample at a perfectly steady 8KHz either. But that appears to be what he is trying to do, and now he is wondering why he can't land his samples exactly on the zero state of each wave. Or, maybe he is asking something else - who knows? -jim -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Sai Kumar wrote:> Hi Tim, > Thank you, > But i am unlucky as u said. > > "Sai Kumar" <saikumar.s@in.bosch.com> wrote in message > news:cfheji$cv6$1@ns1.fe.internet.bosch.com... > >>Dear All, >> >> >>I have one problem in real time signal processing. My signal frequency is >>4000Hz and the sampling frequency is 8000Hz. Actually it should be more > > than > >>8KHz. >> >>Becasue of that i am loosing the zero resting points of the sampled > > signal. > >>With out increasing the sampling frequency , is there any remedy for >>avoiding the information loss ? >> >>Thanking you, >> >> >> >> > > >If your signal really has significant components from 0 to 4000Hz then you have no choice but to sample at greater than 8000Hz -- with real anti-aliasing filters you'll probably need to go much higher (16kHz would not be out of line). I think you need to describe your problem more fully if you want help with it. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●August 15, 20042004-08-15
Hi Kumar - so you have frequencies between +/- 4000Hz present and you are (complex?) sampling at 8000 samples per second ? Why not filter prior to sampling so you only have a small amplitude for frequencies around +/- 4kHz and above? "Sai Kumar" <saikumar.s@in.bosch.com> wrote in message news:cfhi5q$otm$1@ns1.fe.internet.bosch.com...> Hi Tim, > Thank you, > But i am unlucky as u said. > > "Sai Kumar" <saikumar.s@in.bosch.com> wrote in message > news:cfheji$cv6$1@ns1.fe.internet.bosch.com... > > Dear All, > > > > > > I have one problem in real time signal processing. My signal frequencyis> > 4000Hz and the sampling frequency is 8000Hz. Actually it should be more > than > > 8KHz. > > > > Becasue of that i am loosing the zero resting points of the sampled > signal. > > > > With out increasing the sampling frequency , is there any remedy for > > avoiding the information loss ? > > > > Thanking you, > > > > > > > > > >
