I am trying to generate a test waveform which is compatible with the ATSC standard. I am obtaining the MPEG packets from a TV clip obtained from the web. I am ensuring that the MPEG packet frame rate of the transport stream packets is compatible with the ATSC standard. The waveform is converted from IQ -->RF and fed into a set top box, which decodes the signal and feeds the DVI output into a monitor. When I generate the RF signal at a TV frequency (i.e. 584.25 Mhz), the set-top box indicates receipt of a broadcast signal but does not display the actual video corresponding to the MPEG packets which constitute the RF signal. Also, the RSSI (received signal strength indicator) shows only a weak signal and very occasionally shows receipt of a strong signal... The RF waveform is being played out of the arb (arbitrary waveform generator) in a looping mode i.e. the waveform samples are played out of a circular buffer. My suspicion is that the set-top box gets confused when the RF signal loops back and the MPEG packets go out of sequence...Further, all the downstream processing namely descrambling, Reed-Solomon decoding, convolutional de-intereleaving and trellis decoding may get affected due to the loop-back in the arb buffer... Is anyone aware of any easy way to trick a set-top box to display a TV signal from MPEG packets using an arbitrary waveform generator??How do I improve the signal quality going into the box? Any help would be greatly appreciated. Regards Vikram
Phase continuous waveform generation for ATSC (N.American Digital TV standard).
Started by ●August 5, 2005
Reply by ●August 5, 20052005-08-05
In alt.tv.tech.hdtv cvikram@mac.com wrote: | The RF waveform is being played out of the arb (arbitrary waveform | generator) in a looping mode i.e. the waveform samples are played out | of a circular buffer. My suspicion is that the set-top box gets | confused when the RF signal loops back and the MPEG packets go out of | sequence...Further, all the downstream processing namely descrambling, | Reed-Solomon decoding, convolutional de-intereleaving and trellis | decoding may get affected due to the loop-back in the arb buffer... if it just cuts off and loops back in the middle of the data segments or data frames, it's probably never going to get back in sync. | Is anyone aware of any easy way to trick a set-top box to display a TV | signal from MPEG packets using an arbitrary waveform generator??How do | I improve the signal quality going into the box? You need to be sure it fully conforms to ATSC even at the loop back point. An ATSC generator is likely needed. -- ----------------------------------------------------------------------------- | Phil Howard KA9WGN | http://linuxhomepage.com/ http://ham.org/ | | (first name) at ipal.net | http://phil.ipal.org/ http://ka9wgn.ham.org/ | -----------------------------------------------------------------------------
How long is the loop before it repeats? You may have other issues, there are a lot of MPEG layer things that have to be right for the STB to diplay video, like PSIP info and PID numbers etc. Do you have the correct DIGITAL RF center frequency?... the RF freq you listed sounds like an analog video carrier frequency. There can be confusion about RF freqs. Analog TV uses the video carrier freq. Digital CATV (64 or 256 QAM) uses the center freq of the channel I'm not sure what over the air digital uses (8VSB) it may use the pilot carrier frequency or it may use the center frequency or something else??? If your not getting RSSI, you very well may have the wrong RF frequency dialed in. Mark
In alt.tv.tech.hdtv Mark <makolber@yahoo.com> wrote: | I'm not sure what over the air digital uses (8VSB) it may use the pilot | carrier frequency or it may use the center frequency or something | else??? There is a specific frequency offset from the lower end of the channel. I read it in one of the documents but didn't need to remember it's exact value right now (but it is based on some multiples to minimize adjacent channel interference). But I suspect it should work at any frequency as long as the relationships are correct. -- ----------------------------------------------------------------------------- | Phil Howard KA9WGN | http://linuxhomepage.com/ http://ham.org/ | | (first name) at ipal.net | http://phil.ipal.org/ http://ka9wgn.ham.org/ | -----------------------------------------------------------------------------
Phil/Mark Thanks for the reply. I am pretty sure that I have the RF frequency correctly dialed in. In fact, I tuned into the ABC/KVUE station here in Austin that transmits its programs digitally using the ATSC standard at this center frequency (584.25 Mhz). The ATSC standard employs the 8-VSB modulation which is pilot assisted; the pilot is transmitted at the suppressed carrier frequency and located at 310 Khz to the right of the band-edges [a total of 6 Mhz bandwidth]. However, I think that the problem is associated with the looping time. The time for which I am transmitting the MPEG stream is 6.59 seconds after which the waveform loops back... Now, the tuner may have its own tuning time followed by which it attempts to perform MPEG decoding. I see a lot of havoc being caused in MPEG decoding as a result of the loopback. Is there any way to set some MPEG header information to inform the MPEG receiver decoder about the phase discontinuity... Vikram
cvikram@mac.com wrote:> Phil/Mark > Thanks for the reply. > > I am pretty sure that I have the RF frequency correctly dialed in. In > fact, I tuned into the ABC/KVUE station here in Austin that transmits > its programs digitally using the ATSC standard at this center frequency > (584.25 Mhz). > > The ATSC standard employs the 8-VSB modulation which is pilot assisted; > the pilot is transmitted at the suppressed carrier frequency and > located at 310 Khz to the right of the band-edges [a total of 6 Mhz > bandwidth]. > > However, I think that the problem is associated with the looping time. > The time for which I am transmitting the MPEG stream is 6.59 seconds > after which the waveform loops back... > > Now, the tuner may have its own tuning time followed by which it > attempts to perform MPEG decoding. I see a lot of havoc being caused in > MPEG decoding as a result of the loopback. > > Is there any way to set some MPEG header information to inform the MPEG > receiver decoder about the phase discontinuity... > > VikramOK, the STB is Receiving on the correct RF frequency... what RF frequency is the ARB waveform gen set to transmit on? Did you set the generator to 584.25 MHz? That would probably NOT be correct. Can you compare the KVUE singal and your singal on a spectrum analyzer? Mark
I'm going to guess that you need to set the AWG to 583.310 MHz which is the supressed carrier freq. thats 584.25 - 1.25 = the lower band edge = 583 MHz 583 + 0.310 = 583.310 I'm not sure this is correct. Mark
Reply by ●August 6, 20052005-08-06
<cvikram@mac.com> wrote in message news:1123223473.886421.91120@f14g2000cwb.googlegroups.com...>I am trying to generate a test waveform which is compatible with the > ATSC standard. I am obtaining the MPEG packets from a TV clip obtained > from the web. I am ensuring that the MPEG packet frame rate of the > transport stream packets is compatible with the ATSC standard. The > waveform is converted from IQ -->RF and fed into a set top box, which > decodes the signal and feeds the DVI output into a monitor. > > When I generate the RF signal at a TV frequency (i.e. 584.25 Mhz), the > set-top box indicates receipt of a broadcast signal but does not > display the actual video corresponding to the MPEG packets which > constitute the RF signal. Also, the RSSI (received signal strength > indicator) shows only a weak signal and very occasionally shows receipt > of a strong signal... > > The RF waveform is being played out of the arb (arbitrary waveform > generator) in a looping mode i.e. the waveform samples are played out > of a circular buffer. My suspicion is that the set-top box gets > confused when the RF signal loops back and the MPEG packets go out of > sequence...Further, all the downstream processing namely descrambling, > Reed-Solomon decoding, convolutional de-intereleaving and trellis > decoding may get affected due to the loop-back in the arb buffer...Instead of looping, can you just go up and down through the sequence? For example, instead of 1 2 3 4 1 2 34 how about 1 2 3 4 3 2 1 2 3 4 etc.> > Is anyone aware of any easy way to trick a set-top box to display a TV > signal from MPEG packets using an arbitrary waveform generator??How do > I improve the signal quality going into the box? > > Any help would be greatly appreciated. > > Regards > Vikram >
