Hi Everybody!!! Just got a new kit from Spectrum Digital with TMS320DM642 chip... model TMDSEVM642 with TVP Video Decoders... (EVMDM642 - 720 MHz version) and I have some doubts about plugging it into the PC... First: what exactly is JTAG? what is it for? what I understood is the following: I need a JTAG emulator to use the board with pc (like this one: http://emulators.spectrumdigital.com/)... this emulator can use the parallel port or USB (they cost a lot!!!)... but if I plug it directly to PCI slot, or use the ethernet port, I don't need this emulator... Is that it? Another thing: does anyone know where to find more document sources for this equipment? Thanks a lot!!! Bye! This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Connecting DM642 EVM board to the PC
Started by ●August 8, 2005
Reply by ●August 9, 20052005-08-09
julianoys wrote:> > what I understood is the following: I need a JTAG emulator to use the > board with pcYes. The JTAG emulator lets you program, control and debug your DSP system.> this emulator can use the parallel port or USB (they cost a lot!!!)... but > if I plug it directly to PCI slot, or use the ethernet port, I don't need > this emulator...No. You still need to use JTAG for programming and debugging. Your program can use the PCI or Ethernet in any way it likes, but without JTAG you can't get your program onto the target. Typically, you would have your card in one PC, and run your compiler/ debugger (Code Composer Studio) on another PC connected to the JTAG emulator. The "target" system (DSP+PC) would run your software while the "host" PC would be used for debugging.> Another thing: does anyone know where to find more document sources for > this equipment?TI produce a huge amount of documents and app notes. www.dspvillage.com would be a good place to start. Cheers mark-r -- "Let's meet the panel. You couldn't ask for four finer comedians - so that answers your next question..." -- Humphrey Lyttleton
Reply by ●August 10, 20052005-08-10
>TI produce a huge amount of documents and app notes. www.dspvillage.com >would be a good place to start. > >Cheers > >mark-rTo be more precise try these documents: 1] Emulation Fundamentals for TI 's DSP Solutions (Rev. B) (spra439b.htm, 0 KB) 16 May 2002 Abstract 2] spra823a.pdf --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●August 11, 20052005-08-11
First of all, thanks mark-r and Bhooshan for your replies... I've already worked with TMS320VC5402 DSK... I've just checked some info, and I've found out that this DSK has an embedded JTAG emulator... The DSK board had a parallel connector from which I used a cable (included in the DSK package) and connected to the pc parallel port for uploading and debuggind procedures through Code Composer Studio as told in the DSK manual... "The DSK provides embedded JTAG emulation that is accessible via the IEEE-1284 parallel port interface, as well as support for an external XDS510 emulator. The selected JTAG method is user- configurable via DIP switch 1. TMS320C5402 DSK Help (SPRH075A)" Now, this new DSP board I'm working (TMS320DM642 Evaluation Module with TVP Video Decoders) seems to have no embedded JTAG emulator, just a JTAG (14 pin) connector... "A typical development system includes a target board, a JTAG emulator and a copy of TI's Code Composer Studio IDE. Developer Starter Kits (DSKs) include entry-level versions of an embedded JTAG emulator and Code Composer Studio that only work with the DSK board itself. Evaluation modules (EVMs) require an external JTAG emulator and full Code Composer Studio and are suitable for engineers designing their own hardware. http://c6000.spectrumdigital.com/" This would mean I need to buy a JTAG Emulator... My doubt is: The EVM board have a PCI slot connector, an Ethernet connector and a serial port... (I really don't know yet what they are used for...) couldn't I use one of them along with Code Composer Studio and use it without needing to buy an external JTAG Emulator? I mean... Do I need to buy a JTAG Emulator??? I need to begin working with this device, but I don't even know how to plug it into the pc!!! Thanks for the attention guys!!! This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Hello there again... I've done some more research over the net and found some interesting posts about my doubt about using the PCI interface instead of buying a JTAG emulator... if I understood them correctly and I'm not saying studid things... They account for a DM642 PCI loader... one of them says that Texas has a library that does that... could someone please explain about this for me??? http://www.dsprelated.com/groups/c6x/show/3789.php http://www.dsprelated.com/groups/c6x/show/3399.php http://61ic.com/download/DSP/TI/200501/606.html http://focus.ti.com/catalog/docs/thirdpartysoftwarefolder.tsp?softwareId=4459 Thanks!!! This message was sent using the Comp.DSP web interface on www.DSPRelated.com
