Phil Newman Aug 10, 10:05 am show options I have a pure tone sine-wave signal of amplitude 1 and frequency 1. I have additional white noise signal added to this pure tone signal. The white noise is specified as Noise Power, and simulink defines this as the height of the Power Spectral Density of the white noise. (in this case it is set to 0.02) Can anyone help me with calculating the SNR of the resulting signal? I currently have SNR =3D 10*log10(sum(abs(Signal).^2)/s=ADum(abs(Noise).^2)) but the units for PSD are watts per hertz - can this calculate? Phil
SNR in Simulink
Started by ●August 11, 2005
Reply by ●August 11, 20052005-08-11
Phil Newman wrote:> Phil Newman Aug 10, 10:05 am show options > > I have a pure tone sine-wave signal of amplitude 1 and frequency 1. I > have additional white noise signal added to this pure tone signal. > > > The white noise is specified as Noise Power, and simulink defines this > as the height of the Power Spectral Density of the white noise. (in > this case it is set to 0.02) > > > Can anyone help me with calculating the SNR of the resulting signal? > > > I currently have > > > SNR = 10*log10(sum(abs(Signal).^2)/s�um(abs(Noise).^2)) > > > but the units for PSD are watts per hertz - can this calculate? > > > PhilYou also need to know the noise bandwidth then (watts/Hz)*(BW)= watts. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●August 12, 20052005-08-12
well, the only other information I have is that the sampling time is 1. Which infers that the bandwidth is 1Hz?
Phil Newman wrote:> well, the only other information I have is that the sampling time is 1. > Which infers that the bandwidth is 1Hz?No. At most 1/2 (units unspecified), but cutting it that close will put you in trouble for many things. For a noise calculation it will only make the result a little pessimistic. If you don't know that the sample rate must exceed twice the bandwidth, some catch-up reading is indicated. There's a tutorial and a bibliography at http://dspguru.com/. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Ah well, I know I appear to be lacking in knowledge, but not that much! thanks for the help Phil "Jerry Avins" <jya@ieee.org> wrote in message news:jYidnWu06bi9JGHfRVn-jQ@rcn.net...> Phil Newman wrote: >> well, the only other information I have is that the sampling time is 1. >> Which infers that the bandwidth is 1Hz? > > No. At most 1/2 (units unspecified), but cutting it that close will put > you in trouble for many things. For a noise calculation it will only make > the result a little pessimistic. > > If you don't know that the sample rate must exceed twice the bandwidth, > some catch-up reading is indicated. There's a tutorial and a bibliography > at http://dspguru.com/. > > Jerry > -- > Engineering is the art of making what you want from things you can get. > �����������������������������������������������������������������������
Philip Newman wrote:> Ah well, I know I appear to be lacking in knowledge, but not that much! > > thanks for the helpYou're welcome. I believe you, but you had me wondering. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins <jya@ieee.org> wrote:>Phil Newman wrote:>> well, the only other information I have is that the sampling >> time is 1. Which infers that the bandwidth is 1Hz?> No. At most 1/2 (units unspecified), but cutting it that > close will put you in trouble for many things. For a noise > calculation it will only make the result a little pessimistic.> If you don't know that the sample rate must exceed twice > the bandwidth, some catch-up reading is indicated. There's a > tutorial and a bibliography at http://dspguru.com/.Essential knowledge, but not needed to calculate the SNR of this signal. It's simulink, so you can easily measure the RMS value of the sine wave (which should be 1), and the RMS value of the noise signal (which may be 0.02). Do this by running a comfortably large number N of samples and calculating RMS = sqrt((sum over t) s(t)^2 / N). Divide these two to get your SNR. To express it in dB take 20log10() of the result. Steve
Reply by ●August 15, 20052005-08-15
