how to solve a differential equation with impulse input?
Started by kiki ●August 15, 2005
Differential equation such as a simple first order non-homogeous equation:
y'(t)+2*y(t) = x(t),
now x(t)=delta(t), since I want to find the impulse response of this system
to the impulse input.
I did not find this in Oppeheim's Signal & Systems book... that's very
strange. I am very confused by his "initial rest condition" arguement.
Can anybody show some rules about solving diff equation with impulse input
in general? And point me to some resources?
Thanks a lot!
> Differential equation such as a simple first order non-homogeous equation: > > y'(t)+2*y(t) = x(t),
are you sure this is the right equation ? asuming you were sure ...
> now x(t)=delta(t), since I want to find the impulse response of this > system to the impulse input. > > I did not find this in Oppeheim's Signal & Systems book... that's very > strange. I am very confused by his "initial rest condition" arguement. > > Can anybody show some rules about solving diff equation with impulse input > in general? And point me to some resources?
for solving diff equation like this i would recommend laplace-transformation the solution for y'(t) + 2*y(t) = 0 is y(t) = exp(-2*t) there is only a DC-component in the frequency response so the responce will be that y after the impulse is constant, but different of y before to make things visual you can calculate the frequency respons by using the fourier-tranformation Y(w)/X(w) = (2 + jw)/(2 - w^2) a pole on -2*j, making the system stable in mechanical terms it's a massless object connected with a spring and a damper the initial rest condition implies that the kinetic energy and potential energy of the spring are initially zero
On Sun, 14 Aug 2005, kiki wrote:
> Differential equation such as a simple first order non-homogeous equation: > > y'(t)+2*y(t) = x(t), >
You want to find a particular solution to the equation which depends upon x(t). Call that f(t). Now (the rest condition?) y' + 2y = 0 has the solution e^-2t Thus the solutions are c.e^-2t + f(t)
> now x(t)=delta(t), since I want to find the impulse response of this system > to the impulse input. >
Yuck,equationwithoutspaces.
> I did not find this in Oppeheim's Signal & Systems book... that's very > strange. I am very confused by his "initial rest condition" arguement. > > Can anybody show some rules about solving diff equation with impulse input > in general? And point me to some resources? >
There's often good reason for that in a newsgroup. It keeps the equation from being broken across lines no matter what quoting does to it. ... Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
jan hauben wrote:
>>Differential equation such as a simple first order non-homogeous equation: >> >>y'(t)+2*y(t) = x(t), > > > are you sure this is the right equation ? > asuming you were sure ... > > >>now x(t)=delta(t), since I want to find the impulse response of this >>system to the impulse input. >> >>I did not find this in Oppeheim's Signal & Systems book... that's very >>strange. I am very confused by his "initial rest condition" arguement. >> >>Can anybody show some rules about solving diff equation with impulse input >>in general? And point me to some resources? > > > for solving diff equation like this i would recommend laplace-transformation > the solution for y'(t) + 2*y(t) = 0 is y(t) = exp(-2*t) > there is only a DC-component in the frequency response > so the responce will be that y after the impulse is constant, but different > of y before > to make things visual you can calculate the frequency respons by using the > fourier-tranformation > Y(w)/X(w) = (2 + jw)/(2 - w^2) > a pole on -2*j, making the system stable > > in mechanical terms it's a massless object connected with a spring and a > damper > the initial rest condition implies that the kinetic energy and potential > energy of the spring are initially zero
I often find that my intuition is better served by solving for the step response, then differentiating. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
> William Elliot wrote: > > ... > >> Yuck,equationwithoutspaces. > > There's often good reason for that in a newsgroup. It keeps the > equation from being broken across lines no matter what quoting > does to it.
Except if there's a minus sign in the formula. Better to make it readable, then castigate fourth-level respondents who don't rectify messy quotes ;) Martin -- Quidquid latine dictum sit, altum viditur.
Jerry Avins wrote:
> > jan hauben wrote: > >>Differential equation such as a simple first order non-homogeous equation: > >> > >>y'(t)+2*y(t) = x(t), > > > >>now x(t)=delta(t), since I want to find the impulse response of this > >>system to the impulse input. > >>
y'(t)+2*y(t) = x(t) => (multyplying with integrating factor) exp(2*t)*y'(t)+2*exp(2*t)*y(t) = exp(2*t)*x(t) => ( exp(2*t)*y(t) )' = exp(2*t)*x(t) => exp(2*t)*y(t) = C + int_{-oo}^{t} exp(2*s)*x(s) ds => y(t) = exp(-2*t)*C + exp(-2*t)*int_{-oo}^{t} exp(2*s)*x(s) ds for x(t) = delta(t) it follows that y(t) = exp(-2*t)*C + exp(-2*t)*H(t) with H(t) the Heaviside function (H(t)=1 for t>0 and 0 for t<0; dH(t)/dt = dirac(t)). Wilbert
On Mon, 15 Aug 2005, Jerry Avins wrote:
> William Elliot wrote: > > > Yuck,equationwithoutspaces. > > There's often good reason for that in a newsgroup. It keeps the equation > from being broken across lines no matter what quoting does to it. >
That is not a good reason because most equations aren't that long and an equation which is that long and all the moreindeedofspaces canbebrokenintotwolines which can be done at a major +, for example.
kiki wrote:
> Differential equation such as a simple first order non-homogeous equation: > > y'(t)+2*y(t) = x(t), > > now x(t)=delta(t), since I want to find the impulse response of this system > to the impulse input. > > I did not find this in Oppeheim's Signal & Systems book... that's very > strange. I am very confused by his "initial rest condition" arguement. > > Can anybody show some rules about solving diff equation with impulse input > in general? And point me to some resources? > > Thanks a lot! > > >
Playing fast and loose not only with the dirac delta functional but with the conversion from differential to integral equations gets you: y'(t) = -2*y(t) + x(t) implies that t / y(t) = | (-2*y(t) + x(t)) dt + y(0-). / 0- Where 0- is infinitesimally lower than zero and 0+ is infinitesimally higher. Now solve the integral from 0- to 0+. You can argue that y(t) is finite, so: y(0+) = 1 + y(0-). Now finish solving as if it were a regular old diff-eq. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott wrote:
> kiki wrote: >> Differential equation such as a simple first order non-homogeous >> equation: y'(t)+2*y(t) = x(t), >> >> now x(t)=delta(t), since I want to find the impulse response of this >> system to the impulse input. >> >> I did not find this in Oppeheim's Signal & Systems book... that's >> very strange. I am very confused by his "initial rest condition" >> arguement. Can anybody show some rules about solving diff equation with >> impulse >> input in general? And point me to some resources? >> >> Thanks a lot! >> >> >> > Playing fast and loose not only with the dirac delta functional but > with the conversion from differential to integral equations gets you: > > y'(t) = -2*y(t) + x(t) > > implies that > > t > / > y(t) = | (-2*y(t) + x(t)) dt + y(0-). > / > 0- > > Where 0- is infinitesimally lower than zero and 0+ is infinitesimally > higher. Now solve the integral from 0- to 0+. You can argue that > y(t) is finite, so: > > y(0+) = 1 + y(0-). > > Now finish solving as if it were a regular old diff-eq.
Correct. Tim has the right way to look at the problem. To expand on this approach a bit: The original problem is y'+2y=delta(t), y(0)=0. (1) The highest order derivative on the LHS must be a delta, so y is a step function at t=0. Integrate the ODE from t=0- to t=0+ to get y(0+)+0=1. Thus, the original system, Eq. 1, is equivalent to the system y'+2y=0, y(0)=1, (2) whose solution the original poster can presumably obtain. y(t) is discontinuous at t=0.
