Hello i am trying to implement a wavelet transform using digital filters! Could anyone tell me how to design these filters. I have tried to use matlab command FIR1 but it seems not to be a good way to design these filters! Thank for your help This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Wavelet filters
Started by ●August 15, 2005
Reply by ●August 15, 20052005-08-15
"mariya" <angelique1@jippii.fi> writes:> Hello > > i am trying to implement a wavelet transform using digital filters! Could > anyone tell me how to design these filters. I have tried to use matlab > command FIR1 but it seems not to be a good way to design these filters! > Thank for your helpHi, My homework on wavelets from my DSP class at NCSU is on-line at http://www.digitalsignallabs.com/hw8.zip Open the zip file and read the file hw.pdf with Adobe Acrobat. Specifically, read Appendix A, which gives an overview of Matlab's wavelet toolbox. I found I needed it for my own sanity. --Randy -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
Reply by ●August 16, 20052005-08-16
mariya skrev:> Hello > > i am trying to implement a wavelet transform using digital filters! Could > anyone tell me how to design these filters. I have tried to use matlab > command FIR1 but it seems not to be a good way to design these filters!The main difference between wavelets and other sub-band filters, is that the wavelet filters are interrelated in a special way: h_n(t) = 1/a_n * h'((t-b_n)/a_n) [1] where h'(n) is the "mother wavelet". What [1] says, is that each wavelet filter is generated by a sacled, translated and compressed version of some basic wave (impulse response of the filter, as it were). These "mother wavelets" can be quite simple (the "mexican hat") or they can be veritable pains in the neck, like the Daubechie wavelets. The main point is that the wavelet transform introduces strong requirements to the FIR filters. You will probably not be able to use any FIR filter generator to design wavelet filters. Rune
> You will probably not be able > to use any FIR filter generator to design wavelet filters.besides, you dont really need to as there are plenty of good wavelet filters out there, many of which are included in the wavelet toolbox by Matlab. Here are the ones listed in my version of Matlab... biorwavf - Biorthogonal spline wavelet filters. cgauwavf - Complex Gaussian wavelet. cmorwavf - Complex Morlet wavelet. coifwavf - Coiflet wavelet filter. dbaux - Daubechies wavelet filter computation. dbwavf - Daubechies wavelet filters. fbspwavf - Complex Frequency B-Spline wavelet. gauswavf - Gaussian wavelet. mexihat - Mexican Hat wavelet. meyer - Meyer wavelet. meyeraux - Meyer wavelet auxiliary function. morlet - Morlet wavelet. rbiowavf - Reverse Biorthogonal spline wavelet filters. shanwavf - Complex Shannon wavelet. symaux - Symlet wavelet filter computation. symwavf - Symlet wavelet filter.
>The main point is that the wavelet transform introduces strong >requirements to the FIR filters. You will probably not be able >to use any FIR filter generator to design wavelet filters. > >Rune > >********************************** Hi again, If i understood correct you mean that i cannot get wavelet filters using FIR digital filters? I did handle some matlab wavelet filters but the point is that i don't know what are their features such as cutoff or sampling frequency. For instance to decompose the signal there are some quit command such as [C,L] = wavedec(X,N,'wname') [C,L] = wavedec(X,N,Lo_D,Hi_D) Here we need just to choose the wavelet name (let's say 'db3') suitable to our application or the related filters (quit straight )! I would also use the same filters for my wavelet transform on a processor but how to get these filters coefficients?? thanx! This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●August 17, 20052005-08-17
I am not sure which version you are using, but if you are using matlab 12.1 check: http://www.mathworks.com/support/solutions/data/1-18NCG.html?solution=1-18NCG
mariya skrev:> >The main point is that the wavelet transform introduces strong > >requirements to the FIR filters. You will probably not be able > >to use any FIR filter generator to design wavelet filters. > > > >Rune > > > > > ********************************** > Hi again, > > If i understood correct you mean that i cannot get wavelet filters using > FIR digital filters?Yes you can, if the filter generator is set up to take into account the particular aspects that wavelets depend on. I am saying that you probably need specialized wavelet generators to do that. The wavelets themselves are FIR filters. Rune
Reply by ●August 25, 20052005-08-25
Hi, Isn't it correct that the "dbaux command" gives the coefficients of the wavelet reconstruction filters? Any suggestion on which command to use in order to get the coefficients of the analysis filter. I am using matlab version 7.0! Thanks for your time! This message was sent using the Comp.DSP web interface on www.DSPRelated.com
