Hello, I am looking for a fast divide-by-N chip with a high bandwidth. I'm hoping for an input frequency of 1 GHz but would probably settle for one around 80 MHz. Duty cycle doesn't matter for the DSP application I have in mind but I do need to run at 3V. Thanks to anyone who knows of one and cares to share, Thomas
super fast divide-by-N
Started by ●August 16, 2005
Reply by ●August 16, 20052005-08-16
On Tue, 16 Aug 2005 18:30:36 GMT, "Thomas Magma" <somewhere@overtherainbow.com> wrote:>Hello, > >I am looking for a fast divide-by-N chip with a high bandwidth. I'm hoping >for an input frequency of 1 GHz but would probably settle for one around 80 >MHz. Duty cycle doesn't matter for the DSP application I have in mind but I >do need to run at 3V. > >Thanks to anyone who knows of one and cares to share, > >Thomas >http://www.azmicrotek.com/ ...Jim Thompson -- | James E.Thompson, P.E. | mens | | Analog Innovations, Inc. | et | | Analog/Mixed-Signal ASIC's and Discrete Systems | manus | | Phoenix, Arizona Voice:(480)460-2350 | | | E-mail Address at Website Fax:(480)460-2142 | Brass Rat | | http://www.analog-innovations.com | 1962 | I love to cook with wine. Sometimes I even put it in the food.
> http://www.azmicrotek.com/ >Thanks Jim, Nice parts but I can only see a divided by 2 and divided by 4 from that company. I'm kind of looking for a divide by N. Maybe up to 32 or so. Thanks, Thomas
Once you have divided by 2 or 4, you are in the realm of fast logic (look at the various fast logic families). One search I would suggest is 'fast prescalers'. Jim has set you on the right path :) Cheers PeteS
Thomas Magma wrote:>>http://www.azmicrotek.com/ >> > > > Thanks Jim, > > Nice parts but I can only see a divided by 2 and divided by 4 from that > company. I'm kind of looking for a divide by N. Maybe up to 32 or so. >Above, you imply that there are only 32 values of N (1-32). Can you multiply by 1/N instead? -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Sometimes experience is the only teacher that works - Mike Rosing
Thomas Magma wrote:> > >> http://www.azmicrotek.com/ >> > > Thanks Jim, > > Nice parts but I can only see a divided by 2 and divided by 4 from that > company. I'm kind of looking for a divide by N. Maybe up to 32 or so. > > Thanks, > ThomasThe important number is what is the minimum divide ratio that you need. If the minimum N is a reasonably large number then you can use the conventional approach used in RF synthesisers, where you have a fast prescaler (e.g. divide by 8 or 9) and then a slower block of logic that decides when to switch the prescaler into divide by 8, and when to use divide by 9. You might be able to find a RF synth chip where the divider output is available at a pin. Look at the Analog Devices ADF4111 for example which can mux out the divider output to a pin. Chris
Thomas Magma wrote:> Hello, > > I am looking for a fast divide-by-N chip with a high bandwidth. I'm hoping > for an input frequency of 1 GHz but would probably settle for one around 80 > MHz. Duty cycle doesn't matter for the DSP application I have in mind but I > do need to run at 3V.That's a pretty broad range, Thomas. Like me asking a bank for a loan of $1,250 and saying I'll settle for a dollar. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>Can you multiply by 1/N instead?Ah...yes?... I don't quite know what you mean here. I can see how they are equal mathematically, but I don't know how to achieve this with electronics. "Jim Thomas" <jthomas@bittware.com> wrote in message news:11g4lnbjuad2578@corp.supernews.com...> Thomas Magma wrote: >>>http://www.azmicrotek.com/ >>> >> >> >> Thanks Jim, >> >> Nice parts but I can only see a divided by 2 and divided by 4 from that >> company. I'm kind of looking for a divide by N. Maybe up to 32 or so. >> > > Above, you imply that there are only 32 values of N (1-32). Can you > multiply by 1/N instead? > > > -- > Jim Thomas Principal Applications Engineer Bittware, Inc > jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 > Sometimes experience is the only teacher that works - Mike Rosing
Thomas Magma wrote:> Hello, > > I am looking for a fast divide-by-N chip with a high bandwidth. I'm hoping > for an input frequency of 1 GHz but would probably settle for one around 80 > MHz. Duty cycle doesn't matter for the DSP application I have in mind but I > do need to run at 3V. > > Thanks to anyone who knows of one and cares to share,Look at OnSemi, under high performance counters, you'll find ones that go 1.4GHz. You will pay for this performance :) If a few hundred Mhz is OK, then look at any modern 32 macrocell CPLD [ Xilinx / Lattice ], and they are closer to $1 -jg
> That's a pretty broad range, Thomas. Like me asking a bank for a loan of > $1,250 and saying I'll settle for a dollar. > > JerryHa. Let me give you a bit of back ground then. I am really pushed for space. I need different clock frequencies thru-out my board. My highest frequency is a Fox RFXO running around a GHz. I would like to derive all other clocks from this one if possible. Next lowest frequency is around 80 MHz. Then a few after that. I hate PLLs and I don't want a bunch a xtals on my board. So I thought I would just divide down from my highest frequency. One chip solution would be the best. Thomas
