OT Conceit
Started by Jerry Avins ●August 19, 2005
>Stan Pawlukiewicz wrote: > > ... > >> You guys probably have to drill out a lot of stripped screws. > >I have a great little cold chisel that makes short work of round-head >bolts and rivets up to 1/4 inch. I used it yesterday to work on the '89 >Class B camper I got late last week. I think I've figured out everything
>but the plumbing, where to get the built-in propane tank filled, and >where the transmission fluid filler is. I took up a turn and a half on >the steering box adjuster; it goes where I point it now. At 75K miles, >it's 100K miles younger than my '94 Subaru. > >Jerry >-- >Engineering is the art of making what you want from things you can get.
����������������������������������������������������������������������� I hate to say this, but I have to say it: I have no clue what you boys are talking about! And not that I did not try either! --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Bhooshan Iyer wrote:
> I hate to say this, but I have to say it: I have no clue what you boys are > talking about! And not that I did not try either!
What we're chattering about has nothing to to with engineering. It's mechanic talk about how to recover from things gone bad. Sometimes screws stick in place. Often, rust is involved. The successful methods for dealing with them aren't usually in the service manuals. One way to deal with a screw that won't turn is to remove the head by fair means or foul. A hole the size of the body centered on the head is an effective method of decapitation, as is a chisel. "Cold chisel" is a blacksmith's term for a chisel to be used on steel. It needs to be hard but tough; not your ordinary steel. The queer name distinguishes it from a hot chisel, used by blacksmiths for cutting and slitting red hot iron. Naturally, the metallurgy of those chisels is different. The dandy little cold chisel I wrote of has a much more acute cutting edge than most of its kind will support. I don't know how to get another. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
>>Stan Pawlukiewicz wrote: >> >> ... >> >> >>>You guys probably have to drill out a lot of stripped screws. >> >>I have a great little cold chisel that makes short work of round-head >>bolts and rivets up to 1/4 inch. I used it yesterday to work on the '89 >>Class B camper I got late last week. I think I've figured out everything > > >>but the plumbing, where to get the built-in propane tank filled, and >>where the transmission fluid filler is. I took up a turn and a half on >>the steering box adjuster; it goes where I point it now. At 75K miles, >>it's 100K miles younger than my '94 Subaru. >> >>Jerry >>-- >>Engineering is the art of making what you want from things you can get. > > ����������������������������������������������������������������������� > > I hate to say this, but I have to say it: I have no clue what you boys are > talking about! And not that I did not try either! > > --Bhooshan > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
My experience with loosening a screw that requires one to use two hands on the screw driver is that I'll typically strip the head. At best I usually have to replace the screw. Worst case scenario is that you have to drill the screw out, and likely have to re-tap the hole. IMHO, if you need two hands (for an adult male) to take a screw out, you probably should be looking for some WD40, liquid wrench, prayer ect...
On Wed, 24 Aug 2005 09:56:24 -0400, Stan Pawlukiewicz
<spam@spam.mitre.org> wrote:
>My experience with loosening a screw that requires one to use two hands >on the screw driver is that I'll typically strip the head. At best I >usually have to replace the screw. Worst case scenario is that you have >to drill the screw out, and likely have to re-tap the hole. IMHO, if >you need two hands (for an adult male) to take a screw out, you probably >should be looking for some WD40, liquid wrench, prayer ect...
These days WD40 is being replaced by PBBlaster, which does a gnarlier job and has a nasty smell to further convince you that it's better. ;) I do a lot of car wrenching and working on Arizona cars is VASTLY different than working on northern cars. We get northern cars in our club sometimes that need maintenance and those of us used to working on AZ cars will say, "No problem, that's a ten minute job..." not fully appreciating the implications of breaking the heads off rusted pinch bolts and the subsequent hours trying to get an EZ out or something into what's left of a Grade 8 bolt. Arg. Screws are nothing. Phhffft. We do stuck screws in our sleep. Air tools, man... :) Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
"Stan Pawlukiewicz" <spam@spam.mitre.org> wrote in message
news:dehua8$60q$1@newslocal.mitre.org...
> Bhooshan Iyer wrote: >>>Stan Pawlukiewicz wrote: >>> >>>>You guys probably have to drill out a lot of stripped screws. >>> >>>I have a great little cold chisel that makes short work of round-head bolts >>>and rivets up to 1/4 inch. I used it yesterday to work on the '89 Class B >>>camper I got late last week. I think I've figured out everything >> >> >>>but the plumbing, where to get the built-in propane tank filled, and where >>>the transmission fluid filler is. I took up a turn and a half on the steering >>>box adjuster; it goes where I point it now. At 75K miles, it's 100K miles >>>younger than my '94 Subaru. > > > My experience with loosening a screw that requires one to use two hands on the > screw driver is that I'll typically strip the head. At best I usually have to > replace the screw. Worst case scenario is that you have to drill the screw > out, and likely have to re-tap the hole. IMHO, if you need two hands (for an > adult male) to take a screw out, you probably should be looking for some WD40, > liquid wrench, prayer ect...
Yes, though you are better off if the screw driver head size/shape exactly matches the screw (as opposed to what I usually do--use whatever happens to be on-hand!).
On Mon, 22 Aug 2005 09:53:16 -0700, Tim Wescott <tim@seemywebsite.com>
wrote:
>Jerry Avins wrote: > >> Geoff wrote: >> >> ... >> >>> That last paragraph serendipitously provides another example....I've >>> read umpteen books in which the face, chest or stomach of a "prone" >>> body is assaulted etc. A clever trick! The word the authors didn't >>> know was, of course, "supine"..... >> >> >> Those who know anatomy will know those words if they make connections at >> all. The muscles that rotate the wrist relative to to the elbow are the >> pronator and supinator. Usually, the supinator is the stronger, so when >> straining to remove a screw, try using the left hand. >> >> Jerry > >I'm not that proud. If I can't get it out with my right hand I put >_both_ hands on the screwdriver. > >-- > >Tim Wescott
Hi Tim, back when I was workin' on my motorcycle I grabbed the screwdriver with "channel-lock" pliers. The torque you could achieve this way was pretty darned great. (It "chews up" the handle of your screwdriver, but by Sweet Merciful Jesus you could turn a screw awful hard that way.) [-Rick-]
Rick Lyons wrote:
> On Mon, 22 Aug 2005 09:53:16 -0700, Tim Wescott <tim@seemywebsite.com> > wrote: > > >>Jerry Avins wrote: >> >> >>>Geoff wrote: >>> >>> ... >>> >>> >>>>That last paragraph serendipitously provides another example....I've >>>>read umpteen books in which the face, chest or stomach of a "prone" >>>>body is assaulted etc. A clever trick! The word the authors didn't >>>>know was, of course, "supine"..... >>> >>> >>>Those who know anatomy will know those words if they make connections at >>>all. The muscles that rotate the wrist relative to to the elbow are the >>>pronator and supinator. Usually, the supinator is the stronger, so when >>>straining to remove a screw, try using the left hand. >>> >>>Jerry >> >>I'm not that proud. If I can't get it out with my right hand I put >>_both_ hands on the screwdriver. >> >>-- >> >>Tim Wescott > > > Hi Tim, > > back when I was workin' on my motorcycle > I grabbed the screwdriver with "channel-lock" > pliers. The torque you could achieve this > way was pretty darned great. > > (It "chews up" the handle of your screwdriver, > but by Sweet Merciful Jesus you could turn a screw > awful hard that way.)
An adjustable wrench on a screw driver with a square shank chews up nothing and supplies enough torque to twist the head off a 3/8 stove bolt. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
news:CIidnWZwZJgtNoreRVn-jQ@rcn.net...
>>> Hi Tim, >> >> back when I was workin' on my motorcycle >> I grabbed the screwdriver with "channel-lock" pliers. The torque you >> could achieve this way was pretty darned great. >> >> (It "chews up" the handle of your screwdriver, but by Sweet Merciful >> Jesus you could turn a screw awful hard that way.) > > An adjustable wrench on a screw driver with a square shank chews up > nothing and supplies enough torque to twist the head off a 3/8 stove bolt. >
Rick and Jerry, The trick I was taught back when I worked on motorcycles was to use an impact driver especially when opening the aluminum engine case. This will actually remove the screws quite cleanly. During the impact, the driver is both thrust into the screw and at the same time the driver provides a torque. Plus the impact itself serves to break the corrosion that binds the screw to the case and also momentarily compress the length of the screw thereby relieving the torsional friction due to the screw's threads. If you recall, when a screw or bolt is tightened properly, the screw is stretched (within it elastic limits) so all of the threads provide friction. When the proper screw bit is used, the screw heads stay intact. Just be sure to not to confuse Philips with Posidrive. I recall the old British bikes (BSAs and Triumphs) coming with Wentworth tool kits. The wrenches were nearly impossible to obtain otherwise. Good impact drivers also accept sockets. Clay
Clay S. Turner wrote:
> "Jerry Avins" <jya@ieee.org> wrote in message > news:CIidnWZwZJgtNoreRVn-jQ@rcn.net... > >>>>Hi Tim, >>> >>> back when I was workin' on my motorcycle >>>I grabbed the screwdriver with "channel-lock" pliers. The torque you >>>could achieve this way was pretty darned great. >>> >>>(It "chews up" the handle of your screwdriver, but by Sweet Merciful >>>Jesus you could turn a screw awful hard that way.) >> >>An adjustable wrench on a screw driver with a square shank chews up >>nothing and supplies enough torque to twist the head off a 3/8 stove bolt. >> > > > Rick and Jerry, > > The trick I was taught back when I worked on motorcycles was to use an > impact driver especially when opening the aluminum engine case. This will > actually remove the screws quite cleanly. During the impact, the driver is > both thrust into the screw and at the same time the driver provides a > torque. Plus the impact itself serves to break the corrosion that binds the > screw to the case and also momentarily compress the length of the screw > thereby relieving the torsional friction due to the screw's threads. If you > recall, when a screw or bolt is tightened properly, the screw is stretched > (within it elastic limits) so all of the threads provide friction. When the > proper screw bit is used, the screw heads stay intact. Just be sure to not > to confuse Philips with Posidrive. I recall the old British bikes (BSAs and > Triumphs) coming with Wentworth tool kits. The wrenches were nearly > impossible to obtain otherwise. Good impact drivers also accept sockets.
The best trick I know in that department is a gunk called "Neverseize". (IIRC, Permatex bought them out and changed the name.) It looks like grease loaded with powdered aluminum, but the loading is a molybdenum compound. (I'm tempted to say molybdenum disulfide, but isn't that black?) When I replaced the manifold gasket on a car (along with some studs I had to drill out) I reassembled using that gunk. 85,000 miles later, it came off again with ordinary tools and no grunting. I use it on lug nuts on alloy wheels. It saves me from having to break off and replace the studs when changing a flat. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
